Crazy Drain Job Using Low-heel Inlet Bend - Plumbing - Contractor Talk
Old 02-11-2019, 09:18 AM   #1
hack of all trades
dielectricunion's Avatar
Trade: Electrician
Rewards Points: 2,112
I was working on a residential remodel job (as an electrician) about a week ago and the general contractor and one of his guys decided to run all of the plumbing since the plumber's quote sounded too high.
I was occasionally observing the layout and it kept getting crazier. An existing 3" PVC horizontal waste line and copper lines ran out to the section they were remodeling. The line had an offset of 2-45's as it went from the basement ceiling (to be finished) into a crawl. They cut it there and made a tighter offset using 2-90's (no cleanout).
That line first hit a WC. They used a 3"-1.5" low heel inlet elbow which the ****ter drops directly into.... a horizontal 1.5" comes right out of the back and runs to the lav. The 90 turn into the wall was made using a vent elbow. After the lav, the same vertical has a sanitary tee which picks up a washer standpipe on the other side of the wall! No cleanout points are available on this branch....
The standpipe p-trap reduces fron 2-1.5" right before the trap!!
They also cut out the vent which was right above this room and plan to vent with an AAV in the lav cabinet!
Additionally- on the 3" line in the basement they tied in two 1.5" lines using sanitary tees on their backs and a mixture of quarter bends and vent elbows in getting to the kitchen sink and dishwasher locations.
I wish I had taken some pics. Anyway, I explained all the codes he violated and I said regardless of the fact that no permits were pulled, this looks sketchy enough that it will not function properly. He said they were working with limited space and had to do what they had to do. He acted like he knew the code but I seriously doubt it.
How many months/years would you give this drain line before it presents issues that the homeowner will notice? I've seen a lot of seriously screwed up plumbing that somehow functioned. I told the guy to keep me posted on whether or not this chain of dominoes goes down over the next year!
dielectricunion is offline
Old 02-11-2019, 10:11 AM   #2
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 12,847
Re: Crazy Drain Job Using Low-heel Inlet Bend
Just post a pic next time.
MarkJames is online now
The Following 3 Users Say Thank You to MarkJames For This Useful Post:
B.Johnson (02-11-2019), Rio (02-11-2019), Seven-Delta-FortyOne (02-11-2019)
Old 02-11-2019, 04:20 PM   #3
jhark123's Avatar
Trade: Pro Cat Herder
Rewards Points: 1,692
It's your duty to God and Country to go back and get pics!
jhark123 is offline
The Following 2 Users Say Thank You to jhark123 For This Useful Post:
dielectricunion (02-11-2019), TimNJ (02-12-2019)
Old 02-11-2019, 05:03 PM   #4
Lady Dreamer's Avatar
Trade: Roofing and General Contracting
Rewards Points: 756
Haha!
Lady Dreamer is offline
Washing machine won't drain mroy1991 General Discussion 9 03-13-2017 04:07 PM
Basement floor drain construction gowings Masonry 2 03-29-2015 05:54 PM
crazy stupid timelines. Rich D. Business 21 09-29-2012 07:07 PM
Gurgeling sound in Tub Drain???? painter213 Plumbing 6 06-22-2010 04:11 PM
