Comments On Replacing Tank Water Heater With Tankless - Plumbing - Contractor Talk
Old 12-02-2009, 07:12 PM   #1
CRIMPS's Avatar
I have a 40 gal. Electric Water Heater for two full bathrooms. I am remodeling my Master Bath, and I am planning on getting rid of the 17 year old water heater, which is located in a closet. I will be expanding the Shower into the closet... so you understand why I am really wanting to replace the tank water heater with a tankless.
I am looking at this Eemax EX190TC Series Two Electric Tankless water heater. At 3 gal/min the temperature increase is 43 degrees. I think this should be sufficient. Again, this water heater would need to supply hot water to two full baths. We live in North Texas, so I consider the incoming water temp to be moderate. (I am unable to post a link to the water heater at Plumberssurplus dot com.) It looks like I can buy one of these for a little more than $500. This seems reasonable.
My concerns are the quality of the water heater and the electrical upgrade I will probably need to make. Currently, the 40gal water heater installed is using 2x30 amp breakers. I would need to replace the breakers, I assume, with 2x40 amp breakers. Also, has anyone had any experience with these Eemax water heaters?
Thanks for any comments. I haven't ever installed a tankless before. So, if you have any tips, helpful info, etc., I will take it.
Z
CRIMPS is offline
Old 12-02-2009, 08:43 PM   #2
Moderator
Double-A's Avatar
Rewards Points: 2,000
Re: Comments On Replacing Tank Water Heater With Tankless
Z
So, one shower at 2.5 gallons per minute with water temperature of 106 degrees, means that you should have at least 63 degrees otherwise you're not going to have a very hot shower. And 3 gallons a minute isn't much. I think I'd rethink this.
New York Times, July 20, 2006
Double-A is offline
Old 12-04-2009, 11:27 AM   #3
plJosh's Avatar
I have had a lot of experience with both the Eemax and the Stiebel Eltron tankless water heaters. The Eemax is a good unit, but I would recommend that you get one that is a little bit bigger considering what you are talking about in the original post.
The incoming water temperature for most of the united states is 55 degrees so to get to the normal desired level of around 105 you would need about 60 degrees, the Eemax can't provide this. I would consider the Stiebel Eltron Tempra 24, also available on the plumbersurplus.com website for around 660. It can do about a 65 degree increase at 2.5 GPM and has an overall user review of 4 and a half stars. This one does run on a 2x60 circuit breaker though. I know many customers who have used these before and been really happy with them.
Please let me know if you have any other questions regarding them
plJosh is offline
Old 12-04-2009, 11:54 PM   #4
the pipe master
protechplumbing's Avatar
Trade: plumbing, solar
Rewards Points: 502
E-max sucks. I've had to remove several of them. Use a Stiebel Eltron Tempra.
Plumber, Repiping, Replumbing, Leak Detection, Solar Water Heater, Polk County Plumber, Lakeland Plumber, Winter Haven Plumber
protechplumbing is offline
tankless water heater p1grinder Plumbing 17 02-20-2009 10:08 PM
Standard water heater vs Power water heater Alphabuilder422 HVAC 6 10-19-2008 05:45 PM
Tankless Heater Installation Ramblinwreck Plumbing 76 09-17-2008 01:58 AM
Hot Water Heater - replacing part(s) ETHICS05 Plumbing 9 08-18-2007 09:38 AM
