3/4 Valve Won’t Solder - Page 2 - Plumbing - Contractor Talk
Old 05-14-2019, 09:17 AM   #21
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 21,213
Re: 3/4 Valve Won’t Solder
I always use a slightly damp rag. Never got burned.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Old 05-14-2019, 04:31 PM   #22
rescraft's Avatar
Trade: residential remodeling/construction
Rewards Points: 1,435
Originally Posted by Seven-Delta-FortyOne View Post
I've had many situations where old pipe just would not solder. I've had to do what you did, and just cut it out, or use a sharkbite.
I soldered successfully with propane for a short time, until I switched to MAPP gas 20 years ago. Soldering something with a lot of mass, like a ball valve, is going to be difficult with propane.
And please don't use a wet rag to wipe a joint after soldering. You'll get a nasty burn. Use a dry one.
And yes, excess flux should be wiped up. It's actually a corrosive product, and should not be left on the pipe.
RE Flux, my dad worked on the first communication satellite @Hughes Aircraft in the late 60's (CommSat) After a few launches, they were having some failures and could not figure out why. Come to find out, when the techs were soldering all the PC boards, they were failing to clean the tell tale flux left on the connections. After cleaning, no more failures.
rescraft is offline
The Following User Says Thank You to rescraft For This Useful Post:
SmallTownGuy (05-14-2019)
Old 05-14-2019, 06:36 PM   #23
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 76
Ditto. Never got burned by a wet rag either.
A dry rag won't clean the flux off nearly as well.
Tinstaafl is offline
Old 05-14-2019, 06:39 PM   #24
John the Builder
SmallTownGuy's Avatar
Rewards Points: 5,332
Totally worthless, but there ya go info: First IDE drive I ever owned came from a reject pile from Hughes Sats. Cost me a pretty penny, even so.
SmallTownGuy is online now
Old 05-14-2019, 06:53 PM   #25
LRG WoodCrafting
Leo G's Avatar
My first hard drive cost me $400.00. It was 40MB.
Might hold one or two pictures.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 05-14-2019, 07:23 PM   #26
hdavis's Avatar
Rewards Points: 328
There are possibly 2 wipes. One to get rid of excess solder while it is still liquid. This us usually a dry wipe. A wet wipe at this stage risks cooling the joint unevenly, degrading the joint. The second one is to get the flux off the pipe. This would usually be wet with the pipe still warm.
hdavis is online now
superseal (05-14-2019)
Old 05-14-2019, 09:24 PM   #27
Porterfarm's Avatar
Trade: Handyman/ Home Improvement Contractor
Rewards Points: 22
Use mapp or acetylene, plenty of flux, too little is worse than too much. Make certain everything is freshly cleaned .
Yes if you stay too long with a low temp torch you will overheat everything damaging the valve and all.
It's hard to reflow a joint if it leaks. The best thing to do is take it all apart and start from square one.
If you are repositioning a good joint. Make sure everything is clean and dry. Flux everything. Even adjacent joints that will keep the solder from receding.
If you find you're spending too much time with the heat, due to water, old joint, you can try to introduce more flux then try it again as a last ditch effort. The flux is a cleaning agent. You will know if solder starts to flow then your good. Otherwise you need to pull it apart.
Solder always travels towards the heat.
Sometimes wet the joint on the front side with solder in one spot. This can help a lot with heat transfer between your two pieces.
On some really old junk I've hit the area (before making the joint t but in prepping) with flux and then heat afew times in an effort to clean the surfaces ( very extreme cases)
I wait for the joint to cool Abit and wipe with a wet rag to clean off the flux.
Experience through trial and error.
All different things to consider....
Porterfarm is offline
w.c flush valve mohdmaruf Plumbing 1 02-23-2013 09:19 AM
Moen stop check valve....? PrestigeR&D Plumbing 8 11-27-2012 03:03 PM
Sloan flush valve wireless Plumbing 6 08-07-2012 02:37 AM
Check Valve fireguy Plumbing 2 11-04-2010 06:53 PM
bryant gas valve heavyduty73 HVAC 1 12-16-2009 07:20 PM
