This Is What I Cut My Teeth On - Page 2 - Concrete & Paving - Contractor Talk
Old 10-15-2018, 10:11 PM   #21
John the Builder
SmallTownGuy's Avatar
Rewards Points: 7,968
Re: This Is What I Cut My Teeth On
Originally Posted by griz View Post
sand acts as a wick for moisture.
haven't seen sand called out under a slab in 5 years or so.
can't even recall the last time i saw plastic called out.
very common to see vapor barriers like stego called out.
residential guys even using stego type barriers.
imo, it is the new rh standard floor companies are using to determine slab moisture content.
yup
SmallTownGuy is offline
Old 10-15-2018, 10:19 PM   #22
GC/carpenter
Calidecks's Avatar
Rewards Points: 18,378
Last structural slab I poured was about 6 years ago.
Mike.
_______________
Calidecks is online now
griz (10-15-2018)
Old 10-15-2018, 11:49 PM   #23
Designer/Contractor
Rio's Avatar
Rewards Points: 1,888
Originally Posted by Californiadecks View Post
Called out on every one of my residential structural slabs. Sand, plastic, and more sand.
Commercial was oftentimes class 2.
Mike.
_______________
That's how we used to call it out and do it but that's old school, not allowed for new construction per the current CalGreen building code. They want the vapor barrier directly under the concrete with crushed rock as a capillary break under that.
I think the stego stuff that Griz mentioned is what we've been looking for, we had it, lost it, couldn't find it and have been calling out 20 mil or 10 mil plastic. It tears but according to the building science dude a few tears don't matter as long as it's not totally shredded. He wrote an article about this newer way to detail out slabs and mentioned the sand/plastic/sand technique and said in actuality it's a terrible way to do it as it can trap moisture.....
Rio is online now
The Following User Says Thank You to Rio For This Useful Post:
Calidecks (10-15-2018)
Old 10-15-2018, 11:59 PM   #24
GC/carpenter
Calidecks's Avatar
Sand plastic and sand, was a thing for 30 years that I can remember. Damn, it's like coffee, first it's bad then it's good then it's bad again.
Mike.
_______________
Rio (10-16-2018)
Old 10-16-2018, 07:13 AM   #25
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 4,074
My old flatty used wood stakes with two nails on top to hold 1-1/4” piece of pipe. He set the corner stakes with a laser then used a sting to set the other stakes. Grade stakes were used to grade sand and screed the concrete just like these things.
Big Johnson is online now
Old 10-16-2018, 10:01 PM   #26
Designer/Contractor
Rio's Avatar
Mike.
_______________
That's what we always did too, makes perfect sense. 2" sand, 6 mil visqueen which the sand protects on the bottom, 2" more sand on top which protects it again and also allows the sand to be wetted to slow the crete curing but yeah, it's a big no no now.
When that science building dude, Joe complicated last name, started going on about how that's a perfect way for a lot of bad things to happen I remember thinking ,'now we're definitely going to be screwed', but nothings ever come up and hopefully nothing ever will but we don't do it the old way any more.
Rio is online now
Calidecks (10-16-2018)
Old 10-16-2018, 10:05 PM   #27
GC/carpenter
Calidecks's Avatar
I never thought I'd see the day I was uniformed about slab work. Damn, I feel less than.
Mike.
_______________
Old 10-16-2018, 10:07 PM   #28
Fire up the BBQ
griz's Avatar
Rewards Points: 2,320
Mike.
_______________
doubtful you poured a structural slab.
they require huge grade beams, unreal amounts of steel and like 4500 psi concrete.
mix design & slab design by a SE.
they are generally used due to a geo-tech report with a concern of seismic activity and liquefaction.
griz is online now
Old 10-16-2018, 11:02 PM   #29
GC/carpenter
Calidecks's Avatar
Yep, it was structural due to expansive clay. Spec'd at 4500 . Had to have engineering including a field inspection of the soil after footings were dug. Also had to soak the soil first.
I will add it wasn't crazy structural, but structural none the less.
Mike.
_______________
The Following 2 Users Say Thank You to Calidecks For This Useful Post:
Bull Trout (10-16-2018), griz (10-16-2018)
Old 10-16-2018, 11:17 PM   #30
Fire up the BBQ
griz's Avatar
Mike.
_______________
my bad....
i ASSumed some info.....
griz is online now
The Following 2 Users Say Thank You to griz For This Useful Post:
Bull Trout (10-16-2018), Calidecks (10-16-2018)
Cutting teeth on site work quantumflux Excavation & Site Work 6 10-25-2017 09:33 AM
Why I'm armed to the teeth Calidecks Off Topic (Non Trade) 33 10-01-2017 10:49 AM
Avanti 10 in. 60 Teeth Fine Finish Saw Blades (2-Pack) 29.97 JonM Tools & Equipment 8 01-26-2014 01:29 PM
skid steer bucket with teeth or mini-excavator? sadegs Excavation & Site Work 14 02-28-2010 11:12 PM
Help removing bucket teeth 690E Excavation & Site Work 5 01-06-2007 10:31 AM
