A Couple Question About Fire Protection Sprinkler Systems - Commercial Construction - Contractor Talk
Old 01-21-2018, 12:19 PM   #1
Bearcat1's Avatar
Trade: Commercial Construction
Rewards Points: 2
I have a question about the different types of valves related to a sprinkler system for a commercial building. I don't need to do anything with them, but would like to know for my own knowledge, as I deal with sprinkler contractors at work and need to sound like I know what I'm talking about.
The main valves I know of and what I believe they do are the:
PIV (Post Indicator Valve): This is basically the main shut off for the entire building, that is outside the building. This is mostly for the fire department, but I notice that sometimes sprinkler guys will shut this off if they need to drain the system, and sometimes not.
Fire control Valve: As far as I can tell, I think this does the same thing as the PIV, but may be more for sprinkler guys to use. This is normally inside with the riser, but can also be on the exterior on the other side of the wall
Drain Valve: This is always on the riser, this is the main drain that drains the entire system
Flow Switch: This is an electric sensor that detects water flowing in the riser and sends a trouble alert to the fire panel
Inspectors Drain Valve: This is normally on the low point of a system and where you have to drain it after you drained it from the other main drain. I'm not sure why it's called an inspectors test?
Other misc. isolation valves: There are other valves throughout in case you want to isolate one area.
Fire Pump: This is used to increase the pressure to the entire building system when the city water pressure is too low. This can be electric or diesel. There are all kinds of controls, valves, and switches on this thing that I have no idea what they are?!
I think this is all generally correct, but there are some that I am confused on. Like what is the difference between the PIV and the fire control valve?
Any help would be greatly appreciated.
Thank you
Bearcat1 is offline
Old 01-21-2018, 01:07 PM   #2
rrk's Avatar
Rewards Points: 4,858
Re: A Couple Question About Fire Protection Sprinkler Systems
I can help with the fire alarm part-
Flow switch- sends an Alarm not a trouble condition to the FACP, it is a vane inside the pipe once it moves from water movement it sends the alarm
Tamper Switch- on main sprinkler supply valve, sends trouble signal to FACP. Usually a rod laying against a notch in the valve shaft, when shaft rotates rod moves setting off switch
Beware some Fire Depts. will respond to a trouble condition just like it was an alarm condition.
rrk is online now
Fire code question?? BuddySteinle General Discussion 13 04-02-2016 04:02 PM
Sprinkler systems multi family in Wisconsin Mult-Family Plumbing 1 03-27-2016 05:13 PM
Fire Safe building practices and ideas RSims General Discussion 4 11-06-2012 12:51 AM
New Fire Sprinkler Contractor in Tennessee hydraulic New Member Introductions 1 09-22-2012 03:09 PM
