Frozen Vent??? - Plumbing - Contractor Talk
Frozen Vent???
Old 01-23-2014, 09:23 AM   #1
ABLE1's Avatar
Rewards Points: 1,296
Frozen Vent???
Hello all,
The temps are in the single digits and my vent stack is frozen to the point that when the toilet is flushed it gurgles the tub drain and empties the trap.
Anyone in here know how this can happen and how to correct for future. BTW the vent pipe goes up an outside wall to the roof.
Also anyone have hint as to what could be a quick fix??
Thanks,
Les
ABLE1
ABLE1 is offline
Old 01-23-2014, 09:42 AM   #2
muskoka guy's Avatar
Trade: framer/builder
Rewards Points: 558
Re: Frozen Vent???
Had this happen on a house I used to live in. Went up on the roof and broke the thin layer of ice out of the vent stack where it came out of the roof. It was frozen right at the snow line, about two feet above the roof. I used a broom and stuck it down the vent pipe. It happened twice in the five years I lived in the house. Not sure why it happened. I don't know if you were to glue a 90 degree elbow on the top if it would help or not. good luck.
muskoka guy is offline
Old 01-23-2014, 09:54 AM   #3
ABLE1's Avatar
Re: Frozen Vent???
Thanks for the possible fix. Not sure I am in the mood to climb up on my snow covered roof. Although that might be the on solution.
The snow that we got is only about 7" and the stack is about 12". But I can see a bit of snow on the top of the pipe.
How thick was the "thin layer" you experienced??
Thanks,
Les
ABLE1
ABLE1 is offline
Old 01-23-2014, 10:05 AM   #4
Rewards Points: 558
Re: Frozen Vent???
It was maybe a heavy 1/8 inch. Enough to stop air coming down the stack apparently. What made me notice was the smell in the house. Once the vent was blocked, it would just suck air down the nearest trap, which sucks the water out as well. That why you are getting the gurgling. Once it sucks the water out of the p trap, you will get sewer gases into the house. Very unhealthy.
Old 01-23-2014, 11:00 AM   #5
ABLE1's Avatar
Re: Frozen Vent???
Interesting!!!
Then a well aimed garden hose with hot water could melt the ice dam. Certainly can't make it any worse.
New flushing procedure in the house.
Flush, wait till final gurgle, open faucet in tub for 10 seconds, close, and go on with life.
I really hate the winter.
Les
ABLE1
ABLE1 is offline
Old 01-23-2014, 12:15 PM   #6
Gene S.'s Avatar
Trade: Plumbing, HVAC
Re: Frozen Vent???
Its called "frost-over" here. Code requires at least on of the vents thru the roof be at least 3" diameter to help combat this. I have seen it happen to 3" pipe but not very often. Check yer size
Gene S. is offline
Old 01-23-2014, 12:48 PM   #7
ABLE1's Avatar
Re: Frozen Vent???
The size is 1-1/2". House is 35 years old or so. Would it make a difference to place a 3" to 1-1/2" reducer on top for future on would it just compound or amplify the issue??
The other option would be to place 2 ea. 90's on top to get the opening down. But based on your thought of "frost over" I am wondering if that would make a difference.
Current weather is to be below freezing for the next 2 weeks at least.
As for my hot garden hose thought................. well was just a thought until after I looked at the frozen garden hose and trying to determine how long it was going to take to thawl it out.
Les
ABLE1
ABLE1 is offline
Old 01-23-2014, 01:00 PM   #8
stacker of sticks
jlsconstruction's Avatar
Rewards Points: 590
Re: Frozen Vent???
Here all they want is 3" through the roof. I couldn't believe that when the bi told me that. It was on a remodel and it had a 2" and he told me to go in the attic and cut it and put 3" through the roof
jlsconstruction is offline
Old 01-23-2014, 01:04 PM   #9
ABLE1's Avatar
Re: Frozen Vent???
Yea, those guys can really fry your shorts some days.................
ABLE1
ABLE1 is offline
Old 01-23-2014, 01:04 PM   #10
Gene S.'s Avatar
Re: Frozen Vent???
The 1 1/2" vent should be cut back at least 12" below the roof deck and then reducer then go at least 18" above the roof with 3" (Section 904 in the IPC). The 2 90's wont work and will actually frost over faster
Gene S. is offline
Old 01-23-2014, 01:10 PM   #11
Gene S.'s Avatar
Re: Frozen Vent???
The NYS Plumbing code book calls for all vents that go outside the roof be 3" but here in WNY we see a lot of smaller vents thru roofs as long as the stack vent is 3".
Gene S. is offline
Old 01-23-2014, 01:14 PM   #12
Brian Peters's Avatar
Trade: remodeling and some new construction
Rewards Points: 972
Re: Frozen Vent???
We re-roofed a house once, I noticed the vent pipes all had a yellow plug in them ,apparently from when the plumber did a pressure test? I went ahead and took them out, always wondered if they noticed a difference.
Brian Peters is offline
The Following User Says Thank You to Brian Peters For This Useful Post:
jlsconstruction (01-23-2014)
Old 01-23-2014, 01:23 PM   #13
stacker of sticks
Rewards Points: 590
Re: Frozen Vent???
Are you licensed in Rochester by any chance?
Old 01-23-2014, 01:25 PM   #14
ABLE1's Avatar
Re: Frozen Vent???
LOL My guess is that they noticed but did not have a clue why.
ABLE1
ABLE1 is offline
Old 01-23-2014, 01:28 PM   #15
ABLE1's Avatar
Re: Frozen Vent???
I have lived in this house since new. Never had this happen before. Now that it has and I know the cause and the temp fix not sure I will be making any serious changes anytime soon.
I do have a quick solution but won't mention it here since it will violate every plumbing code this side of the Mississippi and beyond.
Les
ABLE1
ABLE1 is offline
Old 01-23-2014, 02:31 PM   #16
Gene S.'s Avatar
Re: Frozen Vent???
All my licenses are in Buffalo and the surrounding areas. Not Rochester but Rochester falls under the same NYS plumbing code which is based on the IPC.
Gene S. is offline
Old 01-23-2014, 02:38 PM   #17
Gene S.'s Avatar
Cool
Re: Frozen Vent???
Les
That smells kinda fishy
Gene S. is offline
Old 01-23-2014, 02:42 PM   #18
ABLE1's Avatar
Re: Frozen Vent???
LOL you may be on the right pathway...................
ABLE1
ABLE1 is offline
Old 01-23-2014, 03:26 PM   #19
ABLE1's Avatar
Re: Frozen Vent???
Didn't smell any fishes but the little fishy worked like a champ!!!
ABLE1
ABLE1 is offline
Old 01-23-2014, 04:20 PM   #20
stacker of sticks
Rewards Points: 590
Re: Frozen Vent???
I was just wondering, I'm from auburn and they will accept Rochester licenses.
Major Water Condensation in Furnace Flue Vent in Attic - Drywall Damage seaweed HVAC 11 01-13-2014 08:51 PM
Barn Water Heater - line frozen artinall Plumbing 16 01-23-2013 09:51 PM
Ridge Vent advice power Roofing 12 01-22-2013 09:55 AM
seal gable vents after ridge vent installed? tacoma5050 Roofing 41 06-07-2012 07:32 PM
Question about vent work licensed-trim Finish Carpentry 9 03-06-2010 01:37 AM
