Does A Toilet Have To Be Vented Per Code? - Plumbing - Contractor Talk
Old 03-23-2019, 10:16 AM   #1
rjconstructs's Avatar
Trade: Residential remodel
Rewards Points: 302
I'm not a plumber but I might play one on my house.
I'm considering a half bath off my kitchen. I was told venting a half bath toilet was not necessary. I am wondering if it might be required by code... but to function, no. Thoughts or advice?
rjconstructs is offline
Old 03-23-2019, 10:28 AM   #2
MarkJames's Avatar
Rewards Points: 18,987
Re: Does A Toilet Have To Be Vented Per Code?
How far away is the stack?
MarkJames is online now
hdavis (03-23-2019)
Old 03-23-2019, 12:59 PM   #3
Rewards Points: 302
No stack. No plumbing there now, its just a nook off the kitchen
Old 03-23-2019, 01:20 PM   #4
MarkJames's Avatar
Where does the kitchen drain go?
Unless you're dead in the water, workwise, I would suggest biting the bullet to have a plumber rough it in, and maybe the supply, too. Then do the rest of the work at your leisure.
Old 03-23-2019, 06:13 PM   #5
Caleb1989's Avatar
Rewards Points: 394
Yes, the half bath needs venting. If you put your thumb over a straw in a glass of water, then lift it straight up, what happens? Plumbing drains need air to balance the air pressure and “chase” the waste. Otherwise you will get glugging, sucking air through the P traps and potentially allowing sewer gas to enter the home if the P traps aren’t full of water.
Just plan it all out
Caleb1989 is offline
Old 03-23-2019, 06:52 PM   #6
nickko's Avatar
Trade: remodeling-cabinet maker
Rewards Points: 845
I think you can us an auto vent in the wall but you have to use a removable panel so there is access to it.
I saw a picture of one once and it was low to the floor close to the toilet behind one of those plastic removable panels.
Nicks.
"Quality work for those who know the difference"
nickko is offline
Old 03-23-2019, 07:01 PM   #7
diplomat
Golden view's Avatar
Rewards Points: 1,550
AAV is a code compliant option in many (most?) places now.
Golden view is offline
Old 03-23-2019, 07:32 PM   #8
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 4,192
Toilets don’t have to be but the sink will.
Big Johnson is online now
Old 03-23-2019, 07:52 PM   #9
tjbnwi's Avatar
Rewards Points: 4,060
No problem then, no sink, just use the kitchen sink....
tjbnwi is online now
Old 03-23-2019, 09:22 PM   #10
The Grand Wazoo
KillerToiletSpider's Avatar
Rewards Points: 2,036
Just put a 5 gallon bucket in there, saves the cost of pipe...
I may be going to hell in a bucket, but at least I'm enjoying the ride.
KillerToiletSpider is offline
The Following 2 Users Say Thank You to KillerToiletSpider For This Useful Post:
jhark123 (03-26-2019), TNTRenovate (03-26-2019)
Old 03-25-2019, 11:04 PM   #11
HubbaBubba's Avatar
Trade: General
Rewards Points: 30
I think there is a six foot rule, toilet and sink within six feet of each other and you can use the sink vent as a wet vent for the toilet.
HubbaBubba is offline
Old 03-26-2019, 07:41 PM   #12
Rewards Points: 302
thanks bubba
Old 03-26-2019, 08:44 PM   #13
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 1,594
Uh.....Not exactly.
It's not the sink vent, it's a combination drain/vent called a wet vent.
RJ, the Code states that all traps must be vented. A Water Closet has an integral trap, therefore, it must be vented.
There is such a thing as a wet vent. I don't know what Code you use, but If it's the CPC/UPC, look at 908.2.
Old 03-26-2019, 08:55 PM   #14
Plumbers don’t vent toilets here. IPC doesn’t require one.
Old 03-26-2019, 08:57 PM   #15
Trade: Highwayman
For real?
And they flush and everything?
Old 03-26-2019, 08:59 PM   #16
Trade: Highwayman
I know the IPC lets you discharge the drain from the T&P valve into the Smitty pan.
A change I wish we would get in the UPC.
Doesn't make any sense to me why we can't.
Old 03-26-2019, 09:03 PM   #17
Originally Posted by Seven-Delta-FortyOne View Post
For real?
2015 International Plumbing Code
909.1Distance of trap from vent.
Each fixture trap shall have a protecting vent located so that the slope and the developed length in the fixture drain from the trap weir to the vent fitting are within the requirements set forth in Table 909.1.
Exception: The developed length of the fixture drain from the trap weir to the vent fitting for self-siphoning fixtures, such as water closets, shall not be limited.
Seven-Delta-FortyOne (03-26-2019)
Old 03-26-2019, 09:51 PM   #18
Trade: Highwayman
So they are vented, there is just no limit to how far away?
Old 03-26-2019, 10:32 PM   #19
Basically as long as there’s a vent somewhere in the house you’re covered as far as toilets go. Since all the other fixtures have to be vented, plumbers under IPC never provide a vent specifically for toilets.
The Following 4 Users Say Thank You to Big Johnson For This Useful Post:
MarkJames (03-27-2019), rjconstructs (03-27-2019), Seven-Delta-FortyOne (03-27-2019), Sisyphus (03-28-2019)
Old 03-30-2019, 03:05 AM   #20
UFGator2212's Avatar
Trade: Plumbing
Rewards Points: 6
Where are you people coming up with plumbers don’t vent toilets. You must not understand venting at all but all toilets are vented. Just because there is not a vent stack beside every fixture does not mean it is not vented you have 8’ to play with and many fixtures are vented off of one stack which in many cases is the one stack you see your lav ties into. I’m like the other guy and wanna know what code you all go by if you don’t vent toilets.
UFGator2212 is offline
Subfloor sag under toilet George_Pag General Discussion 18 12-20-2018 08:47 PM
Used toilet refund Chenyi General Discussion 17 12-16-2016 09:33 AM
Caulk around toilet code Paulie Plumbing 61 10-24-2011 08:07 AM
MA Code, and vented Soffit Patrick General Discussion 14 04-30-2008 09:44 PM
Toilet Challenge Vermaraj Plumbing 40 11-09-2007 09:04 PM
