Waterproofing Question - Concrete & Paving - Contractor Talk
Old 04-15-2019, 06:09 AM   #1
nickelec's Avatar
Trade: professional licensed electrician
Rewards Points: 506
I had an addition put in my house and for some reason this was over looked is there anyway you guys recommend o can stop this from the inside ,
The foundation was waterproofed before back fill but I'm not sure what happened to this corner
Sent from my SM-G965U using Tapatalk
nickelec is online now
Old 04-15-2019, 07:28 AM   #2
NYCB's Avatar
Trade: Concrete/Masonry
Rewards Points: 1,434
Re: Waterproofing Question
Do you have a downspout or valley in the roof draining on that corner? Did they install new footer drains before backfilling? What did they use for wateproofing?
NYCB is offline
Old 04-15-2019, 07:32 AM   #3
nickelec's Avatar
Rewards Points: 506
The gutters and downspouts aren't installed yet the siding contractor is working on that now I have a storm drain set up to receive the downspout. He used some sort of roll on product it was like a blue latex,
Old 04-15-2019, 07:35 AM   #4
nickelec's Avatar
Rewards Points: 506
It doesn't come through anywhere else but that corner
Old 04-15-2019, 09:50 AM   #5
WBailey1041's Avatar
Trade: Gutters
Rewards Points: 1,709
Report back once the gutters are installed. Most likely that’s the problem. Even though it’s just that one area that gives you a problem, moving the water away from the foundation stops this sort of thing.
WBailey1041 is offline
The Following User Says Thank You to WBailey1041 For This Useful Post:
NYgutterguy (04-15-2019)
Old 04-15-2019, 01:06 PM   #6
nickelec's Avatar
Rewards Points: 506
Not sure I'd you can tell from the picture but there's no concrete or stone there I can literally see the backfill, I know it needs to be filled in I was just asking here for the best approach
Old 04-15-2019, 06:55 PM   #7
Bull Trout's Avatar
Rewards Points: 132
looks like there is a gap between the edge of the slab and the wall, am I seeing that right?
Bull Trout is offline
Old 04-15-2019, 06:59 PM   #8
nickelec's Avatar
Rewards Points: 506
Just on the bottom corner there
Old 04-15-2019, 07:00 PM   #9
Bull Trout's Avatar
Rewards Points: 132
is there a vapor barrier under the slab?
Does it extend under the wall?
Old 04-15-2019, 07:01 PM   #10
nickelec's Avatar
Rewards Points: 506
There's Is vapor barrier under the slab the walls were poured before the slab you can't see it but it's cut about a half inch above slab
Old 04-15-2019, 07:19 PM   #11
Bull Trout's Avatar
Rewards Points: 132
This spot? I canít tell if itís a hole or a shadow?
Old 04-15-2019, 07:27 PM   #12
nickelec's Avatar
Rewards Points: 506
It's a hole
Old 04-15-2019, 07:36 PM   #13
Donohue Const's Avatar
Rewards Points: 1,722
did you say that it's a hole where you can see the backfill?!
if that's the case it really should of been filled prior to backfill
Ryan
www.ryandonohueconstruction.com
Donohue Const is offline
Old 04-15-2019, 07:39 PM   #14
nickelec's Avatar
Rewards Points: 506
I agree but what do I do now dig it up ? I'm trying to avoid that can I fill it with hydraulic cement
Old 04-15-2019, 08:40 PM   #15
is the basement going to be finished?
Ryan
Old 04-15-2019, 08:41 PM   #16
nickelec's Avatar
Rewards Points: 506
At some point I plan to finish it yes
Old 04-15-2019, 08:58 PM   #17
tgeb's Avatar
Rewards Points: 848
I'd pack everything full with hydraulic cement and see if it holds. Next step would be to address it from outside.
www.gebcon.com
tgeb is offline
Old 04-15-2019, 10:01 PM   #18
if it was someone else's house, dig from outside and water proof
my own house, probably hydraulic cement and the gutters
then see what happens before it gets finished
Ryan
The Following User Says Thank You to Donohue Const For This Useful Post:
tgeb (04-16-2019)
Big Question Related to HVAC Trade - License hdung91 HVAC 3 05-29-2013 08:29 PM
Question about workin on my own oil burner InterCounty HVAC 6 04-29-2013 12:05 AM
Stupid question? Anyone ever mix sodium bicarbonate with recycled glass? MasterBlaster Sandblasting 7 03-23-2013 06:14 PM
Vinyl Flooring Adhesive Question josephdan General Discussion 1 03-05-2013 05:36 PM
Waterproofing Question jakejorgenson Carpentry 5 07-16-2011 06:58 PM
