Foam Bottomed Tub Is Noisy When Stepping In. - Plumbing - Contractor Talk
Old 01-27-2019, 11:12 AM   #1
diplomat
Golden view's Avatar
Rewards Points: 1,550
I have a tub in a remodel I did that's surprisingly noisy/creaky when stepped in. It's one of those with a foam/felt support underneath an the instructions specifically say it doesn't need a mortar base or anything under it. I probably should have though.
Any thoughts how to quiet this thing down? I can remove drywall from the back if needed. Maybe drill through the foam and somehow inject mortar? Try to carve out much of the foam and spray new foam under there?
Tub is porcelain on steel.
Golden view is offline
Old 01-27-2019, 11:17 AM   #2
rrk's Avatar
Rewards Points: 4,850
Re: Foam Bottomed Tub Is Noisy When Stepping In.
Plumber told me a trick he used on rentals, slip 30lb tarpaper under tub.
Unless creak is coming from upper tub lip the you are screwed
rrk is offline
Golden view (01-27-2019)
Old 01-27-2019, 11:18 AM   #3
John the Builder
SmallTownGuy's Avatar
Rewards Points: 6,114
SmallTownGuy is offline
The Following User Says Thank You to SmallTownGuy For This Useful Post:
Old 01-27-2019, 11:20 AM   #4
hdavis's Avatar
Rewards Points: 1,118
Is it the cast rubbing on the floor? Foam/floor flexing?
If it's loud, I'd think it's the edge of the cast against the floor.
hdavis is online now
Old 01-27-2019, 11:23 AM   #5
diplomat
There's about an inch of foam under the steel.
hdavis (01-27-2019)
Old 01-27-2019, 11:30 AM   #6
Remodeling GC
kevjob's Avatar
Rewards Points: 412
Can you drill through floor below and foam from under it? I have used plastic tubing to extend the tip of foam gun for more reach.
I had one of those tubs and we ended up pulling after installing it as it creaked and setting it in non shrink grout which we do on all tubs and pans.
kevjob is offline
The Following 2 Users Say Thank You to kevjob For This Useful Post:
overanalyze (01-27-2019), Tom M (01-27-2019)
Old 01-27-2019, 11:36 AM   #7
John the Builder
God, I hated those wretched tubs.
IRC, one time drilled holes thru subfloor every few inches and blew a full can of silicone or Lemon Pledge all along the way.
Back then, Lemon Pledge was my go to for just about everything that moved or squeaked, so I'm guessing that.
In any case, next time have turd herder put a piece of tarpaper or tyvek down.
And then stop using those sh!tty tubs.
The Following 3 Users Say Thank You to SmallTownGuy For This Useful Post:
Golden view (01-27-2019), hdavis (01-27-2019), MarkJames (01-27-2019)
Old 01-27-2019, 12:27 PM   #8
hdavis's Avatar
I'd probably try slipping tyvek under it using some sheet steel. Don't know if it would work, though. Obviously a big factor is the finish work repairs.
Old 01-27-2019, 01:31 PM   #9
avenge's Avatar
Rewards Points: 298
Think I would remove the drywall have someone step in the tub and find out where the squeak is coming from before doing anything.
avenge is offline
The Following User Says Thank You to avenge For This Useful Post:
Old 01-27-2019, 01:55 PM   #10
Tom M's Avatar
Rewards Points: 11,152
It could be the ledger if you used one.
I had one with a terrible squeak,. When the customer showed me I was a little pissed off as if what now......
Gave the side of the tub of rap with my leg and squeak when away. . I think the mud job and tile floor pinched the apron a bit I was causing it to react. That was the end of it
Tom M is online now
Old 01-27-2019, 02:07 PM   #11
tjbnwi's Avatar
Rewards Points: 3,988
Originally Posted by SmallTownGuy View Post
I prefer gasoline, it works so much faster. Used to be fun to send the new guy out to get you a cup of gas and hand him a styrofoam cup.
tjbnwi is online now
The Following 3 Users Say Thank You to tjbnwi For This Useful Post:
overanalyze (01-27-2019), SmallTownGuy (01-27-2019), Xtrememtnbiker (01-27-2019)
Old 01-27-2019, 03:50 PM   #12
Mike-B's Avatar
Rewards Points: 1,234
I found that out by mistake in my younger days. I drained the float bowl of a carburetor into a styrofoam cup and the bottom half disappeared before the bowl was drained.
Mike-B is online now
Old 01-27-2019, 04:06 PM   #13
John the Builder
So here's the deal from back when I was a teen:
Then, every gal carried nail polish and remover.
1. Find a victim. A Guy with a good crop of zits was preferred.
2. Get a fresh cig, strip the filter out and place in said victim's palm.
3. Very quickly, pour some polish remover on filter, close their palm, then tell them to close their eyes, and say sex 3 times and shake their fist vigorously, then open it.
Old 01-27-2019, 09:26 PM   #14
MarkJames's Avatar
Rewards Points: 18,889
Those tubs sVck. For lightweight tubs, try the AS ones with the composite underside next time...much more solid.
It could be that foam base kept the apron from contacting the subfloor evenly...or the ledger is moving. You might need to pull a couple floor tiles to get some shims under the apron, as well as spray foam the heck out of it underneath.
MarkJames is online now
Old 01-30-2019, 06:32 PM   #15
diplomat
This IS an American Standard tub. Maybe exactly what you're talking about. Porcelain on steel.
Funny thing is another remodel I'm in the middle of got the same problem. Just yesterday I removed and reset the tub in a mortar base to fix the problem. I'll be doing that from now on.
Still not sure how to best deal with the other one that's in a completed project.
Old 01-30-2019, 06:51 PM   #16
MarkJames's Avatar
The enamel over steel is junk, and I feel your pain (been through it). But they have one with a composite base that's way more solid, yet light. I just saw one in a HfH "Restore" and took note that it existed.
rrk (01-30-2019)
Old 01-30-2019, 07:32 PM   #17
Remodeling GC
kevjob's Avatar
Rewards Points: 412
Americast Princeton tub is probably the one your thinking of. Always set them in mortar.
kevjob is offline
The Following User Says Thank You to kevjob For This Useful Post:
MarkJames (01-30-2019)
Old 01-30-2019, 08:15 PM   #18
diplomat
Yes, I believe that's what it is. Instructions say 1/4" beads of silicone. That's what the plumber did and it didn't work. The mortar did. They have two models. One has the base, the other doesn't. The one without the base says you can bed it, but you don't have to.
I guess I need to read instructions, since my subs don't.
Old 01-30-2019, 09:15 PM   #19
rrk's Avatar
We always use the one without the base and never bed it, but a day after setting it I always stand on the edges to make sure of no movements
rrk is offline
Golden view (01-31-2019)
Old 03-23-2019, 10:28 PM   #20
diplomat
Revisiting this to report back.
Drilled about 10 1/2" holes through the foam at the bottom, then attached 1/4" pex as an extension to my foam gun and filled all those holes, presuming it would expand under the tub and fill most of the space.
Completely solved the problem, from an access "slot" no taller than the base trim on the adjacent wall.
The Following 4 Users Say Thank You to Golden view For This Useful Post:
asevereid (03-25-2019), hdavis (03-24-2019), Tinstaafl (03-24-2019), Xtrememtnbiker (03-23-2019)
Spray Foam not adhering to concrete basement wall... Paint & Hammer General Discussion 6 11-04-2012 01:39 PM
progressive foam vs foam clad siding contractorjay Windows, Siding and Doors 15 10-25-2012 08:03 AM
foam insulation question phnola Construction 3 05-01-2011 09:56 AM
the great debate, foam rain screen woodworkbykirk Windows, Siding and Doors 8 09-13-2010 07:54 PM
Spray foam under a slab for insulation -- Mike Finley Construction 22 01-10-2010 02:39 PM
