Deep Pit Excavation - Page 2 - Commercial Construction - Contractor Talk
Deep Pit Excavation
Old 06-10-2019, 11:09 AM   #21
taz1234's Avatar
Trade: c-12
Rewards Points: 14
Re: Deep Pit Excavation
Thank you all for your responses. The consensus seems to be that this hole should be shored. What if the sides were at 3:1 (18 degrees), do you still need shoring? How about if one side was at 3:1 to allow equipment to "drive-in", could this be dug with scrapers?
I am trying to figure out the most economical way to dig this hole (excavation part only). The site is in a rural area and the spoils will be stockpiled nearby just outside the hole.
taz1234 is offline
Old 06-10-2019, 12:50 PM   #22
hdavis's Avatar
Rewards Points: 1,514
I'm out.
hdavis is online now
Seven-Delta-FortyOne (06-10-2019)
Old 06-10-2019, 01:35 PM   #23
tgeb's Avatar
Trade: Excavation, Foundation, Professional Painter!
Rewards Points: 774
Originally Posted by Fishindude View Post
You can either bench it per OSHA, slope it per OSHA, or use some type of sheet pile or shoring system which requires an engineer to design.
From an earlier post.
www.gebcon.com
tgeb is offline
The Following User Says Thank You to tgeb For This Useful Post:
Fouthgeneration (06-10-2019)
Old 06-10-2019, 04:27 PM   #24
VinylHanger's Avatar
Rewards Points: 9,870
Jeez. I think you need to call someone who is local and does this for a living. A hole this size? Most economical isn't really the word you are wanting.
Safe and low liability would be my first thoughts.
What have the local professionals you must have called told you. That it will be expensive? That it isn't as easy as getting a bigger shovel?
This would be like me asking how to build a 10 story highrise and then asking on here how to most economically do it.
Lots of steps you are missing.
VinylHanger is offline
The Following 4 Users Say Thank You to VinylHanger For This Useful Post:
Bull Trout (06-10-2019), Fouthgeneration (06-10-2019), griz (06-10-2019), tgeb (06-10-2019)
Old 06-10-2019, 10:08 PM   #25
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 2,040
Home Depot has one of these. Pretty cheap, too.
Bang it out in a few hours, none of that safety S$#! needed.
Get Off My Lawn.
"There are no big projects. There are only small machines". - R. G. LeTourneau
SmallTownGuy (06-11-2019)
Old 06-11-2019, 02:42 AM   #26
Yeah, isn't that a Ryobi product?
The Following User Says Thank You to VinylHanger For This Useful Post:
Seven-Delta-FortyOne (06-11-2019)
Old 06-11-2019, 06:33 PM   #27
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 8,051
7-D, 4-1: Some large draglines don't have 'Prime' movers, but use High voltage transformers near the work area.....
The OPer would have to find out if the correct electrical supply was available for an electric powered solution....
To below: YODO! get a pro on the shoring....
Fouthgeneration is offline
Old 06-11-2019, 06:37 PM   #28
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 3,694
Just do it, YOLO!
Big Johnson is offline
Old 06-11-2019, 07:02 PM   #29
John the Builder
SmallTownGuy's Avatar
Rewards Points: 7,128
Oh hell yaaaassss !!!
SmallTownGuy is online now
Old 06-11-2019, 08:57 PM   #30
Trade: Highwayman
Oh My Gosh. You don't say.
That's a picture of Big Muskie. It was the largest walking dragline in the world, until it was dismantled in the late '90's.
My post was meant as sarcastic humor, with a bit of hyperbole thrown in, in order to make a point, that the OP might be in a bit over his head.
I was not seriously suggesting that HD rents a 27 million pound excavator that no longer exists. But now that I've seen your sig line, I'll be sure to speak very slowly, and use only small words with lots of those funny little yellow faces.
Get Off My Lawn.
Old 06-11-2019, 09:53 PM   #31
Trade: Masonry
The "Big Muski" ran at night as much as possible to get cheaper electricity....
It was larger in EVERY dimension then The OPers Hole would be....
At 140 yards a bucket full, 30 scoops = one hole, more or less....
If you under claim intelligence, you disappoint far fewer people, IMHO.
An extraordinary bright Idiot, or a sub- par Genius?
The Following User Says Thank You to Fouthgeneration For This Useful Post:
Old Today, 03:34 PM   #32
Snobnd's Avatar
Trade: Remodeling 30+ yrs
Rewards Points: 3,822
Just be careful or you might end up with more dirt than you expect!
https://www.liveleak.com/view?t=ul5UE_1560166924
The Following User Says Thank You to Snobnd For This Useful Post: Leo
Snobnd is online now
