Delta Shower Cartridge - Plumbing - Contractor Talk
Old 06-01-2020, 04:09 PM   #1
sliver's Avatar
Trade: handyman
Rewards Points: 276
New customer asks me to repair a leaking shower head in a late 90's rental a few blocks from my house. I replace the spring washers no change in the drip. I attempt to replace the cartridge but it will not seat the last 1/8" or so. Put old cartridge back in.
Emailed Delta with a photo of the old and new Danco cartridge on the 22nd and no reply other than a standard "do not reply to this email". After forty minutes on hold, a rep says that the they changed the design of the cartridge in 2006 and that I needed #10347. I told him that I have the Danco equivalent.
Do I purchase the cartridge that is not supposed to work (the newer version) and try it again or.......
sliver is offline
Old 06-03-2020, 07:32 PM   #2
paul100's Avatar
Rewards Points: 62
Re: Delta Shower Cartridge
Doesn't Delta have a lifetime warranty?
paul100 is offline
Old 06-03-2020, 07:42 PM   #3
Fire up the BBQ
griz's Avatar
Rewards Points: 2,462
i can't recall all the delta cartridge stuff but your description of won't quite go in, sounds like maybe you do not have the cartridge lined up right.
is there a little plastic tab on the cartridge that will line up with a notch in the valve body?...allowing it to go all the way in.
why not buy the proper part from delta?
griz is online now
Old 06-03-2020, 08:44 PM   #4
MarkJames's Avatar
Rewards Points: 19,505
Yup, many offer lifetime warranty to the original purchaser. They will ask if it's for them....
MarkJames is offline
Old 06-03-2020, 09:18 PM   #5
dsconstructs's Avatar
Trade: Remodel Contractor
Rewards Points: 876
Those cartridges do have tabs that line up with notches. Typically there's a bit of resistance as the O rings seat,about that last 1/8". I have put the newer cartridges in older valve body without issue.
dsconstructs is offline
Old 06-03-2020, 09:22 PM   #6
tgeb's Avatar
Rewards Points: 1,060
Could be an part of the old valve that did not come out with the rest of it.
An o-ring lodged in the housing can be an issue.
www.gebcon.com
tgeb is offline
Old 06-04-2020, 11:54 AM   #7
rescraft's Avatar
Trade: residential remodeling/construction
Rewards Points: 1,987
Are you lubing up the new o-rings with silicone plumber's grease?
rescraft is online now
Old 06-04-2020, 06:55 PM   #8
sliver's Avatar
Trade: handyman
Rewards Points: 276
Thank you for the replies.
-Not sure about the ownership history of the house.
-I did lube the o-rings.
-The old one went back in so nothing is in the valve body.
-The valve that Delta recommended is the Danco equivalent (#10347) that I attempted to install and still have in my possession.
-There are nubs on each side of the body as seen in photo.
-In the other photo, it reads Hot Side.
sliver is offline
Old 06-04-2020, 07:36 PM   #9
Rewards Points: 876
Think I would get a genuine Delta cartridge. I've had good and bad luck with Danco in the past.
Old 06-06-2020, 05:41 PM   #10
sliver's Avatar
Trade: handyman
Rewards Points: 276
It took two weeks but Delta is sending out a replacement. Maybe they do offer a lifetime warranty?
sliver is offline
Old 06-29-2020, 03:28 PM   #11
sliver's Avatar
Trade: handyman
Rewards Points: 276
The free replacement slipped right into the valve body. Problem solved. Lesson learned. I returned the Danco.
Delta's free replacement policy is great for homeowners that are good with a wrench but not practical for contractors who cannot wait 2-3 weeks for shipping.
sliver is offline
The Following 3 Users Say Thank You to sliver For This Useful Post:
dsconstructs (06-29-2020), MarkJames (06-29-2020), tgeb (06-29-2020)
Old 06-29-2020, 04:19 PM   #12
tjbnwi's Avatar
Rewards Points: 4,764
Thanks for the update, most can’t be bothered. Nice when it happens.
tjbnwi is online now
The Following 3 Users Say Thank You to tjbnwi For This Useful Post:
griz (06-29-2020), MarkJames (06-29-2020), tgeb (06-29-2020)
