Need Ideas - Commercial Construction - Contractor Talk
Need Ideas
Old 05-04-2017, 10:43 PM   #1
Fire up the BBQ
griz's Avatar
Rewards Points: 1,854
Need Ideas
Tasked with renovating almost 200 lineal feet of 5' wide hallway circa 1956 motif.
Standard 4-6-8 black grooved paneling...
with 8' ceiling height....
Need to abate carpet over asbestos tile.
THE WALLS??????
4' high tackboard with a nice moulding,....
Every 16' or so a 4-8' wide floor to ceiling tackboard for the bulletin board effect....
Ceiling is funky azz acoustic tile....
Fix with 2' x 2' LED fixtures turned 90 deg from sq,
What to put from tackboard to ceiling??????
I think drywall is out due to budget but haven't fought that battle yet....
existing door casing also comes in to play.....
I am the designer, architect, engineer and GC....
This sucks.....
griz is online now
Old 05-04-2017, 11:09 PM   #2
Bull Trout's Avatar
Rewards Points: 492
Re: Need Ideas
Doesn't the floor to ceiling tack board go to the ceiling?? :p
Bull Trout is offline
Old 05-05-2017, 08:57 AM   #3
hdavis's Avatar
Rewards Points: 1,710
Re: Need Ideas
If you skim the paneling, you can always paint or wallpaper that part.
hdavis is online now
Robie (05-05-2017)
Old 05-05-2017, 09:07 AM   #4
Fire up the BBQ
griz's Avatar
Re: Need Ideas
Tackboard is like a wainscoting at 4' high except at floor to ceiling bulletin board condition.
yes good idea, may end up beiny the easiest.
Ive been trying to come up with a thin sheet goods, like frp but not frp.
griz is online now
Old 05-05-2017, 10:19 AM   #5
VinylHanger's Avatar
Rewards Points: 9,926
Re: Need Ideas
If a skim coat will stick, it is always the easiest in this situation. It also doesn't change the reveals very much.
VinylHanger is offline
Old 05-05-2017, 10:27 AM   #6
Fire up the BBQ
griz's Avatar
Re: Need Ideas
Yea, skim coat sticking is a concern. That old paneling is shiny and smooth.
I may try a small section, scuff it and wipe it down with lacquer thinner.
griz is online now
Old 05-05-2017, 11:04 AM   #7
Radical Basement Dweller
Robie's Avatar
Rewards Points: 2,310
Re: Need Ideas
B-I-N first.....
Robie is online now
illbuildit.dd (05-05-2017)
Old 05-05-2017, 01:01 PM   #8
hdavis's Avatar
Re: Need Ideas
On something like this, you never get the grooves cleaned out. You can get a surface clean on the rest of it. If it has been painted or sealed in some way, I treat it just like paint prep. Acetone dries too fast for me to really do a clean on that ~1600 sqft wall fast. Denatured alcohol works pretty well, sometimes diluted - it depends how fast you can work. I'll do 1600 sqft in about 30 minutes.
Adhesion in the grooves is likely going to be the issue. They may need pigmented shellac sprayed into them. I haven't tried the shellac replacements to say whether they would work or not, but shellac is the only thing I've ever tried that will stick to crayon wax.
griz (05-05-2017)
Old 05-05-2017, 03:52 PM   #9
Dave in Pa's Avatar
Trade: restoration/remodeling
Rewards Points: 1,272
Re: Need Ideas
I would be concerned about the carpet over asbestos, is it glued down? We don't touch anything with asbestos involved at work, have the proper protection and training there! I do Restoration work, if we pull a carpet and see asbestos tile/or think it is, we STOP, and get it tested/call the Insurance adjuster, and go from there!
And what do you mean by the 2x2 LED fixtures, turned 90 degrees from square???
Dave in Pa is offline
Old 05-05-2017, 05:35 PM   #10
hdavis's Avatar
Re: Need Ideas
He means they'll be in rotated on a 45 degree (no 90 that just makes it look the same).
Old 05-05-2017, 06:47 PM   #11
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,261
Re: Need Ideas
Naw, you just hang 'em by one edge. 90.
Tinstaafl is online now
The Following 2 Users Say Thank You to Tinstaafl For This Useful Post:
griz (05-05-2017), hdavis (05-05-2017)
Old 05-05-2017, 10:38 PM   #12
Fire up the BBQ
griz's Avatar
Re: Need Ideas
carpet is set as an abatement project.
the light fixtures....instead of two sides being parallel with the walls i want them to be at 45deg.
My architectural license.....
griz is online now
Old 05-05-2017, 10:40 PM   #13
Fire up the BBQ
griz's Avatar
Re: Need Ideas
there is no applied coating on the paneling.
The black edges in the grooves is already rough from the factory.
I really want to find a sheet good to cover this mess....
griz is online now
hdavis (05-06-2017)
Old 05-05-2017, 10:52 PM   #14
back doors to hell put in
Irishslave's Avatar
Rewards Points: 1,648
Re: Need Ideas
If you are going to abate the asbestos why not gut the entire hallway? Skim coating just doesn't work somehow....If you can get paint to adhere maybe some rich color scheme with some simple trim features might work...What's underneath the paneling...a good substrate?....
Television is fake...The internet is real
Irishslave is online now
Old 05-06-2017, 12:17 AM   #15
House surgeon
illbuildit.dd's Avatar
Trade: building/remodeling
Rewards Points: 2,078
Re: Need Ideas
Floating paneling can on occasion turn into a nightmare. Like Irish said, I'd check what's under it or cover it like you mentioned. Or spruce it up with some fancy trim and get a great painter to glaze it or just repaint. Might also check with a decorator as to what is currently the "in" thing for an easy way out. Works for me.
illbuildit.dd is offline
Old 05-06-2017, 08:22 AM   #16
hdavis's Avatar
Re: Need Ideas
1/8" hardboard is about the thinnest you can get that will hold up. You still have to deal with the seams - works well with a paneled look.
1/4" drywall, if the paneling is tight to the wall.
Old 05-06-2017, 07:29 PM   #17
Irishslave's Avatar
Re: Need Ideas
Griz, aren't you getting a little old for this stuff? Seems to me like the older I get the more expensive I get. Seems the world is going the opposite direction and everyone wants the Amazon.com fix.
Anything worth doing is worth doing right...if it's been up there for 60 years and they want a new look...it's time to bring in the dumpster and the wrecking tools
The Following 3 Users Say Thank You to Irishslave For This Useful Post:
griz (05-06-2017), rselectric1 (05-06-2017), Tom M (05-06-2017)
Old 05-06-2017, 08:02 PM   #18
Fire up the BBQ
griz's Avatar
Re: Need Ideas
I'm still a kid at heart.....just dont know any better....
The project is for the school district. Also included in turning a mens and womens bath area into two unisex and 1 ADA compliant restroom.
This is also an abatement due to hot drywall, mud & floor.
They just want me to "fix it"....
I told them just guessing we are north of a 100 grand on costs....
There wasn't a scream but a audible gasp.....
They told me to keep going and to try and contain costs as much as possible.....
My ace in the hole is to get the women in the office involved.....
no one in their right phucking mind wants a bunch of chics pissed off that they have to work with everyday.....
griz is online now
Irishslave (05-06-2017)
Old 05-06-2017, 09:01 PM   #19
hdavis's Avatar
Re: Need Ideas
Anything worth doing is worth doing right...if it's been up there for 60 years and they want a new look...it's time to bring in the wallpaper
fify
Old 05-06-2017, 09:12 PM   #20
FrankSmith's Avatar
Rewards Points: 5,124
Re: Need Ideas
Got a picture for us?
FrankSmith is offline
Help with ideas, Patio roof kambrooks Carpentry 28 10-09-2012 07:13 PM
Help on Ideas for remodel needed please unhique Architecture & Design 17 06-24-2012 05:06 PM
Ideas on for setting cap Captainsls Masonry 15 05-10-2012 09:43 PM
Practical GREEN ideas that don't cost much, part 1. wackman General Discussion 24 03-15-2010 06:52 PM
