Barn Water Heater - Line Frozen - Plumbing - Contractor Talk
Old 01-22-2013, 11:58 PM   #1
artinall's Avatar
Trade: Repairs & Finishing
Rewards Points: 1,030
I'm not a plumber by a freak stretch - although we normally keep our hot water line dripping in the barn. Believe this is a "smart water heater" - a shortie that think is GE 30 gal, all copper pipes.
The heater line out goes down through the foundation, underground over to end off, up and out onto a side wall that is (1) room away, so its not a bordering room but at least its still inside the barn. Spigot dumps into a pea gravel basin.
With the spigot frozen solid, so the lever wouldn't even turn (ball valve) I poured a stream of hot water on it for some while. Running a gas stove in the room of the water heater, for about an hour and a half to raise the temp of the copper in case those were solid inside.
After a while, got a gush of hot water, maybe a gallon, then everything went dead, to a slow drip that stopped. Continuing with the hot water trick, I did get an occasional dribble which then went away. The inbound valves to the water heater seemed work fine, nothing seized as if frozen. Also tried the tank pressure release valve, tripping the power breaker. Finally the outbound lines from the heater went cold again after pulling heat from the room.
Is it likely the line is plugged frozen under ground? It's been below 10 degrees here. I guess its possible that our 'preventative dripping' could have seeped into the gravel and frozen deeper around the pipes, kind of counter-productive if you know what I mean.
Anyway, I left the spigot turned a little open, thinking it may release pressure, a feeble attempt to prevent a bursting pipe.
What to do with this? Decided not to use electric pipe warmers.
I can a get the hot water to flow. Horses get thirsty, ya know?
artinall is offline
Old 01-23-2013, 12:16 AM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 2,452
Re: Barn Water Heater - Line Frozen
I'd have to suspect it's frozen under the slab.
If it's all copper, know where there is a pipe thawer?
griz is offline
Old 01-23-2013, 12:22 AM   #3
artinall's Avatar
Thanks for the reply, griz.
Hmmm, pipe thawer. Is that something you find at a tool rental place? By what stroke of magic can you manage to reach beneath the slab?
Other thing I didn't mention is that I left the water heater power on, yet don't know if there is water in it. If partly empty could this fry it? I didn't want it to freeze as well.
artinall is offline
Old 01-23-2013, 12:44 AM   #4
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 12,549
If it runs dry, yes you can burn out an element.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is offline
Old 01-23-2013, 12:52 AM   #5
artinall's Avatar
Should I power it off? But then what if the water freezes inside the water heater?
artinall is offline
Old 01-23-2013, 12:56 AM   #6
LRG WoodCrafting
Leo G's Avatar
If there is water in it then it will freeze. Tough call. You could always disconnect the top element if you think the tank might not be full. If the tank output is on the top of the tank then it is pressure driven. You can't drain the tank with a top discharge.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is offline
Old 01-23-2013, 01:02 AM   #7
artinall's Avatar
I believe the output is on top. So it sounds like that should be safe. Do you agree it's probably frozen under the slab?
artinall is offline
Old 01-23-2013, 08:17 AM   #8
LRG WoodCrafting
Leo G's Avatar
Good chance. Without knowing the depth of the pipe hard to say for sure. Frost line here is 42", usually freezes down to 18" If it's in that range then it's solid.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is offline
Old 01-23-2013, 08:24 AM   #9
artinall's Avatar
Other big concern is if the line bursts, especially in the ground or slab.
artinall is offline
Old 01-23-2013, 08:31 AM   #10
LRG WoodCrafting
Leo G's Avatar
Don't they have a thaw device that just heats up the length of pipe? Clip it on each end and put the power to it? I'm sure it's only a plumber owned thing, probably pricey to have/do.
Better than burst pipes though.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is offline
Old 01-23-2013, 09:08 AM   #11
Capra aegagrus
Tinstaafl's Avatar
Call in a guy with a portable welding rig.
Tinstaafl is offline
Old 01-23-2013, 12:45 PM   #12
wyoming 1's Avatar
Trade: General contractor
Rewards Points: 520
Yep I have seen guys do it with a portable arc welder clamp one on each end of the pipe. The guy who I saw do it said as soon as the water starts turn off the welder or you will melt the solder out of the joints. Not make your picture worse but I have seen them freeze here 5 feet down (under drive ways) and not come back on til July.
wyoming 1 is offline
Old 01-23-2013, 01:17 PM   #13
The Grand Wazoo
KillerToiletSpider's Avatar
Rewards Points: 2,036
This is the machine you are referring to.
I may be going to hell in a bucket, but at least I'm enjoying the ride.
KillerToiletSpider is offline
Old 01-23-2013, 03:56 PM   #14
artinall's Avatar
Rented the pipe thawer and worked on it for a long time, while putting heat back into the room. Didn't work. Thought it would, but unfortunately...
artinall is offline
Old 01-23-2013, 09:22 PM   #15
Capra aegagrus
Tinstaafl's Avatar
Did you establish whether there's liquid pressure [incoming] to the heater, or the heater is frozen? Sometimes the problem is at the other end of the system from where you think it is.
Old 01-23-2013, 09:42 PM   #16
artinall's Avatar
Only thing verified is that 2 lines valves going in move freely, made me think that it wasn't frozen.
Anyway, believe we came close enough with the pipe thawer, it's now working! A $35 solution as it turns out which is reasonable.
- Thanks for the helpful replies. Appreciate it.
artinall is offline
Old 01-23-2013, 09:51 PM   #17
LRG WoodCrafting
Leo G's Avatar
Kewl. Glad to see that you got your water flowing
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is offline
Trenchless water line replacement A-Z Cuda Plumbing 0 10-04-2012 07:50 PM
