Interior Steel Railing - Welding & Steel Trades - Contractor Talk
Old 05-16-2017, 06:19 PM   #1
3 Jacks 2 Nines
bwiab's Avatar
Trade: Wannabe Homebuilder
Rewards Points: 294
Installing an Interior Steel railing. Residential application. What do you think paint or powder coat? Seems to me powder coat always needs touch up and paint never quite matches. Can save 2k with paint.
bwiab is offline
Old 05-16-2017, 07:22 PM   #2
rustyjames's Avatar
Rewards Points: 1,774
Re: Interior Steel Railing
Paint, why waste money on powder coat? for an application like this paint will hold up fine.
rustyjames is online now
The Following User Says Thank You to rustyjames For This Useful Post:
bwiab (05-17-2017)
Old 05-17-2017, 01:11 AM   #3
VinylHanger's Avatar
Rewards Points: 11,528
My neighbor does wrought iron steel stuff. All I've ever seen him do is paint. Or at least the stuff I've seen is painted. Mostly exterior.
VinylHanger is online now
The Following User Says Thank You to VinylHanger For This Useful Post:
bwiab (05-17-2017)
Old 05-17-2017, 03:36 AM   #4
John1957's Avatar
Trade: Home Improvement
Rewards Points: 212
There are many great DTM paints out there. Touching up DTM is easier for a home & business owner than touching up powder coated surfaces.
John1957 is offline
The Following User Says Thank You to John1957 For This Useful Post:
bwiab (05-17-2017)
Old 06-29-2018, 09:53 AM   #5
Castle Railings's Avatar
Trade: Custom Metal Work
Rewards Points: 34
For an indoor application, I would say metal primer and paint is ok if you want a life expectancy of say 5-10 years with normal use. You will most likely need to touch up low gloss areas and scratches within that time frame though.
For an indoor/outdoor railing application requiring a high performance coating that is guaranteed to last 10+ years. I would recommend a zinc rich primer coat followed by a polyester blend powder coating. This type of coating is designed to pass AAMA 2603. https://www.tcipowder.com/architectu...-coatings.html
FYI, I use powder on all my railing projects..
http://www.castlerailings.com
Castle Railings is offline
Railing Question redwood Decks & Fencing 14 09-15-2015 05:48 AM
Mahogany porch railing mk5065 Specialty Coatings 2 06-09-2013 09:40 PM
Deck Railing FinishingEdge Decks & Fencing 27 11-04-2012 05:09 PM
DO i need to raise the railing height if i add benches along the railing? maleko Decks & Fencing 21 09-26-2011 09:22 PM
