R21 Insulation - Commercial Construction - Contractor Talk
R21 Insulation
Old 08-25-2019, 08:52 AM   #1
Thread Reading Aficionado
Builders Inc.'s Avatar
Trade: Certified Building Contractor
Rewards Points: 1,458
R21 Insulation
At what scenario, in walls, is R21 high density fiberglass insulation used over R19?
Builders Inc. is offline
Old 08-25-2019, 09:25 AM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 752
Re: R21 Insulation
when you want a higher r value.
or when the energy calcs call for it.
griz is offline
Old 08-25-2019, 10:32 AM   #3
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 2,052
Re: R21 Insulation
I would use the R-21 regardless.
Randy Bush is offline
The Following User Says Thank You to Randy Bush For This Useful Post:
ScipioAfricanus (08-25-2019)
Old 08-25-2019, 12:35 PM   #4
Re: R21 Insulation
Well here’s the scenario. We work off of a consultant xactimate scope, bid it sight unseen and what was there was R19 and the consultant wrote R21. I bought R19. R19 is 6.25”. The walls are metal stud 2x8 on first floor and 2x6 from there up. The R21 insulation is spec’d for light gauge metal studs 5.5” the consultant wrote it wrong from being like kind material. We now have to do a deductive change order since the consultant spec’d the wrong pre existing material. From a municipal stand point for cost effectiveness and why would an architect would spec using R21 when there wouldn’t be a need for the “high density” feature of R21. From a comfort aspect I seriously doubt you could feel a difference in R21 vs R19 in a finished space other than your wallet or budget. I screwed up ordering R19 and just glanced at the 6” line item in the scope but the estimator screwed up in adding R21 to the scope instead of looking and seeing it actually had R19.... either way the customer is ok with us using R19=what is there previously.
The Following User Says Thank You to Builders Inc. For This Useful Post:
hdavis (08-26-2019)
Old 08-25-2019, 11:27 PM   #5
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 9,405
Re: R21 Insulation
With metal studs bridging the space between your sheathing and Dry wall your wall averages about R8.6 with 24 C to C studs and R19 glass,,, R9.0 with R21 glass
Install a layer of 0.5" ANYTHING on the outside and you are a Genius.... And no silly tear outs.
Fouthgeneration is offline
Old 08-26-2019, 06:13 AM   #6
General Contractor
greg24k's Avatar
Rewards Points: 8,480
Re: R21 Insulation
If you using high-density insulation... R-21 id for a 2x6 wall.
If you want to achieve R-21 in a 2x4 wall you have to use Polyurethane Rigid foam insulation which comes anywhere from R-18 to R-28 and it's 3 1/2" thick or use spray foam insulation.
greg24k is offline
Old 08-26-2019, 04:30 PM   #7
Trade: Masonry
Re: R21 Insulation
Greg24K: You can't achieve R-24 with a 2 x 4 steel stud framed wall with the "steel" short circuiting the heat flow between the dry wall / exterior product.
Two inches of foam mounted across the studs on the exterior, and some fiber glass for sound control?
R-15 fiber glassed metal studs = ~7.8 R value for the whole panel....24" spacing, 6.4 R value for 16" C to C studing.
The Following User Says Thank You to Fouthgeneration For This Useful Post:
greg24k (08-27-2019)
Old 08-27-2019, 05:41 AM   #8
General Contractor
greg24k's Avatar
Re: R21 Insulation
I was referring to wood studs before he made a follow-up post (I just saw it) where he mentioned metal studs.
I never use metal studs and the only time I used them is when I was doing a commercial job (25 years ago) and we didn't use insulation (it was between 2 stores) so I'm not really familiar with insulation methods when it comes to metal framing.
greg24k is offline
Fouthgeneration (08-27-2019)
