This Is What I Cut My Teeth On - Concrete & Paving - Contractor Talk
Old 10-14-2018, 05:29 PM   #1
GC/carpenter
Calidecks's Avatar
Rewards Points: 3,096
Didn't matter the size of the building we screeded 10' at a time. Was able to get the finsih grade and concrete spot on every time. Does anyone still use these?
Mike.
_______________
Calidecks is offline
Old 10-14-2018, 08:29 PM   #2
tgeb's Avatar
Rewards Points: 376
Re: This Is What I Cut My Teeth On
I can honestly say that I have never seen those here on the East coast.
I am still interested in how you set them up. From what you indicated, it could save us a ton of time.
www.gebcon.com
tgeb is online now
Old 10-14-2018, 08:48 PM   #3
KAP's Avatar
Trade: Custom
Rewards Points: 36,666
Mike.
_______________
Coat hangers?... sure...
KAP is offline
The Following User Says Thank You to KAP For This Useful Post:
cedarboarder (10-14-2018)
Old 10-14-2018, 09:15 PM   #4
Fire up the BBQ
griz's Avatar
Rewards Points: 404
Mike.
_______________
haven't seen those since late 70's early 80's on tilt ups in sacramento.
griz is online now
Calidecks (10-15-2018)
Old 10-14-2018, 10:43 PM   #5
Windycity's Avatar
Trade: Masonry
Rewards Points: 8,398
What the hell is that?
Windycity is offline
Old 10-14-2018, 10:51 PM   #6
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 576
How is it better than a screed pin?
Golden view is offline
Old 10-14-2018, 11:11 PM   #7
test
cedarboarder's Avatar
Trade: General
Rewards Points: 1,883
looks expensive. No wonder you use them.
cedarboarder is online now
The Following User Says Thank You to cedarboarder For This Useful Post:
B.Johnson (10-15-2018)
Old 10-14-2018, 11:16 PM   #8
Fire up the BBQ
griz's Avatar
Rewards Points: 404
i have not used them but watched them in use.
just like any system/method, whether we understand it or approve of it, the guys who used them were wicked fast.
i was framing interiors on tilt ups and saw the concrete guys use them.
they are still around and very inexpensive.
griz is online now
The Following 2 Users Say Thank You to griz For This Useful Post:
Calidecks (10-15-2018), cedarboarder (10-14-2018)
Old 10-14-2018, 11:25 PM   #9
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 1,958
Maybe we can get Mike to put on a demonstration for us on how to use it.
Randy Bush is online now
Old 10-14-2018, 11:26 PM   #10
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,006
Screed hook.
Inner10 is offline
Old 10-15-2018, 12:31 PM   #11
GC/carpenter
Calidecks's Avatar
Today everyone seems to guess grade and concrete height.
Mike.
_______________
Golden view (10-15-2018)
Old 10-15-2018, 12:33 PM   #12
GC/carpenter
Calidecks's Avatar
I don't think they were using screed pins when I last used the ones in the OP. My point is I don't see either these days.
Full disclosure, tgeb (Tom) and I were discussing them around the camp fire.
Mike.
_______________
The Following 2 Users Say Thank You to Calidecks For This Useful Post:
Golden view (10-15-2018), tgeb (10-15-2018)
Old 10-15-2018, 08:38 PM   #13
test
Trade: General
Mike.
_______________
on a 4 foot wide by 10 pour some hacks came up short on concrete and a big dip in the middle was the result. They ended up coring a 4 inch hole with a drain cap going no where..
I didn't get the job cause I was the higher price.
The Following 3 Users Say Thank You to cedarboarder For This Useful Post:
Bull Trout (10-16-2018), Calidecks (10-15-2018), TheConstruct (10-15-2018)
Old 10-15-2018, 09:01 PM   #14
Fire up the BBQ
griz's Avatar
Rewards Points: 404
Mike.
_______________
not in my world.
all set by laser off a bench mark....
griz is online now
The Following 5 Users Say Thank You to griz For This Useful Post:
Bull Trout (10-16-2018), pizalm (10-16-2018), shanewreckd (10-15-2018), tang (10-16-2018), tgeb (10-15-2018)
Old 10-15-2018, 09:10 PM   #15
GC/carpenter
Calidecks's Avatar
Originally Posted by griz View Post
not in my world.
How do you set sand by a laser other than spot checking?
I know later in my tilt-up days the skip-loader had a laser attached to it and never was there any screed rails set up for finish grade, like we did in the olden days.
Mike.
_______________
Old 10-15-2018, 09:18 PM   #16
Fire up the BBQ
griz's Avatar
Rewards Points: 404
Mike.
_______________
we set screeds for sand, however using sand under a slab is an old method and not used much now days.
griz is online now
Old 10-15-2018, 09:35 PM   #17
GC/carpenter
Calidecks's Avatar
Called out on every one of my residential structural slabs. Sand, plastic, and more sand.
Commercial was oftentimes class 2.
Mike.
_______________
Old 10-15-2018, 09:51 PM   #18
edward trowelhands
Trade: Diplomat
Rewards Points: 576
Mike.
_______________
Every one... same engineer?
Old 10-15-2018, 10:01 PM   #19
GC/carpenter
Calidecks's Avatar
Nope, different engineers, same soil type though.
Mike.
_______________
Old 10-15-2018, 10:07 PM   #20
Fire up the BBQ
griz's Avatar
Rewards Points: 404
Mike.
_______________
sand acts as a wick for moisture.
haven't seen sand called out under a slab in 5 years or so.
can't even recall the last time i saw plastic called out.
very common to see vapor barriers like stego called out.
residential guys even using stego type barriers.
imo, it is the new rh standard floor companies are using to determine slab moisture content.
griz is online now
Rio (10-15-2018)
Cutting teeth on site work quantumflux Excavation & Site Work 6 10-25-2017 09:33 AM
Why I'm armed to the teeth Calidecks Off Topic (Non Trade) 33 10-01-2017 10:49 AM
Avanti 10 in. 60 Teeth Fine Finish Saw Blades (2-Pack) 29.97 JonM Tools & Equipment 8 01-26-2014 01:29 PM
skid steer bucket with teeth or mini-excavator? sadegs Excavation & Site Work 14 02-28-2010 11:12 PM
Help removing bucket teeth 690E Excavation & Site Work 5 01-06-2007 10:31 AM
