Help With 3 Basin Kitchen Sink Plumb - Plumbing - Contractor Talk
Old 03-30-2016, 01:08 AM   #1
Kaitzco's Avatar
Trade: General Contractor B Lic
Rewards Points: 4
I am a General Contractor starting a full renovation of a kitchen. The home owner has chosen a 3 basin kitchen sink. The disposal will be placed in the center basin.
I am very familiar with the 2 basin plumb in, however I am unable to find legitimate info elsewhere about how to properly tie all the lines together. I also could not find any good schematics or pictures either.
Any detailed information will greatly be appreciated!
Kaitzco is offline
Old 03-30-2016, 01:44 AM   #2
m1911's Avatar
Trade: finish carpenter
Rewards Points: 15,632
Re: Help With 3 Basin Kitchen Sink Plumb
Call your plumber. Done.
Originally Posted by tipitop View Post
That guy in video have mental issues plus eat hole turtle from some reason
m1911 is offline
Old 05-03-2016, 12:02 AM   #3
Kaitzco's Avatar
Rewards Points: 4
Lame negativety
Kaitzco is offline
Old 05-03-2016, 02:34 AM   #4
VinylHanger's Avatar
Rewards Points: 12,910
But true. Why not just ask your plumber? It's what I do and he asks me about framing or siding, or the things I do. It's how it works.
VinylHanger is offline
The Following 2 Users Say Thank You to VinylHanger For This Useful Post:
m1911 (05-03-2016), Randy Bush (05-03-2016)
Old 05-03-2016, 06:45 AM   #5
mikeswoods's Avatar
Trade: interior remodeling
Rewards Points: 2,664
3 p-traps--and a 3 outlet Y--
Best would be to redo the piping inside the wall to give you 3 trap openings.
mikeswoods is offline
Old 05-03-2016, 08:25 AM   #6
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 2,532
All normal double sinks I have seen only have one P-trap, why would this one need 3? I could see 2 for ease of install.
Not a plumber so just asking.
Randy Bush is offline
Old 05-03-2016, 08:33 AM   #7
MarkJames's Avatar
Rewards Points: 18,913
Fwiw...
I just replaced a double bowl sink where separate traps were needed so I wye'd it in the cabinet. Otherwise, the combo drain would have required a lower P-trap (and arm) to make it work.
MarkJames is online now
Old 05-03-2016, 03:30 PM   #8
Tom M's Avatar
Rewards Points: 11,160
Doesnt sound right, but I wonder if this triggers the need for a 2" trap.
Tom M is online now
Old 05-03-2016, 06:48 PM   #9
SectorSecurity's Avatar
Trade: Low Voltage Wiring
Rewards Points: 2,828
https://www.google.ca/search?q=how+t...obile&ie=UTF-8
Took me about 20 seconds I'm sure its covered on YouTube it you are completely stuck.
SectorSecurity is offline
Old 05-04-2016, 06:33 AM   #10
mikeswoods's Avatar
In our area every sink needs its own P-trap---
The Following User Says Thank You to mikeswoods For This Useful Post:
Randy Bush (05-04-2016)
tiling kitchen first of several 1 1/2 '' cement over wood sub floor carolitis Tiling 2 05-01-2013 11:29 AM
More white kitchen cabinets Gus Dering Carpentry Picture Post 23 12-14-2012 09:45 AM
Hardwood Flooring in a Galley Kitchen laid Parallel to the Floor Joists? David Osinga Flooring 22 12-10-2012 05:24 AM
Bathroom sink strainer drain issue with venting stanfordconst Plumbing 1 05-19-2011 06:06 PM
clogged kitchen waste line beapainter Plumbing 2 01-09-2010 02:55 AM
