Is 3/4" Pex Necessary? - Plumbing - Contractor Talk
Old 11-08-2019, 10:24 AM   #1
BlueRidgeGreen's Avatar
Trade: Craftsman
I'm building this house that has very long runs.
125' from end to end.
My water supply will be roughly 50' and 75' away from the furthest fixtures...respectively.
My intention was to run a manifold system using copper manifolds with 1" inlets and soldered on 3/4" pex valve outlets.
(I found a couple made by Sioux Chief that fit the bill.)
Basically, each bathroom (two of them being the farthest points) and the kitchen (30') will have 3/4" pex supplies that branch as they arrive at the fixtures.
The Master Bath is obviously the most important, and is the 50' run.
Questions....
Am I overbuilding this thing?
Would 1/2" home runs be sufficient for speed of hot water to fixtures and pressure at fixtures?
Would the volume in 3/4" actually slow the delivery of hot water (from a Stiebel electric on demand)?
After a great thread years ago (by a plumber who is long gone) about Pex diameter, fittings, and pressure loss; I've been running 3/4" to everything with good results.
Just wondering what you experts think about this situation though.
Thanks in advance,
Jonathan
"Timid men prefer the calm of despotism to the tempestuous sea of liberty". Thomas Jefferson
BlueRidgeGreen is online now
Old 11-08-2019, 11:31 AM   #2
Mordekyle's Avatar
Rewards Points: 5,156
Re: Is 3/4" Pex Necessary?
Price difference?
Mordekyle is online now
Old 11-08-2019, 11:51 AM   #3
Fire up the BBQ
griz's Avatar
I always did the same, 3/4 on long runs.
Dont forget to run a circ line for the hot water.
griz is online now
Seven-Delta-FortyOne (11-08-2019)
Old 11-08-2019, 11:58 AM   #4
Trade: Craftsman
Originally Posted by Mordekyle View Post
Price difference?
Canít be that much.
Worth it if it beats those long runs.
Old 11-08-2019, 12:18 PM   #5
John the Builder
SmallTownGuy's Avatar
Rewards Points: 5,378
hmmm. Firstly, that you use electric.
Here, use gas almost exclusively. Two levels - one heater and furnace on each level. Shorter runs and less water cooling off in the supplies.
SmallTownGuy is online now
Old 11-08-2019, 01:13 PM   #6
Trade: Craftsman
Iíve used the Stiebel electrics a bunch.
They are great.
It will be great for this build because no one seemed to consider mechanicals AT ALL during the design phase and venting would be a PITA (and likely enrage their aesthetic sensibilities).
Levels?
Furnace?
Huh?
Old 11-08-2019, 01:15 PM   #7
Trade: Craftsman
The circ line is another issue.
Based on my research, it seems Iím better off just installing a small point-of-use under the Master Bath and forego trying to run a recirc with a tankless.
Old 11-08-2019, 01:38 PM   #8
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 1,690
One plumber I know use to run only 1/2 for the hot on long runs, not so much water to run before it got hot.
Randy Bush is online now
The Following 3 Users Say Thank You to Randy Bush For This Useful Post:
BlueRidgeGreen (11-08-2019), Mordekyle (11-08-2019), SmallTownGuy (11-08-2019)
Old 11-08-2019, 01:53 PM   #9
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 540
It's an electric tankless?
You (they) are going to be waiting a loooong time for hot water. With no re-circ, 75' runs, and an electric, or any tankless, and, yea, it'll be a wait.
I'd go with the 3/4 if you're doing a bathroom group on one home run. It would more than likely be required where I am anyway.
Old 11-08-2019, 02:01 PM   #10
Trade: Craftsman
Thatís exactly what Iím thinking.
But what do I lose in pressure?
Thatís why Iím thinking point of use for the Master using 3/4.....no worries at all.
Old 11-08-2019, 02:02 PM   #11
Trade: Craftsman
The Stiebel electrics are fantastic.
Iíve got a few operating on 40í + runs right now with zero issues.
I used to think the same thing.
The Following User Says Thank You to BlueRidgeGreen For This Useful Post:
Old 11-08-2019, 02:07 PM   #12
Trade: Highwayman
Rewards Points: 540
It's more a volume thing.
Pressure will be fine with one lav faucet running, it's when you get all 3 heads in the shower going and then someone flushes the WC.
Old 11-08-2019, 02:08 PM   #13
John the Builder
There'd have to be a compelling logistics issue here to spec tankless. Electricity is def not cheap in these parts.
Old 11-08-2019, 02:56 PM   #14
hdavis's Avatar
Rewards Points: 154
This is one of the few cases I wouldn't consider going with the minimum demand would require.
Shower heads get changed, flow restricters/aerators get changed, and next thing you know your plumbing sux.
If anything, oversize it. It costs way too much to redo later.
hdavis is online now
Old 11-08-2019, 05:28 PM   #15
tjbnwi's Avatar
Rewards Points: 20
I’d go with a small POU water heater fed from the tankless, 3/4 to 1/2 out unless there is a tub filler, then 3/4 to the tub filler.
tjbnwi is online now
Old 11-08-2019, 06:00 PM   #16
Trade: Craftsman
Originally Posted by tjbnwi View Post
Iíd go with a small POU water heater fed from the tankless, 3/4 to 1/2 out unless there is a tub filler, then 3/4 to the tub filler.
Thereís a tub filler.
I think Iím going to stick with the original plan of 3/4 to everything else also.
Old 11-08-2019, 06:01 PM   #17
Trade: Craftsman
I havenít installed a tanked WH in ...over a decade.
Old 11-08-2019, 06:47 PM   #18
dave_dj1's Avatar
Trade: general contractor
Rewards Points: 1,138
3/4" PEX isn't much if any larger than 1/2" copper, I wouldn't want 75' run with 1/2" copper. Maybe run a loop of 1" and tee off it where you need it?
dave_dj1 is offline
Old 11-08-2019, 06:53 PM   #19
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 2
I'm not a fan of tankless, but hey, that's just me.
Couple years back, we built a house with some pretty long runs, and used 1/2" CPVC to get the hot water there quicker (no high-volume demand). Inspector made us use 3/4" instead, and sure enough, it took forever and a day to get hot water at the point of use.
Fortunately, we never removed the 1/2" we ran initially. Once the 3/4" we added passed inspection, just flipped a couple of valves to use the original 1/2".
One thing to keep in mind is that 3/4" pex fittings effectively reduce flow to somewhere around 1/2" pipe due to their internal diameter. For really long runs, it might be a good idea to consider a circ pump either way.
Tinstaafl is offline
Old 11-08-2019, 06:54 PM   #20
Randy Bush's Avatar
I don't think you lose pressure, or very little, just volume. But I could be wrong too.
