Flexible Fittings - Plumbing - Contractor Talk
Flexible Fittings
Old 03-21-2009, 08:55 PM   #1
sir plums alot
ChieffyWeefy's Avatar
Trade: Plumbing apprentice
Flexible Fittings
When installing drainage pipe, can I legally (in Canada) use the rubber flexible fittings to get the grade in pipe i'll need for drainage or do I have to stay with the pvc fittings..
ChieffyWeefy is offline
Old 03-28-2009, 11:58 AM   #2
Pro Plumber
Ron The Plumber's Avatar
Trade: Plumber
Rewards Points: 2,000
Re: Flexible Fittings
Are you asking about the use of fernco's, post a picture of what your talking about.
Ron The Plumber is offline
Old 03-31-2009, 07:04 AM   #3
sir plums alot
Sorry for the late reply Ron. I had asked around here, and I found that I can use flexible fittings for what I was thinking, thanks...
Kitec attached directly to copper pipe? No fittings A.D. Const Plumbing 29 03-31-2009 07:26 AM
Pre-calculate DWV pipe lengths between fittings? bob_cntrctr Plumbing 1 01-20-2009 01:08 PM
Question: Stainless Steel Pipe Fittings and Valves jasonltsp Plumbing 0 01-06-2009 02:42 PM
Flexible Black Poly Tube and ABS Fittings? theworx Plumbing 2 05-22-2006 11:49 PM
