Air Pump On Pressure Tank? - Plumbing - Contractor Talk
Old 10-21-2012, 08:43 PM   #1
bob_cntrctr's Avatar
Trade: property manager & renovator
Gentlemen,
Can anyone imagine what this is about?
I'm looking at a unit here - on well & septic. Two pressure tanks installed in parallel. The larger of the two has a small electric air pump permanently connected to the top of the tank, and it's wired into the pressure switch so that every time the well pump comes on, so does this little air pump.
Never seen anything like this before. Can anyone confirm that this is something normal and with a purpse? Or am I calling the plumber to fix someone's mess?
Thanks.
Update: - I cannot find an air inlet nipple anywhere on the tank that one might use to adjust the precharge.
bob_cntrctr is offline
Old 10-21-2012, 08:51 PM   #2
The Grand Wazoo
KillerToiletSpider's Avatar
Rewards Points: 2,000
Re: Air Pump On Pressure Tank?
It could be an older tank that does not have a diaphragm in it to sustain the pressure, and instead relies on the pump to do that instead.
I may be going to hell in a bucket, but at least I'm enjoying the ride.
KillerToiletSpider is offline
Old 10-21-2012, 09:48 PM   #3
paul100's Avatar
Rewards Points: 60
Are you sure it is an air pump and not a chemical feed pump. Chemical feed pump would be used to pump chlorine and other chemicals into the water every time the main water pump kicked on.
paul100 is offline
Old 10-21-2012, 10:58 PM   #4
Thanks for the suggestion - but I think it's not very old. It's a fiber-wound Well Mate tank, about 100-gallons.
Old 10-21-2012, 11:01 PM   #5
Yes, I suppose that's possible. There is no hose for drawing in a treatment chemical, nor a container for such, only a hose from the pump to the top of the cyclinder - but I suppose it could have just been removed and the pump left there.
Also, it has no metering for delivering any set amount of chemicals - just a pressure meter, which reads approximately the line-pressure, and it runs the whole time the well pump is on.
Old 10-22-2012, 07:44 AM   #6
Oconomowoc's Avatar
Trade: construction
The tank with the pump has no bladder and the purpose of the pump is to introduce air and reduce the smell - like sulfer etc. The next tank has a bladder.
In the old days they were called "air over water" tanks and they were great because it would help reduce the rotten eggs smell.
There's a good chance the original house had one simple pressure tank. Then the HO couldn't take the smell so a plumber put in the extra tank in to get rid of it.
Oconomowoc is offline
Old 10-22-2012, 08:00 AM   #7
Oconomowoc's Avatar
Trade: construction
Whatever you do don't take out the tank with the pump or you will have a very pissed off home owner. The sulfer smell is probably really bad and the second that tank is removed it will come out the faucets. Lol
Remember, a bladder tank has no "air to water" direct connection. So by itself the smell is simply transfered in the water until it bleeds out the faucets.
They do work very well and it's dependable.
Old 10-22-2012, 09:02 AM   #8
Ding! Ding! Ding!
I do believe you nailed it. Searched for those terms and found this:
http://www.wellmatetanks.com/wellmat...ater-tanks.htm
That's exactly what it is. So, no, not a sketchy installation I have to get corrected by the plumber. But don't worry - there'll be other work for him on this one.
Thanks a bunch.
Old 10-22-2012, 09:45 AM   #9
Oconomowoc's Avatar
Trade: construction
You're welcome
Old 10-22-2012, 09:48 AM   #10
Oconomowoc's Avatar
Trade: construction
FYI: It's worth mentioning to the home owner that they should have the water tested. Sulfur is one thing but sulfur bacteria is another.
A system like this can hide or mask a much more severe problem. A water test done by a laboratory is a smart precaution and it's a kind thing to mention.
Old 10-22-2012, 10:36 AM   #11
Thanks for the additional info.
The "homeowner" is the rental group I work for. This house was recently purchased to be turned into a rental. My job is to identify what should be done to make everything up to snuff before it's rented out, then manage the property (so any grief I get from tenants about deficiencies is my own damn fault.....). I try to figure out as much as I can before calling the specialty trades so I know what I'm talking about.
So a standard bacteriological test was done for the purchase. I'll check if that covered sulfur bacteria.
Then I'll be looking up how to go about adjusting the pre-charge on this thing so we can dial down the system pressure. Previous owners had it jacked up to 50psi cut-in and 75psi cut-out! No wonder the toilet inlet valves were leaking.
Anyway - thanks again.
Old 10-22-2012, 11:02 AM   #12
Oconomowoc's Avatar
Trade: construction
It's normal for those to run up to 75. Don't change anything! You'll phuc it up!
75 psi are not causing a leak, they can handle it. 80 psi is Max in Wisconsin but to be at 75 is normal for an aeration system.
60 is average for NORMAL systems but NOT for that. We're only talking 15 pounds.
Polish it with a rag and walk away. Lol
Old 10-22-2012, 11:03 AM   #13
Oconomowoc's Avatar
Trade: construction
Spend $8 and put Fluidmaster 400A's in the toilet tanks. Done!
Old 10-22-2012, 11:45 AM   #14
So now I'm curious, for my own education - why the higher pressure for an air-injection system? And how would reducing to 60 mess it up?
And...
double-checking the Well Mate site
www.wellmatetanks.com/wellmate-fiberglass-tanks/hp-series-traditional-air-over-water-tanks.htm
and
http://www.wellmate.com/en-US/produc...onnect-series/
You couldn't know this for your previous replies, obviously, but the specs for this tank say max operating pressure = 75psi.
So I'm gonna hafta turn it down - doesn't seem reasonable operating everyday at max spec, with zero room for thermal expansion spikes.
Update: I spoke with Well Mate. They confirm - under no circumstances should this tank be operated at 75psi.
Old 10-22-2012, 04:06 PM   #15
Oconomowoc's Avatar
Trade: construction
Well, the limit is 75 and that where you are at so it's not an issue. Historically aeration systems are run at the max. If you adjust it make sure you know what you are doing. It's been working just fine because it's set-up to run like that.
Anyhow, the tank is not the limit. What I mean is, operating pressure is different than engineered pressure capacity. Lots, and I.mean lots of them are at 75.
If the pressure exceeds 80 psi the system has a relief valve that trips and this is to protect the system from pressure.
Do what you want of course it's your baby.
Old 10-23-2012, 08:17 AM   #16
Well, much appreciate the input and someone to discuss it with, but it sounds like it's not as sorted out as I thought.
Manufacturer says don't do that. This being a rental, if something were to happen, "I read on the internet..." wouldn't be much of a defense.
So it looks like a specialty trade will be getting work on this after all. I've got the water treatment system guys coming today to sort it out. Important thing was to determine that, yes, there are questions justifying the visit, not just my ignorance.
Thanks agaain.
How to Safely Pressure Wash Your Home. PressureWashE Pressure Washing 1 07-02-2010 05:50 AM
sub pump done misconduct Plumbing 9 04-25-2010 02:24 PM
myson controller pump 3 port?? big moo Plumbing 1 09-02-2008 02:48 PM
advice on low pressure well problem AustinDB Plumbing 0 07-16-2007 06:54 AM
