Darn Leak. - Plumbing - Contractor Talk
Darn Leak.
Old 11-26-2018, 10:38 PM   #1
tgeb's Avatar
Rewards Points: 920
Darn Leak.
Thanksgiving Thursday we start out with a leak in the kitchen that runs water out onto the hardwood floor.
Looks simple enough, check the basement, appears to be coming from the cold side of the faucet, must be between the cabinet bottom and the flooring. Cut out the CPVC and add in a piece, new valve etc. good to go.
The old pipe looked good though and the floor was drying so figured that was it.
Later the leak reappeared...must be on the hot side, the valve to the washer was clearly leaking, not much but some. Cut that all out and replaced two valves.
Looks like I've got it all dried in.
Next day I'm still getting water on the floor and into the basement....Drain line has to be the issue....
Drain line runs through the wall behind the cabinets, so in I go.
Had to cut out the back of the cabinets, the drywall and find that the pipe is definitely leaking in the area of the 3 wall studs.
I cut the pipe out and see it clearly is the issue. No problem except that the old copper pipe is smaller than the new PVC and I have to make a new larger hole in an old hole....Not much fun. But I managed.
I don't know why this pipe failed but I'm glad I could fix it.
Darn leak.-20181126_103411-1280x960-.jpg   Darn leak.-20181126_110921-1280x960-.jpg   Darn leak.-20181126_143507-1280x960-.jpg
www.gebcon.com
tgeb is online now
The Following 5 Users Say Thank You to tgeb For This Useful Post:
greg24k (11-27-2018), hdavis (11-27-2018), KAP (11-27-2018), SmallTownGuy (11-27-2018), TheConstruct (11-26-2018)
Old 11-26-2018, 10:40 PM   #2
tgeb's Avatar
Rewards Points: 920
Re: Darn Leak.
The final result.
www.gebcon.com
tgeb is online now
The Following User Says Thank You to tgeb For This Useful Post:
Old 11-26-2018, 10:59 PM   #3
TheConstruct's Avatar
Trade: Renovations & Carpentry
Rewards Points: 1,622
Re: Darn Leak.
What a frustrating situation!
TheConstruct is online now
Old 11-27-2018, 11:36 AM   #4
Lettusbee's Avatar
Rewards Points: 1,522
Re: Darn Leak.
Copper drain lines? Haven't seen that in a while.
Lettusbee is online now
Old 11-27-2018, 12:00 PM   #5
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 10,107
Re: Darn Leak.
I've got 30' OF 3" Copper drain in the basement. Actually had a guy tell me I should take it out and trade it in for scrap and replace with PVC. Idiot. Couple bucks traded for tons of labor. I guess his labor is free.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
The Following 2 Users Say Thank You to Leo G For This Useful Post:
hdavis (11-27-2018), tgeb (11-27-2018)
Old 11-27-2018, 12:18 PM   #6
tgeb's Avatar
Rewards Points: 920
Re: Darn Leak.
Yeah, house built in 1965. All the DWV piping is copper till just before going into the concrete slab it changes over to cast iron.
I have a run of copper in my basement also from the back to the front of the house and like you Leo, my copper will stay where it is.
www.gebcon.com
tgeb is online now
Old 11-27-2018, 01:22 PM   #7
hdavis's Avatar
Rewards Points: 1,356
Re: Darn Leak.
I keep copper.
hdavis is online now
Old 11-27-2018, 06:09 PM   #8
Radical Basement Dweller
Robie's Avatar
Rewards Points: 2,982
Re: Darn Leak.
Ditto...1965 or '66...all copper on the drains.
Had the place re-plumbed with pvc supply lines 20 years ago.
“Now is no time to think of what you do not have.
Think of what you can do with what there is”
― Ernest Hemingway, The Old Man and the Sea
Robie is online now
Old 11-27-2018, 06:17 PM   #9
MarkJames's Avatar
Rewards Points: 19,095
Re: Darn Leak.
My folks just had a similar copper in-wall repair. House built in 65ish.
MarkJames is offline
Old 11-27-2018, 07:09 PM   #10
LRG WoodCrafting
Leo G's Avatar
Re: Darn Leak.
Built in '91.
1891 that is. You can see lead plumbing lines in the basement that were fed through the foundation. Not in use obviously. Don't know when the copper went it, but the house has lots of everything. Cast iron, copper, pvc.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 11-27-2018, 10:17 PM   #11
The Grand Wazoo
KillerToiletSpider's Avatar
Rewards Points: 2,036
Re: Darn Leak.
It probably failed from abrasion of the wood expanding and contracting against the pipe over several decades, it's common when the holes are drilled just for the pipe with no clearance. Buildings move, especially in areas with widely varied temperatures.
That being said, if I were to build my own house tomorrow it would be plumbed with hub and spigot cast iron and copper waste and vent...
I may be going to hell in a bucket, but at least I'm enjoying the ride.
KillerToiletSpider is offline
The Following User Says Thank You to KillerToiletSpider For This Useful Post:
tgeb (11-27-2018)
Old 11-27-2018, 10:30 PM   #12
tgeb's Avatar
Rewards Points: 920
Re: Darn Leak.
Once I found the leak and removed the pipe, I thought the same thing, movement over time. The heating and cooling of the pipe daily, sometimes many times a day, as well as seasonal shifting just wore it out where it passed through those 3 wall studs.
It did fit pretty tight.
www.gebcon.com
tgeb is online now
Need help finding a leak! Gary L Roofing 12 01-14-2014 04:28 PM
leak in pex go do it Plumbing 41 10-13-2013 10:22 PM
Do you think this will leak???? stombaugh85 Roofing 14 01-12-2013 08:38 AM
Refrigerant Leak Detection Articles MechAcc HVAC 7 10-09-2009 04:42 AM
