Can You Recommend A Welder For Sheet Metal Repair ? - Welding & Steel Trades - Contractor Talk
Old 12-19-2015, 07:20 PM   #1
plazaman's Avatar
Rewards Points: 1,206
I have a very unique situation here . First of all, I am not a professional welder, but I do own a Lincoln Electric AC225s Arc Welder .
I am in a middle of a Brownstone Renovation where I am stripping paint off of a metal cornice on the exterior and repainting . However, there are a few quarter size holes that have rusted out . I just don't want to fill it bondo, but cut the rust out and weld a new piece into place .
Question is , can I purchase a cheap Harbor freight welder to do this or even use my stick welder ?
plazaman is online now
Old 12-19-2015, 08:21 PM   #2
TimelessQuality's Avatar
Trade: GC/Remodeling
Rewards Points: 1,730
Re: Can You Recommend A Welder For Sheet Metal Repair ?
A cheap mig could do it, but tig makes a more workable weld...
Have an oxacetylene outfit? I'd gas weld it myself
-Steve
TimelessQuality is offline
Old 12-19-2015, 08:25 PM   #3
Easyfier of Complexitries
digiconsoo's Avatar
Trade: Framing Components
Rewards Points: 1,552
Are you set on welding?
I've used this in similar situations, and blind rivets work fantastic and if done right will last as least as long as it has thus far.
http://www.eastwood.com/ew-no-weld-p...FVQYHwodaeQIUw
Welding upside down or from scaffolding isn't as easy as welding something on a welding table.
If you have the skill to do it, go for it, I don't believe that it would be a better repair, just different.
Originally Posted by hdavis View Post
It's probably better you write about something where you aren't functionally ignorant, you're just embarrassing yourself.
Originally Posted by tipitop View Post
Trump is lucky he didn't mess with me.
http://www.digiconsoo.com
digiconsoo is offline
Old 12-19-2015, 08:30 PM   #4
Peter_C's Avatar
Trade: Home Beautification
Rewards Points: 412
Stick welder is a no go. HF welder without a shielding gas will most certainly blow right thru it. It will take a decent welder to get the heat and feed set correctly, unless you dot the welds along. Brazing torch might be the best option with a brass rod, EXCEPT: DO NOT WELD ON GALVANIZED METAL, without a fresh air system or scuba tank.
Honestly, I would look into an epoxy repair, like JB Weld after removing the rust. Be careful to not breathe any grinding dust from galvanized metal.
Peter_C is offline
Old 12-19-2015, 08:59 PM   #5
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
back in the day sheet goods were often soldered
http://www.gsa.gov/portal/content/111750
Tom Struble is offline
The Following 3 Users Say Thank You to Tom Struble For This Useful Post:
mikeswoods (12-20-2015), Peter_C (12-19-2015), Railman (12-20-2015)
Old 12-19-2015, 09:29 PM   #6
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 5,250
I would try to fill with a 50/50 bar or something similar.
You start striking an arc on old ass tin cornice and you will quickly be fixing 5x what you started with.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is online now
The Following 4 Users Say Thank You to WarnerConstInc. For This Useful Post:
brhokel606 (12-20-2015), griz (12-19-2015), mikeswoods (12-20-2015), muskoka guy (12-20-2015)
Old 12-19-2015, 09:49 PM   #7
Peter_C's Avatar
Rewards Points: 412
Okay school me on what a 50/50 bar is please. Cause all I can find is the Urban Dictionary description.
"50 50 bar:
A term used to describe a turd poop that comes out half diarhhea and half formed.
"I just left a 50/50 bar in that toilet."
Or...
I agree 100%! Even with a TIG welder. Not a good place to be learning.
Edit: Found it. Not going to find that in California...lead.
http://www.grainger.com/product/WORT...UDED-BAR-5EGA7
Might be best to sub it to a sheet metal worker.
Peter_C is offline
Old 12-19-2015, 10:05 PM   #8
Philament's Avatar
Trade: Whatever the customer wants
Rewards Points: 2,182
50% Tin, 50% lead solder. Commonly used on flat seam metal roofing and tin cornice miters and repair work.
Philament is offline
Old 12-20-2015, 09:41 AM   #9
plazaman's Avatar
It looks like that no weld pair kit would do the trick .
What torch would I use that 50/50 with ?
Old 12-20-2015, 09:48 AM   #10
Philament's Avatar
I've only ever used a soldering iron. Scuff the mating surfaces with sandpaper, brush on a little paste flux, solder, then wipe the flux with a damp rag when cooled or use spray flux remover.
Old 12-20-2015, 12:30 PM   #11
Trade: siding
Rewards Points: 20
that link i provided will tell you how to do copper or steel
Old 12-20-2015, 06:12 PM   #12
Box Builder
Morning Wood's Avatar
Rewards Points: 9,426
Solder it would be good. Acetylene, propane, map gas will all work
Morning Wood is offline
The Following User Says Thank You to Morning Wood For This Useful Post:
Old 12-20-2015, 10:44 PM   #13
plazaman's Avatar
I have mapp gas, maybe I'll try that .
So am I using the solder as filler? Or am I soldering a piece of metal to it ? Remember this is metal tin cornice in a vertical application . It's hollow behind it .
Old 12-21-2015, 06:22 AM   #14
Trade: siding
Rewards Points: 20
soldering sheet metal takes some knowledge and skill,especially if your going to try it with a torch..i would suggest leaving the torch at home
rustyjames (12-21-2015)
Old 12-21-2015, 10:55 AM   #15
CarpenterSFO's Avatar
Rewards Points: 2,044
Soldering is easy; if you've sweated copper pipes you can do it. You don't need 50/50, though you can get it, including in California. Lead free from a body shop supplier wd be fine: http://www.eastwood.com/lead-solder-...al-information, or lead-free plumbing solder would be perfectly fine for a small patch. The disadvantage of lead free is that it's more expensive, and that it may be more likely to break under stress, if not done as well. Neither of those considerations matters for a small patch. The secret is - as with all soldering - to get perfectly clean metal, flux where you want the solder to go, and have the piece clamped, riveted or held tightly in place, while heat then apply the solder.
If you think you're going to start a fire, don't do it (or use some old soldering irons (which really requires a helper and a bigger torch to heat them)).
.... or just bondo or epoxy a patch. For a 1" patch, just about anything would do. For me the question would be whether the surrounding area would stand up to the sanding or grinding necessary to get to clean metal for soldering.
- Bob
CarpenterSFO is offline
Old 12-21-2015, 11:25 AM   #16
rustyjames's Avatar
Rewards Points: 1,618
And once it's been contaminated with lead forget welding over it.
rustyjames is online now
Old 12-21-2015, 03:55 PM   #17
Pro or somethin'...
Anthill's Avatar
Trade: Tinwoodman
Rewards Points: 1,258
Certainly don't try to solder sheet tin with a torch. It will warp and burn and leave you a big mess. Save that for copper or brass. If you get the heat right on a properly tinned iron, it would be quite doable though. Tin takes solder very easily if its clean. Cut muriatic acid makes a good flux. Any tin solder will work, though 50/50 melts at a lower temp as is a little easier to work with.
Anthill is offline
The Following User Says Thank You to Anthill For This Useful Post:
Tom Struble (12-21-2015)
Old 12-21-2015, 03:57 PM   #18
I like Green things
50/50 is the easiest and best.
Soldering with the lead free crap is nearly impossible
I have several old copper irons, and a few homemade spoons I use.
Warner Mill Works
Facebook
YouTube
Old 12-21-2015, 05:40 PM   #19
Trade: siding
Rewards Points: 20
..no..that is not the ''only secret''op says it was rusty so i'm assuming it's tin
Old 12-21-2015, 05:49 PM   #20
madmax718's Avatar
Trade: General
Rewards Points: 3,272
If you have quarter sized rust holes, most likely the surrounding areas is also thin and weak. You'd blow holes like crazy. I dont know what your working on but avoid butt welds. Flange the edges, do a template, cut from new metal, punch holes. Weld through primer, then you can use a flux mig.
If you do use a cheap harbor freight mig, re-clean the ground clamp and bolt, and replace the stock wire with something better. Innershield works well.
http://www.harborfreight.com/air-pun...tool-1110.html
Try not to go too thick on the metal sheeting. The metal punch has a limit. 16ga is what its rated to.
However, if you have access through the back, get a copper backer blank, and go at it with your stick, 1/16th if you have. you cant blow through the copper, so it actually works out quite well.
madmax718 is offline
Metal shingle repair - Any experience? dDubya Roofing 11 05-25-2015 07:20 AM
240 for a welder farmerkev Electrical 30 12-13-2014 07:39 AM
MA Sheet Metal License RenaissanceR Contractor Licensing 6 08-31-2011 04:52 PM
Cutting 29ga metal corrugated panels (metal roofing panels) gnxtc2 Roofing 7 02-15-2011 02:51 AM
Corrugated metal fence stanfordconst Decks & Fencing 2 05-31-2010 12:38 PM
