Partition Wall Under Drop Ceiling - Page 2 - Commercial Construction - Contractor Talk
Old 02-13-2017, 07:42 PM   #21
LooseScrews's Avatar
Trade: Handyman
Rewards Points: 26
Re: Partition Wall Under Drop Ceiling
Originally Posted by slowsol View Post
Hard to see in this pic, but basically this.
Thanks for that. It's kind of hard to see there. But that diagonal stud is attaching to the back side of the channel that is screwed to the T-grid? Also, what did you use to attach that stud to the steel truss?
Here's the plans...
For some reason, I can't upload the other images that have the specifications spelled out. Not sure what's going on there. I have tried converting to jpg and png and it won't accept the upload.
LooseScrews is offline
Old 02-13-2017, 07:48 PM   #22
Trade: Handyman
Rewards Points: 26
-The sprinkler heads are a non-issue, the walls are not interfering with their coverage.
-One light is getting moved over 2 tiles, that's all that's needed.
An electrician will take care of moving the light over and hanging an Exit light and installing the outlets and switches.
As far as I can tell, I just need to make a couple strong walls that don't shake when someone slams the door. And skim coat 1400 sq/ft of textured drywall... my shoulders are complaining already.
Thanks to everyone who has posted so far, I really appreciate the insight as this is unfamiliar territory to me and you are really helping me a lot.
Old 05-24-2017, 12:04 AM   #23
Milesjcoker's Avatar
Trade: Residential construction and remodeling
Rewards Points: 60
Here's the plans...
Existing ceiling grid to remain, accommodate for new wall.
I take that to mean full height wall, but I could be wrong. Ask the architect.
Milesjcoker is offline
Old 05-24-2017, 02:31 AM   #24
General Contractor
greg24k's Avatar
Rewards Points: 7,944
Check the code, if the area is over 1000 SF you will have to do a fire separation above the drop ceiling, so one of the partitions you will have to run to the roof line or do a drop ceiling to roof line separation.
greg24k is offline
Old 05-24-2017, 06:07 AM   #25
Trade: Handyman
Rewards Points: 26
This job got finished a while ago. Thanks to all for input, especially slowsol.
Partition wall under drop ceiling-20170227_160525_1495623596273.jpg   Partition wall under drop ceiling-20170319_185732_1495623775927.jpg   Partition wall under drop ceiling-20170319_185739_1495623887990.jpg
Old 06-02-2017, 11:44 AM   #26
ktmrider's Avatar
Trade: carpentry
we use grid clips,they clip on grid than screw to track,they are good so you don't mess up the grid if the wall ever gets moved,we just use them to hold the wall up until we get kickers on it, cause our code says walls and ceilings have to be independent,we usually have a spec on our print for kicker detail.to finish top of drywall off just use tear away trim,
ktmrider is offline
Old 11-08-2017, 02:00 PM   #27
Danno1212's Avatar
I typically will attach the top track to the ceiling grid than add a few kickers to the top of the track to building steel. I have built miles of wall this way and never had a problem.
Danno1212 is offline
Old 11-10-2017, 10:37 PM   #28
MeanWeen's Avatar
Trade: City worker
Rewards Points: 28
Looks like a nice job, good thing it was accepted as your print says full height studs.
MeanWeen is offline
Old 12-30-2017, 06:54 PM   #29
cnstrctr's Avatar
Trade: General
Rewards Points: 38
Builditguy - props to this response - it was by far the best and most cohesive, all of your points make complete sense. The recommendation on the tearaway is great.
Originally Posted by builditguy View Post
We do this. At least 2 jobs per year.
#1 Screw the top plate to the grid. Not my favorite way to do it, but if that's what the owner and the architect want, it's not my place to argue. I don't like the holes in the grid. They are thinking they can change the walls if it get rented to a new tenant. I'm just thinking, there's holes in the grid.
I do like a kicker to the top of the wall, but that is never specd. If I do it, it's on my own. Architect never details that.
#2 I use tearaway bead at the top. There are times they don't even want us to tear it off. They say to leave it. It looks fine and lets face it, it's commercial, nobody even notices.
#3 The sprinkler system will need to be addressed. It is possible all of the heads will hit where they are supposed to hit. Maybe not, but unless it is your job to do the sprinkler system, then it's not your problem.
#4 HVAC. Usually there needs to be some shifting of the ducts. Unless you are the HVAC contractor, this does not affect you.
Don't forget cold air returns. Again, unless you are the HVAC contractor, not your problem.
#5 Lights. They usually need to be shifted as well.
$6 Egress and emergency lighting will need to be checked. But....that is for the architect to figure out. The emergency lighting is also for the architect to figure out. The electrician will just put it in the location the architect specifies.
There are all kinds of arguments that this or that should be done. The reality is they hired an architect and got an inspector to sign off on the changes. It's your job to do what they want.
cnstrctr is offline
Old 12-30-2017, 08:00 PM   #30
scottktmrider's Avatar
Trade: carpenter/drywall
Rewards Points: 295
I don't know why you would not use grid clips so you don't have to screw into the ceiling
scottktmrider is offline
How to access drop ceiling and fixtures 30' above ground DoBo Tools & Equipment 7 10-22-2016 04:55 PM
Help with weird crown molding angle where wall and ceiling ends Dannyboi Carpentry 9 05-30-2016 10:05 PM
Drop ceiling question MarcP Remodeling 10 04-19-2013 06:51 PM
Renovating A Commercial Building : Concrete Block Walls, Drop Ceiling questions SWConstruction Commercial Construction 27 09-08-2010 08:57 PM
estimating costs of a drop ceiling Jean K General Discussion 3 12-28-2009 07:53 AM
