Compatible Fittings? - Page 2 - Plumbing - Contractor Talk
Old 04-14-2019, 12:32 PM   #21
arudam's Avatar
Trade: Paving stone
Re: Compatible Fittings?
$43 shipping to canada ouch
arudam is offline
Old 04-14-2019, 12:42 PM   #22
VinylHanger's Avatar
Rewards Points: 9,642
I can't imagine a plumbing supply place can't get you what you need?
Either way, you are building a pool and you are worrying about the price? Cheap wont be cheap when you have to dig everything up again.
VinylHanger is offline
Old 04-14-2019, 12:46 PM   #23
arudam's Avatar
Trade: Paving stone
I can do 2 45s together for $4 a corner which is now the plan. ive been told what i want doesnt exist in canada by multiple suppliers, which is why i posted asking about the first fitting. By no means have i cheaped out to as of yet on the pool but im not about to spend almost a grand on elbows that would be plain dumb
arudam is offline
Old 04-14-2019, 01:53 PM   #24
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 8,541
Not schedule 80.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Fouthgeneration (04-15-2019)
Old 04-14-2019, 02:04 PM   #25
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 3,278
Divided by how many fittings?
Big Johnson is offline
Old 04-14-2019, 02:25 PM   #26
arudam's Avatar
Trade: Paving stone
Good call, i just assumed each without thinking. ill check that out thanks
arudam is offline
Old 04-14-2019, 02:39 PM   #27
arudam's Avatar
Trade: Paving stone
that last ebay link is 2.5" also, back to everyone i find in 2" is dwv. and thanks for the help and suggestions so far everyone
arudam is offline
Old 04-14-2019, 03:58 PM   #28
If they have 2.5 they probably have 2 as well.
Old 04-14-2019, 04:21 PM   #29
arudam's Avatar
Trade: Paving stone
i sent them an email! see what they say
arudam is offline
Old 04-14-2019, 08:07 PM   #30
How do they do what you want to do then? If you called a pool installation company, what would they use.
Not being snarky, just curious. If they dont have what you are trying to do, maybe there is a reason?
Old 04-14-2019, 08:13 PM   #31
arudam's Avatar
Trade: Paving stone
Most use the flexible hose, and most pool builders wouldnt care about using a sharp 90. Im building my pool to be as energy efficient as possible, using the most efficient equipment. Its built with insulated concrete forums, even running hydronic floor heat thru a custom made wood boiler. So basically a sharp 90 would work, 2-45s would be better, but a long sweep 90 would IMO kick ass. Not to say it would be worth it in the end but at least i can say i did my best
arudam is offline
The Following User Says Thank You to arudam For This Useful Post:
VinylHanger (04-14-2019)
Old 04-14-2019, 08:18 PM   #32
LRG WoodCrafting
Leo G's Avatar
Fill straight pipe with sand, use a blanket PVC heater and bend it to the radius you want.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 04-14-2019, 08:36 PM   #33
arudam's Avatar
Trade: Paving stone
I kinda like that idea as long as it doesnt take away strength, but really youd think it should be stronger by eliminating a glue joint. I guess the purpose of sand would be to keep the pipe from compressing into the bend?
arudam is offline
Old 04-15-2019, 03:07 PM   #34
arudam's Avatar
Trade: Paving stone
Well the company on the previous ebay link with 2.5" doesnt carry a 2", the other company i found cant tell me the schedule of it because they are a distributor not the manufacturer ( WOW Brutal )
Im going to bend them, found a few great tips on youtube. thanks for all the help and suggestions by everyone!
arudam is offline
Old 04-15-2019, 03:22 PM   #35
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 3,716
Anytime I needed weird PVC fittings I went here:
http://canusplastics.com/materials/tubes/
Inner10 is online now
Old 04-15-2019, 03:39 PM   #36
LRG WoodCrafting
Leo G's Avatar
I win!!
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 04-15-2019, 04:11 PM   #37
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,143
You win until the outside of the bend blows out because it got thinner due to the stretching. :
Tinstaafl is online now
Old 04-15-2019, 04:39 PM   #38
LRG WoodCrafting
Leo G's Avatar
Nope, he loses.
If you do it correctly the outer wall stays the same thickness and the inner wall get fatter. Don't stretch the outer bend, compress the inner bend.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 04-15-2019, 05:05 PM   #39
arudam's Avatar
Trade: Paving stone
you guys fight this out and let me know who wins lol
arudam is offline
Old 04-15-2019, 06:11 PM   #40
Capra aegagrus
Tinstaafl's Avatar
No fighting here, just pointing out potential.
I've heat-bent my share of PVC, but I draw the line if it's getting buried. I want that up to factory specs.
Air fittings TempestV Tools & Equipment 8 10-02-2015 07:29 PM
Had a 'duh' moment (pex plumbing and fittings) jproffer Plumbing 7 02-11-2014 06:27 AM
Pex, brass fittings and mineral buildup Anti-wingnut Plumbing 1 03-18-2010 10:56 PM
Kitec attached directly to copper pipe? No fittings A.D. Const Plumbing 29 03-31-2009 07:26 AM
Pre-calculate DWV pipe lengths between fittings? bob_cntrctr Plumbing 1 01-20-2009 01:08 PM
