Leaky Curbless Shower. Ideas? - Plumbing - Contractor Talk
Old 05-25-2019, 09:16 PM   #1
THEPRO'SPRO's Avatar
Trade: Engineering
Rewards Points: 6
I am about to work on a leaking curbless shower. It looks like it was improperly installed. The pan (under the grout) fills with water, and then overflows causing the baseboards to become slightly damp. I know the first answer is the pan was likely not installed correctly. Most possibly, the gradient isn't steep enough to allow sufficient water to drain out. Are there any other less labor intensive things that could be done in this case? I am trying to do this job as cheaply as possible. Could I build a curb right outside the glass door and directly at the lip of the pan? I would only need to remove a few tiles to do this.
THEPRO'SPRO is offline
Old 05-25-2019, 09:31 PM   #2
tjbnwi's Avatar
Rewards Points: 3,480
Re: Leaky Curbless Shower. Ideas?
Check the pitch, with "normal" tile 1/4" per foot is all that's needed. Pebbles need 3/8-1/2.
Odds are this is a capillary issue, they did not install a capillary break.
tjbnwi is offline
Old 05-25-2019, 09:51 PM   #3
Trade: Engineering
Rewards Points: 6
Thanks for the reply. I will check that. I can see a small portion of the pan once I removed the baseboard. It seems covered correctly by a PVC cover. From that vantage point, I can watch the water rise to the point of overflowing. It then runs, like a small river, in the channel once occupied by the baseboard - in between the tile and the bottom plate stud. It takes about 10 to 15 minutes of running the shower for the water to reach this point.
Old 05-25-2019, 09:57 PM   #4
tjbnwi's Avatar
How is the water getting to the pan liner?---through the grout and/or tile.
If this is a mud pan, probably should have had a drain with weeps, if not, you need a capillary dam to prevent the water under the tile from leaving the pan.
tjbnwi is offline
Old 05-25-2019, 10:29 PM   #5
Trade: Engineering
Rewards Points: 6
I assume it is getting to the pan through the grout and tile. Could the drain also be leaking? It is the standing, center of the pan, style drain. The shower is built on a slab foundation house.
Old 05-25-2019, 10:37 PM   #6
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 13,525
Who built the shower? Can you get any pics of the work in progress?
MarkJames is offline
Old 05-25-2019, 10:45 PM   #7
tjbnwi's Avatar
Yes, it's getting through the grout and tile.
Seeping between the tile and the drain, maybe.
If the water is on the liner, not under, I doubt a drain leak is causing this.
tjbnwi is offline
Old 05-25-2019, 11:37 PM   #8
Caleb1989's Avatar
Rewards Points: 286
Take up the tile around the drain. Fix it so the pan-liner water can flow into the drain holes.
Just about the only way I know to fix something like that.
There’s my $3.50
Caleb1989 is offline
Old 05-26-2019, 08:40 AM   #9
tjbnwi's Avatar
There’s my $3.50
If they put in a drain body with weeps. Have a feeling they didn't, with the liner above the pan, weeps are not be necessary. As described this is not a water in/water out system.
tjbnwi is offline
Capillary water movement (curbless shower) srwcontracting Tiling 52 11-16-2015 11:05 PM
membrane termination on curbless shower cleveman Flooring 9 12-20-2010 06:22 PM
Strange shower leak - need help JSMHDM Plumbing 13 12-06-2010 05:38 AM
Frameless glass shower build, ideas please rotarex General Discussion 23 12-29-2008 09:57 AM
Looking for some new ideas for shower jjcards Tiling 22 07-17-2008 11:11 AM
