Had A 'duh' Moment (pex Plumbing And Fittings) - Plumbing - Contractor Talk
Old 02-11-2014, 05:01 AM   #1
Repair/Remodeling Tech.
jproffer's Avatar
Trade: Repair and Remodeling Services
Rewards Points: 66
I'm getting ready to do some PEX plumbing in the spring, and I've bought a few fittings, crimp rings, etc. The initial plan was to use crimp connections.
In the mean time, I found an expander tool on Ebay and bought it, thinking that "I'd really rather use that method...and there's the tool...so WTH".
And sitting here at 4am, thinking about this a little bit, I just had a '*head slap* you dumb-a$$' moment, lol.
I have the fittings for crimp connections, which I can only assume (now I realize) are smaller than fittings for expansion connections, right?
It hit me like a shot in the head.....because, naturally, I'd been messing around with the fittings/pipe a little bit and the fitting I have slide right in.......and that's when it..... ....they slide right in. So why would I need an expansion tool for THAT??? (this is where the head slap came in)
So I guess ultimately my question is...am I right?? Is there 2 different formats of fittings, depending on the connection method?
If so, it's too late for this job, and I guess I'll have a nice expander tool sitting in the case waiting for the next job while I crimp this job out...which isn't the end of the world, but still. Just makes me shake my head and laugh at myself.
Jim P.
jproffer is offline
Old 02-11-2014, 05:44 AM   #2
pappagor's Avatar
Trade: general contractor
Rewards Points: 32
Re: Had A 'duh' Moment (pex Plumbing And Fittings)
yep you need pex pro fittings crimp fittings will not work hope you have not got your pipe yet you will need pex agua pex a pipe to
pappagor is offline
The Following User Says Thank You to pappagor For This Useful Post:
jproffer (02-11-2014)
Old 02-11-2014, 05:52 AM   #3
jproffer's Avatar
Rewards Points: 66
Yea, I wanted to use Pex-a regardless, so that's what I got...just was sitting here thinking about the fittings..."expanding the pipe...........wait, why do I need to expand.....oh sheeeeeot".
Like I said, it's not the end of the world. I'll crimp this job out and get the right G&# [email protected]!& fittings next time
Thanks for the confirmation.
Jim P.
jproffer is offline
Old 02-11-2014, 05:59 AM   #4
pappagor's Avatar
Rewards Points: 32
pex supply is good to deal with
pappagor is offline
Old 02-11-2014, 06:03 AM   #5
jproffer's Avatar
Rewards Points: 66
Here's another one for ya (or anyone else)...as I was looking around (Amazon) for propex fittings, I saw a few that were 5/8" size (so it said). Is that just the actual size of the expansion fittings for 1/2" pipe? Or was 3/4 and 1/2 not enough, and they had to add a 5/8 option in there?
IOW, is there actually 5/8" pex PIPE that one would use with 5/8" pex fittings?
ETA: Not that I necessarily want to use 5/8 vs 1/2, just curious.
Jim P.
jproffer is offline
Old 02-11-2014, 06:04 AM   #6
jproffer's Avatar
Rewards Points: 66
Thanks for that. I'll check them out next time around.
Jim P.
jproffer is offline
Old 02-11-2014, 06:18 AM   #7
pappagor's Avatar
Rewards Points: 32
yes there is a 5/8 pex never use it all i use is 1/2 3/4 1 inch
pappagor is offline
Old 02-11-2014, 06:27 AM   #8
jproffer's Avatar
Rewards Points: 66
Ok. Like I said, just curious. I would probably never use it either. I don't really see the point in having an 1/8 fraction in there. If 1/2" just absolutely won't work...why not just use 3/4"..............................but anyhow, that's just my opinion.
Thanks again for all the info.
Jim P.
jproffer is offline
