Compatible Fittings? - Page 3 - Plumbing - Contractor Talk
Old 04-15-2019, 06:13 PM   #41
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 9,403
Re: Compatible Fittings?
Go big on the pipe, the lower the power needed for set GPM flow....
A little math will tell the trade off between hp cost per year vs. plant/install cost of the different plumbing diameters.
Maybe leave room for larger filters/ upgrades?
Design around the PSI loss of the filter system if it is full flow, Set pump in "well" pit for gravity prime, fewer feet of piping, a piece of 3' or meter sized concrete culvert on end, I'd use large enough for the heater and gas/electric controls all together.
Are you trying to build an exercise pool?
Fouthgeneration is offline
Old 04-15-2019, 09:01 PM   #42
arudam's Avatar
Trade: Paving stone
Im running 2" pipe, many people just run 1.5" but all the newer equipment is coming out with 2" connections now. i dont see a purpose to running any bigger than 2" if you consider for example the restriction at the jet outlet or even the ball valves can already only pass so much water?
Ive purchased the biggest filter possible, oversized by 1/3 to my size, as well as i maxed out my pump size at 3hp just for fun but its a variable speed so i wont be running at max anyways.
I also made my pumphouse only 3 feet from the pool so the plumbing is very minimal as well i added one more return line/jet over what was "standard". the pump house floor is level with the pool deck so very minimal "lift" required by the pump but had i heard of the recessed idea for the pump prior i certainly would have done it.
I built the pool using ICF logix blocks, so having the R value will significantly increase usage time, as well as the wood (plus electric backup) boiler to run the floor heat i figure it should be pretty efficient as well as consistent heat not just the top half will be warm.
And as much as i should exercise, its for the kids lol but i may float around on occasion with a beer or 2
arudam is offline
Old 07-08-2019, 04:32 PM   #43
kloiks's Avatar
Trade: Contracting
Rewards Points: 6
Why pour concrete over plumbing that is GOING to FAIL?
kloiks is offline
Old 07-08-2019, 04:39 PM   #44
arudam's Avatar
Trade: Paving stone
your a little late to the party. when i ask for opinions i give worst case scenarios. i didnt pour concrete over, but i wanted opinions on something that would last as if it was.
To add to how this turned out, its pretty easy to heat and bend the pvc, to do a 90 degree bend it takes a big corner, turned out well
arudam is offline
Old 07-09-2019, 12:51 AM   #45
Trade: Masonry
The vast majority of home owned pools i've been around are only used a few years, mostly during a family's pre-drivers license age of its kids...
the large weekly/monthly labor/$$ costs plus the very large heating costs on uncovered pools leads to shorter seasons then finally the pool getting too septic to swim in..
Keep the dirt and biomatter out of the pool water for cheap operation, cover the pool always when out of use to gain heat /reduce heat loss.
have a shower house very near the water, always use it.
consider special filters for the various skin care greases.
I'd consider salt based pool chemistry instead of chlorine based biocides...
Enjoy the money pit. Keep records and you'll know when to fill it in, or turn it into a cement pond
Old 07-09-2019, 03:36 PM   #46
arudam's Avatar
Trade: Paving stone
Didnt your momma teach you any manners
arudam is offline
Air fittings TempestV Tools & Equipment 8 10-02-2015 07:29 PM
Had a 'duh' moment (pex plumbing and fittings) jproffer Plumbing 7 02-11-2014 06:27 AM
Pex, brass fittings and mineral buildup Anti-wingnut Plumbing 1 03-18-2010 10:56 PM
Kitec attached directly to copper pipe? No fittings A.D. Const Plumbing 29 03-31-2009 07:26 AM
Pre-calculate DWV pipe lengths between fittings? bob_cntrctr Plumbing 1 01-20-2009 01:08 PM
