Combination Sump Pump Vs 2 Dedicated Systems - Plumbing - Contractor Talk
Old 02-22-2019, 02:00 PM   #1
AlabamaSummers's Avatar
Rewards Points: 92
Hey, guys,
I was told recently that 2 dedicated sump pumps are better that a combination sump pump for a home. The reasoning was that if one component breaks on the combination sump pump, the entire system goes down.
On the other hand, if you have two dedicated sump pump systems (one in which has a battery backup), you won't encounter this problem.
What do you guys think?
AlabamaSummers is offline
Old 02-22-2019, 02:34 PM   #2
hdavis's Avatar
Rewards Points: 1,196
Re: Combination Sump Pump Vs 2 Dedicated Systems
I did that after I had a system fail leading to a cellar flooding. It's rare to have a fail.
hdavis is online now
AlabamaSummers (02-22-2019)
Old 02-22-2019, 03:11 PM   #3
Rewards Points: 92
Even though it's rare, I guess you're for getting two separate dedicated systems with one of them having a battery backup, right?
Old 02-22-2019, 03:16 PM   #4
MarkJames's Avatar
Rewards Points: 18,987
Do you mean a main and a battery-operated back-up? There are combo units with those two separate units), so they basically save you some plumbing discharge work in the pit. Battery sold separately.
MarkJames is offline
Old 02-22-2019, 03:17 PM   #5
Designer/Contractor
Rio's Avatar
Rewards Points: 1,094
If it's a critical area where you really don't want it get wet then it would seem to be well worth the additional cost and hassle.
Rio is online now
The Following User Says Thank You to Rio For This Useful Post:
hdavis (02-22-2019)
Old 02-22-2019, 03:19 PM   #6
MarkJames's Avatar
Don't forget a water alarm (or two) placed on the floor nearby. Cheap insurance.
Old 02-22-2019, 03:33 PM   #7
hdavis's Avatar
Doesn't work well if nobody is home, but it's still worth it.
Old 02-22-2019, 04:06 PM   #8
tgeb's Avatar
Rewards Points: 860
The combination units I have seen have 2 pumps which will work in tandem if the primary pump is overwhelmed, and one will work as battery backup in the event of power failure.
Are you thinking of having two separate sumps and systems? Not real clear what the question is.
www.gebcon.com
tgeb is online now
Old 02-22-2019, 04:20 PM   #9
Rewards Points: 92
Hi, Mark,
Yep, I meant a main and a battery operated back-up. I was asking whether the combo units are better than having two separate systems. One main. And another separate system with a battery backup.
Old 02-22-2019, 04:23 PM   #10
Rewards Points: 92
Hi, tgeb,
I know about the combo units. I meant totally two different systems. I was told that the combo units can fail (they said they've seen it happen) because if a certain component breaks in the combo unit, the entire system can fail. They said it's better to get two separate systems.
I'm wondering how true this is.
Old 02-22-2019, 04:47 PM   #11
rrk's Avatar
Rewards Points: 4,884
A battery backup pump will not pump for long especially when you need it the most, maybe 2 hrs
I have a few customers who found out the hard way, if you have city water check out water powered back up pumps. Uses no electricity, pumps out 2 gallons for every 1 gallon used
rrk is online now
The Following 2 Users Say Thank You to rrk For This Useful Post:
AlabamaSummers (02-23-2019), Rio (02-23-2019)
Old 02-22-2019, 04:53 PM   #12
Windycity's Avatar
Trade: Masonry
Rewards Points: 8,740
I have been thinking of getting one of those myself. The only problem is you need to make sure you have sufficient water flow to the unit to create enough suction
Windycity is offline
Old 02-22-2019, 08:10 PM   #13
rrk's Avatar
yes, everyone I see has a 3/4" line. But they work great and the discharge line has to be above ground so you know its pumping but with the amount of water coming out it is a bit noisy
rrk is online now
Old 02-22-2019, 08:27 PM   #14
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 4,174
They’ll last longer than 2 hours but it all depends on the battery size. A 45amp hour will last about 2 days pumping every 5 minutes.
Big Johnson is offline
Old 02-22-2019, 11:05 PM   #15
hdavis's Avatar
If I had to go with a battery backup, I'd make that use a 12V bilge pump. 5A draw to get 1250 gph into a 5 foot head, for instance. Way more efficient use of the juice.
The last sump pump fail I had was the check valve, which came loose inside and erratically blocked the outlet.
Morning Wood (02-23-2019), Rio (02-23-2019)
Old 02-24-2019, 10:04 AM   #16
rrk's Avatar
I can positively tell you that the battery that comes with that pump does not last that long.
2 different customers one lasted 2 hours 1 close to 3 hours
Another one had a drainage system installed in their basement with one and that only lasted 2 cycles when the customer decided to test it by unplugging main pump. But I think that was a defect with pump or battery since it was brand new
rrk is online now
hdavis (02-24-2019)
Old 02-24-2019, 10:24 AM   #17
hdavis's Avatar
Doing one from scratch knowing what I know, I'd use 2" pipe and no 90 elbows If it's any real length. It improves the pumping efficiency, so less power is used. It also increases flow rate. I've seen systems that under the right conditions it can't keep up with the water coming in.
They're cheap, over engineering them isn't much money compared to what can be lost.
BTW, Attwater bilge pumps are the most efficient ones out there, but they won't work well if there is too much head.
Old 02-24-2019, 11:02 AM   #18
diplomat
Golden view's Avatar
Rewards Points: 1,550
If it were my house, I'd consider the battery back up something to keep me dry while I get the generator out.
The systems used here use large batteries and claim 12,000 gallons on a battery.
Golden view is offline
The Following 2 Users Say Thank You to Golden view For This Useful Post:
hdavis (02-24-2019), rrk (02-24-2019)
Old 02-24-2019, 11:19 AM   #19
MarkJames's Avatar
Near our sump is an existing floor drain connected to the sanitary waste. No longer legal, but I'm certainly not removing it.
Old 02-24-2019, 12:33 PM   #20
Radical Basement Dweller
Robie's Avatar
Rewards Points: 2,520
This works if you're not home. I bought one a few years ago and it works great. I was having trouble with copper pipes entering and existing my oil-fired-boiler leaking.
I paid half the price of what it is now.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
“Now is no time to think of what you do not have.
Think of what you can do with what there is”
― Ernest Hemingway, The Old Man and the Sea
Robie is online now
hdavis (02-24-2019)
Winterizing laundry sink sump pump Willin Plumbing 3 10-09-2017 10:14 PM
sump pump change-out cleveman General Discussion 7 07-10-2014 08:10 AM
Free standing Wheelchair ramp by Creative Bath Systems Creative Bath Specialty Trades Picture Post 5 05-30-2012 05:40 PM
Sump systems that mount above grade? wackman Plumbing 8 01-16-2008 08:38 PM
Mixing mortar with sump pump water mdshunk Masonry 13 01-25-2006 04:58 PM
