Easy, Toilet Replacement - Plumbing - Contractor Talk
Old 05-08-2011, 08:24 PM   #1
fireguy's Avatar
Trade: Fire Suppression Equipment Sales & Service
Rewards Points: 324
Ever notice how the other trades always look so easy? Yesterdays project was to replace the main floor toilet. I bought a toilet a couple of weeks ago. My new toilet had a rough in of 12 inches. The existing toilet is 10 inches. No problem. Today, I went off to the store, get a 10" rough in toilet. The brass bolts had bad threads, & I used vise grips to break the old bolts. I put the new bolts in. My house was built in 1890, the toilet flange is lead and there are no holes for the bolts. The wood around the hole is not going to hold a lag thread. The only way I can figure to hold the toilet to the floor is to use redi-bolt, cut long enough to go through the floor and a piece of wood or uni-strut across the bottom of the floor joists. I will need to do this on both sides of the toilet. I do not have any 1/4 redi-bolt and though I may have 5/16 redi-bolt, I do not have any 5/16 brass nuts. Although that should not be a problem, as I do not expect to ever replace the toilet again. I will be dead before the toilet needs to come up again.
Do you real plumbers have any other suggestions?
fireguy is offline
Old 05-08-2011, 08:54 PM   #2
The Grand Wazoo
KillerToiletSpider's Avatar
Rewards Points: 2,036
Re: Easy, Toilet Replacement
Replace the floor.
I may be going to hell in a bucket, but at least I'm enjoying the ride.
KillerToiletSpider is offline
Old 05-08-2011, 09:29 PM   #3
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,024
Originally Posted by KillerToiletSpider View Post
Replace the floor.
Ah, so that's how plumbers make it look so easy. :wise nod:
Tinstaafl is offline
Old 05-08-2011, 11:05 PM   #4
The Grand Wazoo
It is impossible to convey sarcasm here.
Old 05-09-2011, 05:50 AM   #5
Capra aegagrus
Tinstaafl's Avatar
Au contraire, you do it quite well.
Old 05-09-2011, 06:31 AM   #6
doncando's Avatar
Trade: carpentry and painting
Rewards Points: 25
There is a toilet repair flange that may work. It's just a flat flange with several holes to secure it to the floor. If you can't this repair flange to work, you may have to repair the floor or possibly even forego the flange bolts.
I regard the the flange bolts as secondary to the toilet sitting flat and secure on the floor.
P.S. I am not a plumber
doncando is offline
Old 05-09-2011, 10:07 AM   #7
Mike's Plumbing's Avatar
Trade: ooo
Rewards Points: 2,000
It's not that it's easy for us, it's just that we are fully equipped. To give you an example of the parts I carry I'll run through some numbers. On my truck, just for toilets, I carry about $500 worth of different flappers, $500 worth of flush valve parts including seals, about 300 worth of handles, ballcocks out the wazoo, hundreds of dollars in tank to bowl parts dating back to the first commercially available toilets, and a 300 pound bin of every other miscellaneous parts known to man. So this riht there allows me to fix and repair any toilet I come accross. For fastening the toilet down I must have hundreds of dollars worth of different flanges I stock. They make flange parts you have never seen or heard of before.
Anyhow, the real value is having this available on the truck at all times so when I get a call I walk in a fix it in minutes. This gives the impression it's easy.....and it is rather easy I guess, but in you shoes it's different because you have no inventory so you have to start from zero.
Mike
see ya!
Mike's Plumbing is offline
Old 05-09-2011, 06:41 PM   #8
Capra aegagrus
Tinstaafl's Avatar
You know Mike... I'm going to tell you something that's been said to me far too many times.
You're irritating because you're right so often.
Old 05-09-2011, 07:02 PM   #9
Project Manager
CookeCarpentry's Avatar
Trade: Project Manager
Rewards Points: 2,016
I find him irritating because he doesn't look and talk like his avatar photo....
CookeCarpentry is offline
Old 05-09-2011, 07:44 PM   #10
MikeGC's Avatar
Trade: All construction, remodeling, home improvements
Location: Rochester, NY Elmira, NY, WNY, Finger Lakes, Southern Tier
Rewards Points: 510
Shove one of these in there, twist it until its tight and screw it down.
MikeGC is offline
Old 05-09-2011, 07:55 PM   #11
The Grand Wazoo
I would not use one of those on a lead closet bend.
The Following User Says Thank You to KillerToiletSpider For This Useful Post:
Mike's Plumbing (05-09-2011)
Old 05-09-2011, 08:47 PM   #12
MikeGC's Avatar
Rewards Points: 510
Why?
MikeGC is offline
Old 05-09-2011, 08:53 PM   #13
Trade: ooo
So everybody finds me irritating, well that's nice. Maybe I'll just go hang out on the Oprah Winfrey forum.
BTW: The plastic expansion closet flange is a bad idea. That's doesn't do a very good job of holding a toilet down. Just because they make something doesn't mean we should use it.
Drive 2 hangar bolts in the floor and bolt the SOB down. Chuck it in a cordless drill and drive them home. Easy as pie.
Mike
see ya!
Old 05-09-2011, 09:11 PM   #14
The Grand Wazoo
Why?
Because fixing cracked sheet lead in place is a pain in the ass.
Old 05-09-2011, 09:22 PM   #15
MikeGC's Avatar
Rewards Points: 510
I have used them a few times over the past 15+ years including at my own house and a few of my older rentals where the flange had no slot for the bolts. Never had a problem and Id do it again.
MikeGC is offline
Old 05-09-2011, 09:29 PM   #16
The Grand Wazoo
I'm happy for you.
Old 05-09-2011, 09:33 PM   #17
Trade: ooo
Sweet, products like this keep us plumbers busy. Please keep installing these.
see ya!
Old 05-10-2011, 08:27 PM   #18
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 1,856
Mike
I wanna see pics of your service van someday!!
Mike's Plumbing (05-10-2011)
Old 05-10-2011, 10:03 PM   #19
Trade: ooo
Sure, I have her really gutted right now and I worked on it all day. I decided to put all my tools on the drivers side, passenger side will have toilet and sink repair parts etc, and the inside of the cube will be all parts and pipe etc.
I had to do a service call today and I was bare bones, made me pretty nervous but I got done thankfully.
If I have it too gutted out I could really screw myself but so far so good.
Mike
see ya!
Old 05-10-2011, 10:06 PM   #20
New Quirky Carpenter
William James's Avatar
Trade: Trim Carpentry and Remodeling
Rewards Points: 538
Mike
Not all plumbers are as proactive as you Mike. I knew one guy, every job he had to run to the store for something. A fernco, ABS pipe, some fitting... Almost every small/quick job became a 2-3 hour job.
Guilford, CT Remodeler and Carpenter Web-site [email protected]
Facebook
The great use of life is to spend it for something that will outlast it.
William James is offline
Giveaway of the Day - Easy Flyer Creator Celtic Marketing & Sales 4 09-21-2009 11:34 PM
Replace toilet? VAviaCo Plumbing 5 05-18-2009 09:05 AM
New toilet plumbing MICHAEL55 Off Topic (Non Trade) 13 05-15-2009 06:26 AM
Venting for toilet dillema fumbrunner Plumbing 12 11-18-2008 01:06 AM
Toilet problem Mike Finley Plumbing 5 11-06-2007 10:21 AM
