Install Sump Pump Check Valve On Washing Machine - Plumbing - Contractor Talk
Old 09-01-2019, 12:17 PM   #1
JoeThomas's Avatar
Trade: plumbing
Rewards Points: 22
We just purchased a Everbuilt THD1020 (In-Line Sump Pump Check Valve) , and installed in the back hose of our washing machine. The original hose would leak detergent soap and water. Is it a good practice to install In-Line check valves like this on laundry machines? Are there any negative consequences, issues with flooding or clogging from doing this? The original hose kept leaking, so decide to get this instead. How does this fit in state california rules?
https://www.homedepot.com/p/Everbilt...1020/205616001
JoeThomas is offline
Old 09-01-2019, 01:12 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 1,764
Re: Install Sump Pump Check Valve On Washing Machine
if the hose is leaking why not just fix that...
plumbing is your trade?????
or are you a laundry mat owner trying to cobble your plumbing drain together?????....
griz is online now
Big Johnson (09-01-2019)
Old 09-01-2019, 01:52 PM   #3
JoeThomas's Avatar
Trade: plumbing
Rewards Points: 22
thanks, electrical is my trade, mistyped on my profile, thanks
Old 09-01-2019, 01:53 PM   #4
hdavis's Avatar
Rewards Points: 1,086
Just another pumping restriction.
hdavis is online now
Old 09-01-2019, 02:01 PM   #5
JoeThomas's Avatar
Trade: plumbing
Rewards Points: 22
ok, I will explain this to the plumber who installed this, it may cause another water restriction, thank you
Old 09-01-2019, 02:37 PM   #6
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 4,022
Another electrician, those guys are a dime a dozen. Time for prices to come down.
Big Johnson is offline
SmallTownGuy (09-01-2019)
Old 09-01-2019, 02:43 PM   #7
John the Builder
SmallTownGuy's Avatar
Rewards Points: 6,114
I think that "painter" doing the deck is another electrical sumthin or nuther.
They are coming outta da woodwork, I tell ya !
SmallTownGuy is offline
The Following User Says Thank You to SmallTownGuy For This Useful Post:
mrcat (09-01-2019)
Old 09-01-2019, 07:30 PM   #8
The Grand Wazoo
KillerToiletSpider's Avatar
Rewards Points: 2,036
A check valve is a poor way to address a suds pressure zone problem.
I may be going to hell in a bucket, but at least I'm enjoying the ride.
KillerToiletSpider is offline
