Not sure if this had a sealer on it before... but there is a white haze over the entire area, and little white dots. Cleaned it with a pressure washer and they are still there. Someone I asked said the dots are where rocks are close to the surface, which caused the colorant to not adhere properly, and that nothing could really be done. The dots are primarily in the sunny areas.
Would this condition be caused from rocks near the surface causing the colorant (or maybe sealer, or both) to disappear, and do so mostly in the sunny areas?
I asked two knowledgeable people and got slightly different answers, but the guy that said it was rocks near the surface probably knows more... wanting to confirm.
