Temporary Construction Barrier Wall System - Commercial Construction - Contractor Talk
Old 02-15-2016, 10:26 PM   #1
HFHConstruction's Avatar
Rewards Points: 24
Hey guys,
Im interested in temporary barrier wall systems for commercial construction. The problem is i havent found alot of information on them and am curious about the costs of purchase Vs. rental or lease. Its not a huge area but it is tantamount to construction that the barrier be in place as it is in a place that will be occupied during construction.
any suggestions?
Halp plaise
HFHConstruction is offline
Old 02-16-2016, 10:47 AM   #2
rustyjames's Avatar
Rewards Points: 28
Re: Temporary Construction Barrier Wall System
We've done it with light weight metal studs on OSB.
rustyjames is online now
Old 02-16-2016, 02:40 PM   #3
SuperiorHIP's Avatar
Trade: Home Improvement Contractor
Rewards Points: 1,450
https://www.fastcap.com/estore/pc/3rd-Hand-c46.htm
I have a set of these with their dust barrier doors. Similar to zip wall but way higher quality and cheaper too. Their doors use magnets instead of zipper, lots of options.
SuperiorHIP is offline
Old 03-23-2016, 06:06 AM   #4
zabbo's Avatar
Trade: Union Carpenter
Rewards Points: 12
Look into stark wall system. We use it all the time in operational hospitals.
zabbo is offline
Old 03-30-2016, 07:52 PM   #5
ubcguy89's Avatar
Trade: carpenter/ interior systems
Rewards Points: 742
In hospitals where we need to acquire negative air pressure, get the HEPA machines running.... We usually build then it of steel studs and drywall, throw a temp door on and run our exhaust right through the wall with a simple drywall damper to cut the air flow down. Then 6 mill plastic above ceiling height.
ubcguy89 is offline
Old 06-18-2016, 10:06 PM   #6
BlueNails's Avatar
Rewards Points: 40
We have used this system lately on a few sensitive workspace jobs - it's super easy, fast and looks good.
http://www.powerpac.co.nz/shop/Onsit...Solutions.html
BlueNails is offline
New block construction question(s) TLHWindows Construction 2 01-31-2014 01:42 AM
Exterior wall covering options? bob_cntrctr Construction 8 02-25-2013 08:05 AM
Double wall construction shaggywaggle Construction 11 02-15-2012 09:39 AM
Thoughts On Construction of Block Wall - Look at Pictures EricAnderson Masonry 36 09-17-2011 12:30 AM
ICF vs ZIP System Wall thx10 Construction 3 01-30-2009 08:03 PM
