4 Stud Wall Hung Toilet Vs 2 Stud Wall Toilet - Plumbing - Contractor Talk
Old 02-25-2013, 07:39 AM   #1
mohdmaruf's Avatar
Trade: civil engineer
hi guys. till now i have install commercial toilet with 4 studs two at top and two at bottom . now i come across a residential wall hung toilet to be supported on two top studs only. what about the bottom stud portion? will these two studs sufficient to take a man load. what measures one should take while tightening. so it would not come in contact with wall anywhere to prevent damage to bowl.
mohdmaruf is offline
Old 02-25-2013, 07:48 AM   #2
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
Re: 4 Stud Wall Hung Toilet Vs 2 Stud Wall Toilet
They should be fine. There are numerous 4 and 2 hole systems available and they all work fine. don't go silly tight with the bolts but make sure they are snug.
www.bcconstructionllc.com
BCConstruction is offline
The Following User Says Thank You to BCConstruction For This Useful Post:
mohdmaruf (02-28-2013)
Load Bearing Wall Diozark Framing 20 01-01-2013 04:29 PM
Restaurant Wall build?? lsgstexas Commercial Construction 1 10-17-2012 09:09 PM
Retaining Wall Rebuild Dovetailed Landscaping 22 03-31-2012 08:02 PM
Plumb against concrete or stud exterior wall? jimustanguitar Plumbing 1 11-28-2011 05:40 PM
Attaching Flat Screens To Metal Stud Wall Tidewater07 Low Voltage 15 05-04-2008 08:18 AM
