Can You Just Solder A Cut In A Copper Pipe? - Page 3 - Plumbing - Contractor Talk
Old 05-17-2019, 04:49 PM   #41
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
Re: Can You Just Solder A Cut In A Copper Pipe?
Originally Posted by KillerToiletSpider View Post
A little Mighty Putty should do the trick.
Worked in a pinch when I drilled through a 4" copper waste pipe in an apartment at 7pm on a Saturday....
Inner10 is offline
Old 05-17-2019, 05:30 PM   #42
Designer/Contractor
Rio's Avatar
Rewards Points: 526
No pressure on a waste line.......
Rio is offline
Old 05-17-2019, 05:33 PM   #43
Inner10's Avatar
Fact
Inner10 is offline
Old 05-17-2019, 05:41 PM   #44
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 516
But we have to pressure test them to pass inspection. Go figger.
Tinstaafl is online now
Old 05-17-2019, 07:45 PM   #45
tjbnwi's Avatar
Rewards Points: 2,054
Fact
Until there is a blockage. That's why drains are pressure tested in most areas. Some require a full system water test, not air.
tjbnwi is online now
Old 05-17-2019, 07:53 PM   #46
John the Builder
SmallTownGuy's Avatar
Rewards Points: 6,114
Yeah, ain't nobody pressure testing repairs. FCOL
People going off the rails again on extremes.
SmallTownGuy is offline
Old 05-17-2019, 08:51 PM   #47
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 516
I'll give you that. However, I'd postulate that an air test could fail where a water test would pass. Reasoning being that water is denser and won't leak so readily, and in most cases wouldn't present as much pressure as we're required to use with air. Admittedly, I've never measured that pressure.
Old 05-18-2019, 12:39 AM   #48
Designer/Contractor
Rio's Avatar
Rewards Points: 526
Yes, but the pressure they're tested at isn't as high as the line pressure many times and it's not forever so a plug that might work well for a short duration could easily fail after a month, or a year or..........
Rio is offline
Old 05-18-2019, 09:01 PM   #49
VinylHanger's Avatar
Rewards Points: 11,730
My waste line always has pressure. It makes me giggle when the dogs waste line releases pressure as well.
VinylHanger is online now
The Following User Says Thank You to VinylHanger For This Useful Post:
TheConstruct (11-12-2019)
Old 07-08-2019, 04:31 PM   #50
kloiks's Avatar
Trade: Contracting
Rewards Points: 6
Put a saddle clamp on it. The clamp won't be holding back pressure, just supporting that area of the pipe.
kloiks is offline
Old 11-12-2019, 08:36 PM   #51
dkonrai's Avatar
Trade: plumber
Rewards Points: 28
I've seen patches like that leak over time. Maybe 5 or so years and it will start as a small leak, then a rupture. At least that's what I've seen when nail holes were soldered over.
Another vote to use a slip coupling and solder.
Or with propress around, it takes seconds.
Sent from my moto g(7) using Tapatalk
dkonrai is offline
Copper Pipe Bender Smokin Plumbing 21 12-07-2014 11:57 PM
pipe repair - ok to replace copper with cpvc? MarkJames Plumbing 39 10-11-2013 04:36 PM
HDPE Pipe Problems with vacuum and collapsing turfguy13 General Discussion 6 02-10-2011 08:03 AM
Cement Contact with Copper Pipe Capt2 Plumbing 11 04-17-2007 08:05 PM
