Liquid Applied Waterproofing Membrane - Commercial Construction - Contractor Talk
Old 11-14-2013, 09:08 PM   #1
designer + carpenter
NINZAN STUDIO's Avatar
Trade: carpentry
Rewards Points: 510
I work for a design-build company. We spec and use Vulkem 350/351 for waterproofing concrete slabs, most of the time when they're elevated above A/C space or roof decks. What products are you guys using / seeing spec'd for similar application?
NINZAN STUDIO is offline
Old 11-14-2013, 09:33 PM   #2
Renaissance Man
superseal's Avatar
Rewards Points: 5,838
Re: Liquid Applied Waterproofing Membrane
The Vulkem 350/351 system is top notch although it's pretty nasty to your brain cells. I use it on balconies and I wouldn't change a thing.
I have used ThoroCoat f74 and Tuf trac in the past for certain things similar, but Vulkem is superior IMO.
You thinkin' of changing up?
supersealconstruction.com
superseal is offline
Old 11-15-2013, 12:52 PM   #3
Trade: carpentry
Rewards Points: 510
Thanks for reply. No, I just wanted to see if there was a better method or something similar performance wise.
Old 12-12-2013, 09:40 PM   #4
Endre27's Avatar
Trade: Commercial building
Hello all ! I was wondering if anyone has a suggestion for an iPhone app that is great for material/ cost calculation? I've seen 1 or 2 but there are no reviews and I don't trust that!
Endre27 is offline
Waterproofing and parging OVER the membrane above grade... Johntoronto Masonry 11 09-24-2019 04:13 PM
blue max waterproofing membrane Ceezz Construction 2 07-31-2013 07:42 AM
Surface waterproofing membrane Aaron Tritt Tiling 1 06-10-2011 06:22 AM
Hydroment Waterproofing membrane(Bostic Findley Manufacturer) vs rubber membrane ewarch Kitchens & Baths 0 08-21-2007 12:20 PM
