2" Quarter Bend After P Trap - Plumbing - Contractor Talk
Old 06-26-2019, 01:50 PM   #1
Braga's Avatar
Trade: Designer
Hey guys, I've a question about this design: P trap + 2" quarter bend going down + 2" quarter bend connecting to the starter fitting (see pictures attached). Is this ok by code?
2" Quarter Bend after P Trap-screenshot_4.png   2" Quarter Bend after P Trap-screenshot_5.png
Braga is offline
Old 06-26-2019, 02:10 PM   #2
jhark123's Avatar
Trade: Pro Cat Herder
Rewards Points: 1,746
Re: 2" Quarter Bend After P Trap
IIRC it has to be a long sweep or a wye + 45 to lay on it's back like that (by code). However I doubt you would have a problem with just a sink connected. A wye + 45 would be nice as you could add a cleanout. Disclaimer: not a plumber by trade.
jhark123 is offline
Old 06-26-2019, 02:23 PM   #3
Braga's Avatar
Trade: Designer
Hi jhark123, thanks for replying. IPC (Table 706.3) allows me to have the quarter bend for drains up to 2". This is actually a bathtub. I am not sure about having those two quarter bends right after the P Trap. Here is a plan for clarification.
Braga is offline
Old 06-26-2019, 03:18 PM   #4
jhark123's Avatar
Is there a space constriction that is keeping you from using a long sweep?
jhark123 is offline
Old 06-26-2019, 03:28 PM   #5
Braga's Avatar
Trade: Designer
yes
Braga is offline
Old 06-26-2019, 04:40 PM   #6
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 312
Sorry, I can't make heads or tails out of that.......thing......you drew.
If you're talking about coming out of a sink and going down the wall, you have to use a San-Tee. Otherwise, you'll suction the trap.
Tougher Than The Rest.
Old 06-26-2019, 04:42 PM   #7
Trade: Highwayman
Rewards Points: 312
And what is a "starter fitting"? I've never heard of that.
Old 06-26-2019, 04:50 PM   #8
Braga's Avatar
Trade: Designer
fyi
2" Quarter Bend after P Trap-screenshot_7.png   2" Quarter Bend after P Trap-screenshot_8.png   2" Quarter Bend after P Trap-screenshot_9.png
Braga is offline
The Following 2 Users Say Thank You to Braga For This Useful Post:
MarkJames (06-27-2019), Seven-Delta-FortyOne (06-26-2019)
Old 06-26-2019, 07:23 PM   #9
Trade: Highwayman
Rewards Points: 312
Thanks. Never heard of that.
In the pic that I'm attaching, that would be a code violation where I'm at.
Do you see where the horizontal drain connects to the vertical waste stack? That can't be lower than the trap weir. Hence the use of a san-tee in that spot.
Old 06-26-2019, 08:06 PM   #10
Braga's Avatar
Trade: Designer
The manufactures have some other versions of this fitting to meet other's states codes.
Braga is offline
Old 06-26-2019, 09:25 PM   #11
rescraft's Avatar
Trade: residential remodeling/construction
Rewards Points: 1,401
Do I look like a CAD professor???
rescraft is offline
Old 06-26-2019, 11:23 PM   #12
Braga's Avatar
Trade: Designer
I don’t remember asking CAD questions. Or maybe I should tell you the difference between CAD and IPC... never mind.
Braga is offline
The Following User Says Thank You to Braga For This Useful Post:
Seven-Delta-FortyOne (06-27-2019)
Old 06-26-2019, 11:32 PM   #13
Renaissance Man
superseal's Avatar
Rewards Points: 5,828
Trap arm length needs to be 1.5 times the diameter of the pipe used and the vent take off must be above the trap weir. I would say what you have is a no go...
supersealconstruction.com
superseal is offline
The Following User Says Thank You to superseal For This Useful Post:
Old 06-27-2019, 09:22 PM   #14
The Grand Wazoo
KillerToiletSpider's Avatar
Rewards Points: 1,950
The starter fitting is individually vented, so there is no possibility of a s-trap, which is the reason for that code, there is no possibility of the trap being siphoned.
I may be going to hell in a bucket, but at least I'm enjoying the ride.
KillerToiletSpider is offline
Old 06-29-2019, 12:38 PM   #15
Mad Piper's Avatar
Trade: Plumbing
UPC - 1002.3 A trap arm shall be permitted to change direction without the use of a cleanout when such change of direction does not exceed 90 degrees (1.6 rad). All horizontal changes in direction of trap arms shall comply with Section 706.3.
Exception: For trap arms three (3) inches (80 mm) in diameter and larger, the change of direction shall not exceed 135 degrees (2.36 rad) without the use of a cleanout.
Mad Piper is offline
The Following User Says Thank You to Mad Piper For This Useful Post:
Rio (07-02-2019)
