Can You Just Solder A Cut In A Copper Pipe? - Plumbing - Contractor Talk
Old 05-16-2019, 05:31 AM   #1
woodspike's Avatar
Rewards Points: 688
plumbers showed up to clients house yesterday
one was a girl about 25 . said she was a plumber .
they had to re-do the drain under a double sink.
she was so hesitant to cut the backing off the cabinet. i told her don`t worry i`ll replace it ,
short story i jumped in and cut it out with my sawsall , and hit one of the pipes.
shut the water off , quick.( my defense , there was a disposal , dishwasher lines, and water filter , so hard to maneuver a full sawsall. and i didn`t have a blade for my multi-tool!!)
she said she was gonna just solder the pipe ( not cut , and add a slip coupling )
will that hold in the long -run ?
just didn`t like her style.
constantly calling her husband , and asked him how to do this and that
and charging the client $100 for her , and an apprentice who seemed to know more than her, but wouldn't let him do much because of ego.
this is a new remodeled kitchen , i want to make sure this leak will hold , ( great client )
will it hold , or should i demand they cut , and add a coupling ?
woodspike is offline
Old 05-16-2019, 05:50 AM   #2
John the Builder
SmallTownGuy's Avatar
Rewards Points: 4,500
Re: Can You Just Solder A Cut In A Copper Pipe?
Did you walk out the door with it that way?
If so, wait a couple years, then check back in with customer. If still no leak, I'd let it go.
SmallTownGuy is offline
Old 05-16-2019, 06:02 AM   #3
woodspike's Avatar
Rewards Points: 688
wow.
no offense , but i don`t like that philosophy at all.
i want 'whats the right way to repair a leak?"'.
not a " i hope it holds " repair.
nice , nice client , they just bought the house, just put in thousands to remodel. just moving in
floors are wood.
don`t want a suprise
Old 05-16-2019, 06:02 AM   #4
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 5,226
If the coupling is over the cut.
I’m not sure I understand what you’re describing
Big Johnson is offline
The Following 2 Users Say Thank You to Big Johnson For This Useful Post:
MarkJames (05-16-2019), Rio (05-16-2019)
Old 05-16-2019, 06:10 AM   #5
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 4,352
I did it on a drain pipe...
Inner10 is offline
Old 05-16-2019, 06:20 AM   #6
John the Builder
Originally Posted by woodspike View Post
wow.
floors are wood.
I am mocking you. You walked out the door with it that way, knowing in your gut YOU weren't happy with the process, and now you are here, asking us to salve your soul with some bull**** answer.
Answer this: What is the difference between waiting and hoping one day or 2 years?
Nothing - not one damned thing.
Old 05-16-2019, 06:20 AM   #7
woodspike's Avatar
Rewards Points: 688
no coupling , she just soldered over the sawsall cut
Old 05-16-2019, 07:03 AM   #8
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 15,253
That probably won't hold by itself, but a slip coupling would have. Even a fernco over the cut would have been good. Did you clip the top of the pipe, or near the bottom? Sure it was just the drain?
MarkJames is offline
Old 05-16-2019, 07:31 AM   #9
It was a supply line, he had to “shut the water off quick”.
MarkJames (05-16-2019), SmallTownGuy (05-16-2019)
Old 05-16-2019, 07:35 AM   #10
MarkJames's Avatar
Figured as much, but he mentioned drain line, too...which wouldn't make sense anyway since it's not the 60's anymore. (My folks have all copper drains in their house, up in philly)
And that confirms the plumber lady was really not up to par, so maybe I was trying to give her the benefit of the doubt.
Old 05-16-2019, 07:36 AM   #11
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 15,181
If she got a good bond and made it thick enough it'll likely hold for a long time. It's not the right way to do it. As others have said, cut the pipe the rest of the way and reconnect it with a slip coupling.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Rio (05-16-2019)
Old 05-16-2019, 07:38 AM   #12
tjbnwi's Avatar
Rewards Points: 4,642
Put a saddle clamp on it. The clamp won't be holding back pressure, just supporting that area of the pipe.
tjbnwi is online now
Old 05-16-2019, 07:39 AM   #13
MarkJames's Avatar
How would you clean the cut surfaces sufficiently, prior to flux?
Old 05-16-2019, 07:40 AM   #14
tjbnwi's Avatar
Scuff the out side of the pipe.
Old 05-16-2019, 07:43 AM   #15
LRG WoodCrafting
Leo G's Avatar
Just like you would normally. emery cloth, sand paper, wire brush. Whatever you do just make sure it's clean. Probably easier to do while the pipe is still together. Clean it, cut it, flux it, install the fitting, solder it.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 05-16-2019, 07:48 AM   #16
tjbnwi's Avatar
Here you go
https://www.flexsealproducts.com/product/flex-tape/
hdavis (05-16-2019)
Old 05-16-2019, 07:49 AM   #17
MarkJames's Avatar
You convinced me that it'll hold for a while, but if it creates a bump of solder inside the pipe, then it'll probably have issues further down the road.
Did you ever watch those vids where they bisect pipe to show how pinholes form downstream from a burr left in a joint? It creates turbulence and wears the inside of the copper, leading to pinholes.
Old 05-16-2019, 07:55 AM   #18
woodspike's Avatar
Rewards Points: 688
Hey guys i never mentioned a drain line.
" Inner 10 "
This was a basic 1/2 inch copper line.
I called her boss and told him if he won't put in writing that she just soldered it, and if he won't guarantee it'll hold up as good as putting a coupling in he needs to change it.
Hey. Plumbers charging$100 an hour should know their job and i shouldnt be having to hunt for the answers.
The Following User Says Thank You to woodspike For This Useful Post:
Old 05-16-2019, 07:56 AM   #19
woodspike's Avatar
Rewards Points: 688
meant to say, inner 10 was the one who mentioned the drain line
Old 05-16-2019, 07:57 AM   #20
MarkJames's Avatar
" Inner 10 "
Was she cute?
The Following 2 Users Say Thank You to MarkJames For This Useful Post:
Jay hole (05-17-2019), jhark123 (05-16-2019)
Copper Pipe Bender Smokin Plumbing 21 12-07-2014 11:57 PM
pipe repair - ok to replace copper with cpvc? MarkJames Plumbing 39 10-11-2013 04:36 PM
HDPE Pipe Problems with vacuum and collapsing turfguy13 General Discussion 6 02-10-2011 08:03 AM
Cement Contact with Copper Pipe Capt2 Plumbing 11 04-17-2007 08:05 PM
