Beamis Slow Drop Seat Won't Stay Put - Plumbing - Contractor Talk
Old 04-30-2019, 08:56 AM   #1
artinall's Avatar
Trade: Repairs & Finishing
Rewards Points: 1,030
Help! Maybe caused by a mount on a Toto (distance to bowl?)
Whenever lifted - slowly, it begins to pass a tipping point and starts to lower while in use. Annoying. And its difficult to stay mindful of this hazard during a middle of the night wake-up call...
Any way to loosen tension? Believe it already is mounted forward.
artinall is offline
Old 04-30-2019, 09:07 AM   #2
MarkJames's Avatar
Rewards Points: 18,873
Re: Beamis Slow Drop Seat Won't Stay Put
Remove the crocheted toilet seat cover.
MarkJames is online now
Rio (05-04-2019)
Old 04-30-2019, 09:09 AM   #3
artinall's Avatar
Wish it were that easy -- thx for the optimism.
Although you are giving me ideas.
I could slip on a political-themed. Just let it catch the spray.
artinall is offline
Old 04-30-2019, 09:19 AM   #4
MarkJames's Avatar
Assuming that it's hitting the tank top, loosen the seat bolts and see if you can slide it further a bit. If it came with offset oval washers, use them in the forward position instead of the centered washers.
Or push the tank lid a bit further back, if possible.
A bit goofy, but sticking a counterweight on the top edge of the lid might also solve it.
Old 04-30-2019, 11:01 AM   #5
rrk's Avatar
Rewards Points: 4,846
Only use Toto or Church seats on Toto toilets
rrk is online now
artinall (04-30-2019)
Old 04-30-2019, 12:24 PM   #6
artinall's Avatar
If only I knew then...trusted the plumbing supplier.
Believe they had to order this.
artinall is offline
Old 04-30-2019, 07:39 PM   #7
B.Johnson's Avatar
Trade: Builder
Rewards Points: 2,840
Then I would think that they have a problem, not you.
Home Designer Series Software
B.Johnson is offline
Old 04-30-2019, 10:17 PM   #8
rblakes1's Avatar
Rewards Points: 3,920
Is the toilet level from front to back? If it's tipping down towards the front, that might be causing the issue
-Rich
rblakes1 is online now
Old 05-06-2019, 01:33 PM   #9
lynndr's Avatar
Trade: Plumbing
Rewards Points: 2
Church and Bemis are the same exact toilet seats - just different names. You should be able to use either of them on a Toto toilet.
lynndr is offline
Old 05-06-2019, 01:50 PM   #10
artinall's Avatar
-Rich
Checked and it is level
artinall is offline
Old 05-06-2019, 02:50 PM   #11
rrk's Avatar
no they are not
plumber matched them up and the hinges are little different dimension
after he had the same seat issue
rrk is online now
York furnace-pilot light will not stay lit.... PrestigeR&D HVAC 40 03-27-2013 08:12 AM
Should I Stay Or Go? dcphinney Concrete & Paving 36 06-18-2012 08:42 PM
Drop covers for protecting furniture, etc. when sanding and painting Wood_Smith Painting & Finish Work 4 04-23-2012 04:59 AM
You could have heard a pin drop Willie T Off Topic (Non Trade) 5 08-10-2011 09:30 PM
Uh-oh, the Big Drop is stalling out. Mike Finley Marketing & Sales 7 12-12-2008 06:05 PM
