Delta Shower Fixtures - Plumbing - Contractor Talk
Old 04-10-2019, 07:34 PM   #1
FloorsByAlex's Avatar
Trade: Flooring
Rewards Points: 128
I'm building a shower for a client. I have experience with plumbing a basic shower setup with a few peripherals...
The setup is, delta multichoice mv, delta 3-6 diverter, 2x delta body sprays, standard type delta shower head as well as a 12" rainhead, and a handheld wand.
I have a 2 part question.
1st pertaining to the body sprays, since there is only two, should I loop them together or just T off to them with equal sized leads. I heard of pressure issues with 3 or more. But no diagrams when just using 2.
Secondly, my client is not being helpful with choosing what to run simultaneously. My diverter will allow 3 functions of 2 fixtures at the same time. What would be a "common" setup. Like. Rainhead+body spray or shower+wand...etc.
Any help is much appreciated.
FloorsByAlex is offline
Old 04-10-2019, 08:01 PM   #2
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 1,002
Re: Delta Shower Fixtures
You running 3/4” feeds for that setup?
overanalyze is offline
Old 04-10-2019, 08:10 PM   #3
Trade: Flooring
Rewards Points: 128
It only has 1/2 there now.
The 3/4 mains are under a new floor about 5 feet away.
Can I just convert it to 3/4 where it comes through the wall plate or is that pointless. I know keeping it 1/2 water flow will be terrible.
Old 04-10-2019, 08:27 PM   #4
Trade: Flooring
Rewards Points: 128
A follow up question to that. Is it best to stay with 3/4 for the whole install, or is is safe to use 1/2 after the mv or diverter.
Old 04-10-2019, 09:01 PM   #5
Hair Splitter
TNTRenovate's Avatar
Trade: General
Rewards Points: 1,244
Uh, no. The purpose is to go back to 3/4 for volume required by those devices. You need to go back to 3/4. But it's Delta, throw it in the garbage and go with Moen.
Tried & True on Facebook
Tried & True Website
TNTRenovate is offline
Old 04-10-2019, 09:09 PM   #6
Trade: Flooring
Rewards Points: 128
Thanks for that. I appreciate the feedback. Do you think it would be fine if I were to just convert it to 3/4 just above the floor plate? The branches to the mains are only about 5 feet long of 1/2" under the floor. The floor is new, and it Is almost inaccessible from below.
As far as swapping for moen. I wish lol. Not my choice. Customer special ordered everything.
Old 04-10-2019, 09:27 PM   #7
Hair Splitter
Trade: General
No, you need no flow reduction between the 3/4 and valves.
Old 04-10-2019, 11:56 PM   #8
tjbnwi's Avatar
Rewards Points: 558
Go 3/4 to the mixing valve, you may need 2-2" drains and lines....
Loop the sprays, easy enough do.
tjbnwi is online now
overanalyze (04-11-2019)
Old 04-11-2019, 08:13 PM   #9
Always Learning
You have to go 3/4" back to the 3/4" main off the water heater and main cold feed. Latest bath remodel had 4 3/4" lines feeding the shower valves.
Old 06-16-2019, 08:16 AM   #10
Porterfarm's Avatar
Trade: Handyman/ Home Improvement Contractor
Rewards Points: 12
Why is everything "Low flow" and my kitchen sink takes ten minutes to fill a pasta pot or dog bowl? My bathroom sink now too since I had to change the faucet....bargain $90 unit.....the kind real people have to buy.
Municipalities require low flow but you can get away with "two 3/4" water feeds" to a shower...….blows my mind.
I did a bathroom a few years ago for one of my customers. Who complained about the cost of everything. She needed two bathrooms remodeled. She purchased the regular Simmons tub/s shower control, complaining how expensive it was, a buck fifty?
She ended up getting a Maxx shower, and a separate Maxx tub. and configured it all to fit. I went over to install the shower control, and low and behold, she had this picked up new Moen stuff, two body sprays, wand, and a over head rain head......….I told her she was going to drown. She hasn't and loves it. I call that bathroom a water park.
but again I can't seem to get that question answered...with water restrictions how?
Thanks sorry for venting:
Sorry
Porterfarm is online now
Old 06-16-2019, 04:46 PM   #11
tjbnwi's Avatar
Rewards Points: 558
Last one I did was code limited to 9 GPM.
Old 06-24-2019, 05:36 PM   #12
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 15,659
Personally, the 2.8 low flow stuff works just fine for me nowadays. And when a shower head is old and clogged, it's time to clear debris or replace it. No biggie.
MarkJames is offline
Weird Pressure change in shower when flushing toilet Morning Wood Plumbing 10 03-30-2016 08:16 AM
Difficult to find shower leak CharlieM Tiling 36 07-18-2015 11:56 PM
Tiling inside a neoangle shower Cmac9000 Tiling 2 03-04-2014 09:04 AM
