Compatible Fittings? - Plumbing - Contractor Talk
Old 04-13-2019, 10:50 AM   #1
arudam's Avatar
Trade: Paving stone
Hey all, Im doing some pool Plumbing for a personal project that I'm building, I'm having a hard time finding 2in PVC Schedule 40 long sweep 90s and I don't want to use standard 90s for obvious flow obstruction reasons. The pump im running is 3hp capable of pumping 180 GPM, My lines will all be buried and concreted over so i need to make sure its done right the first time!
I know i have the option of using 2 - 45s to make the corner , but i was told by a employee at the lumber yard that these fittings pictured below would work i just dont trust anyone and hoping for input from more people with in field experience. It does state above or underground as well as sch40 on the sweep. im no plumber, whats the difference in white to grey... will they adhere together proper, what issues would arise from using this? to my knowledge this is an electrical conduit fitting
THANK YOU
Compatible fittings?-screenshot_20190413-104703_gallery_1555170555014.jpg   Compatible fittings?-screenshot_20190413-104709_gallery_1555170576553.jpg   Compatible fittings?-screenshot_20190413-104721_gallery_1555170592393.jpg
arudam is offline
Old 04-13-2019, 11:44 AM   #2
WHSmike's Avatar
Trade: Plumbing
Re: Compatible Fittings?
That looks like conduit fittings for electrical. Regardless I would get pressure 90s which actually have a sharper turn but are made for pumps and pressure lines
WHSmike is offline
Old 04-13-2019, 11:59 AM   #3
Eater of sins.
ScipioAfricanus's Avatar
Rewards Points: 434
Grey pipe for plumbing is usually a dark grey and will be schedule 80 or it could come in other colors too.
I would not use the light grey pipe he recommended as it is, I think it is electrical conduit and as such may not be compatible with potable waters. And it may not use the same priming and gluing products as white PVC pipe.
Now even though it states that it is "schedule 40" it may not necessarily be rated for a certain pressure but rather for the thickness of the pipe. Others may disagree with this though.
Andy.
ScipioAfricanus is offline
The Following 2 Users Say Thank You to ScipioAfricanus For This Useful Post:
Fouthgeneration (04-14-2019), Rio (04-13-2019)
Old 04-13-2019, 01:03 PM   #4
We Fix Houses's Avatar
Trade: Remodeling / Carpentry
Rewards Points: 2,470
Hope you will pressure test your system, right ?
Curios, is the pump centrifugal or positive displacement ?
Steve
We Fix Houses is offline
Old 04-13-2019, 03:47 PM   #5
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 2,518
couple good heat guns can make your own , 2" not that big just take your time doing it.
Randy Bush is offline
The Following User Says Thank You to Randy Bush For This Useful Post:
jproffer (07-09-2019)
Old 04-13-2019, 04:26 PM   #6
Designer/Contractor
Rio's Avatar
Rewards Points: 1,066
Zoom in and it says Schedule 40 rigid and non metallic conduit, you should go to a plumbing supply house and go from there or work with a good plumber on it.
Here's a short video that explains a bit about pvc, cpvc, schedule 40 and schedule 80................
Rio is offline
The Following 2 Users Say Thank You to Rio For This Useful Post:
ScipioAfricanus (04-13-2019), SmallTownGuy (04-13-2019)
Old 04-13-2019, 04:40 PM   #7
The Grand Wazoo
KillerToiletSpider's Avatar
Rewards Points: 2,036
They make them in both sweep and long sweep.
I may be going to hell in a bucket, but at least I'm enjoying the ride.
KillerToiletSpider is offline
Old 04-13-2019, 07:17 PM   #8
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 4,022
https://www.menards.com/main/plumbin...4449206110.htm
Big Johnson is offline
Old 04-13-2019, 09:25 PM   #9
arudam's Avatar
Trade: Paving stone
Sounds like ill be best off just using 2 - 45s, im sure the long sweep i mentioned would work but long term who knows and im not a gambler 🙂
Ill definitely test the system before i bury the pipe and as far as the pump being centrifugal or positive displacement ? lol no idea!! its a Pentair 011018 model variable speed.
arudam is offline
Old 04-13-2019, 09:26 PM   #10
arudam's Avatar
Trade: Paving stone
Unfortunately this is drain line, so not pressure rated
Originally Posted by Big Johnson View Post
arudam is offline
Old 04-13-2019, 09:32 PM   #11
tjbnwi's Avatar
Rewards Points: 3,970
The fittings you posted are electrical fittings, do not use them in this application.
tjbnwi is online now
Old 04-14-2019, 01:14 AM   #12
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 9,725
Why pour concrete over plumbing that is GOING to FAIL?
use pavers etc....
High end pools have tunnels around them for easy service...
3 HP = 30 cents + an hour, 4 hrs a day ~500.00$ a year for juice, and all those water treatment chems, and You are cheaping out on Potable water pipes.
Go Schedule 80 Pressure fittings they have longer glue joints and will take more pressure jolts then DVW and Conduit crap.
Don't forget to install thrust blocking as required.
Use Anti-Hammer fittings to prevent joint and pipe breakage.
Fouthgeneration is offline
Old 04-14-2019, 08:20 AM   #13
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 9,313
https://www.pvcfittingsonline.com/2-...SABEgIhOPD_BwE
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is offline
Old 04-14-2019, 09:16 AM   #14
https://www.menards.com/main/plumbin...5564673&ipos=2
Old 04-14-2019, 09:21 AM   #15
http://lascofittings.com/poolspa
Old 04-14-2019, 10:15 AM   #16
LRG WoodCrafting
Leo G's Avatar
I did't see any long throw 90s in that link.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is offline
Old 04-14-2019, 10:18 AM   #17
diplomat
Golden view's Avatar
Rewards Points: 1,520
http://lascofittings.com/category/poolspa-sweepelbow
Golden view is offline
Old 04-14-2019, 10:21 AM   #18
LRG WoodCrafting
Leo G's Avatar
Well there ya go.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is offline
Old 04-14-2019, 10:26 AM   #19
arudam's Avatar
Trade: Paving stone
Yup thats it thanks! Have to see if they will sell me direct, otherwise being in canada... dang almost $50 each delivered and i need 14, id still be using 2-45s at that price
arudam is offline
Old 04-14-2019, 12:03 PM   #20
https://www.ebay.com/itm/Waterway-Po....c100005.m1851
Air fittings TempestV Tools & Equipment 8 10-02-2015 07:29 PM
Had a 'duh' moment (pex plumbing and fittings) jproffer Plumbing 7 02-11-2014 06:27 AM
Pex, brass fittings and mineral buildup Anti-wingnut Plumbing 1 03-18-2010 10:56 PM
Kitec attached directly to copper pipe? No fittings A.D. Const Plumbing 29 03-31-2009 07:26 AM
Pre-calculate DWV pipe lengths between fittings? bob_cntrctr Plumbing 1 01-20-2009 01:08 PM
