"Verify Footing" On Plans. How? - Concrete & Paving - Contractor Talk
Old 04-04-2016, 05:03 PM   #1
diplomat
Golden view's Avatar
Rewards Points: 698
Removing wall on main floor, new beam bears on post, load path traces to post in finished basement.
City accepted plans that request I verify that a footing exists, otherwise I have to cut the concrete and pour a new one. I'd love to avoid hauling out 2000 pounds of material and hauling back in 2000 pounds of concrete.
How would you verify that there's a footing? I have original plans from the 1950s that show a footing. Floor is vinyl. I could roto hammer several holes and see if it hits hard for 12+ inches. Any better ideas? It'll be up to the inspector in the end, so the more I have to convince him, the better.
Golden view is online now
Old 04-04-2016, 05:06 PM   #2
Dan_Watson's Avatar
Rewards Points: 2,748
Re: "Verify Footing" On Plans. How?
We always have to dig and confirm. Haven't found a better way so I am interested to hear if there is a better way as well.
Dan_Watson is offline
The Following User Says Thank You to Dan_Watson For This Useful Post:
Golden view (04-04-2016)
Old 04-04-2016, 05:11 PM   #3
diplomat
Rewards Points: 698
Damn. I'll put on my best charm and hope for the best.
Old 04-04-2016, 05:13 PM   #4
Dan_Watson's Avatar
We have used ground penetrating radar before but it gets expensive and Xray may work. Probably depends on the availability of those services in your area.
How much can you charge to drill and repair or dig vs those services.....
Old 04-04-2016, 05:16 PM   #5
diplomat
Rewards Points: 698
So if there's a slab, you cut a section and dig next to the footing to show it's there? I guess that's still better than replacing the footing.
I bid this as part of a more major remodel for better or worse so I'll do whatever costs me less.
Old 04-04-2016, 05:26 PM   #6
Dan_Watson's Avatar
Depends how deep and where it is located. We have had 2-3 addition rebuilds that we dug from the outside. Inside we will cut and dig down to show the footing depth.
Old 04-04-2016, 05:32 PM   #7
diplomat
Rewards Points: 698
Yeah this is right in the middle of a basement.
Old 04-04-2016, 05:34 PM   #8
Dan_Watson's Avatar
Cut and dig. Best case the footing is there, worst case you are halfway to the new footings.
The Following 4 Users Say Thank You to Dan_Watson For This Useful Post:
Builderbob 72 (04-04-2016), Eaglei (04-06-2016), Golden view (04-04-2016), Jaws (04-05-2016)
Old 04-04-2016, 06:33 PM   #9
Eater of sins.
ScipioAfricanus's Avatar
Rewards Points: 190
Drilling it with nice long bits is what is used here quite a bit. No pun intended.
Andy.
ScipioAfricanus is offline
The Following 2 Users Say Thank You to ScipioAfricanus For This Useful Post:
Golden view (04-04-2016), Rio (04-04-2016)
Old 04-04-2016, 07:43 PM   #10
philcav7's Avatar
Trade: Residential Remodeling
Rewards Points: 1,185
I have drilled and cut/dig in the past. Drilling is certainly less invasive.
I have to dig to verify two pier footings this week. Unfortunately mine are out of the thermal envelope and must be 42" min. I'm expecting the worse case scenario...to find a 36" footing that will need pulled and replaced by hand.
No access for a machine to do the work.
philcav7 is offline
The Following User Says Thank You to philcav7 For This Useful Post:
Old 04-04-2016, 08:07 PM   #11
diplomat
Rewards Points: 698
Yee haw.
I have another one coming up that I know doesn't exist, so at least I know I have to haul 3000 pounds up and 3000 pounds down the basement stairs.
Old 04-04-2016, 09:30 PM   #12
philcav7's Avatar
I have large sand bags that fit inside a 5G bucket. When I dig in basements, we put the sand bags in the multiple buckets, like a trash can liner. Shovel directly into the bucket, remove, tie closed if needed, carry out a manageable weight into the truck/trailer.
If you have a dump bed or throwing the fill into the dumpster, there's no need to bag. I pay $65/ton for dumpsters. 3K lbs would cost me $90 to send to the dump. Most likely cheaper than bagging, hauling, and dumping as clean fill. I don't always have a dumpster onsite so the bags do the trick.
How many/how big footings are you digging? 3K is a lot of soil/Crete, For interior footings.
philcav7 is offline
Old 04-04-2016, 09:38 PM   #13
Bubble stick operator
Defenestrate's Avatar
Rewards Points: 40
Originally Posted by Golden view View Post
... I could roto hammer several holes and see if it hits hard for 12+ inches...
I've done exactly that. And do enough to be able to trace a rough outline so that if the inspector gives you a ton of chit, you can just hand him a drill with a long bit. Even an inspector can figure out the diff between breaking through after 4" and 12".
Defenestrate is offline
The Following User Says Thank You to Defenestrate For This Useful Post:
Old 04-04-2016, 09:54 PM   #14
diplomat
Rewards Points: 698
Just a couple. 37x37x12 and 48x48x12. I guess that's about 3600-3800 pounds total each way.
Old 04-04-2016, 10:22 PM   #15
philcav7's Avatar
48x48f for a footing? Does your area have the soil bearing capacity of quicksand?
I'm not a concrete guy. Isn't there some ratios of ideal thickness vs. to surface area? I think I remember seeing that in the ACI book. What are you sitting on it?
philcav7 is offline
Old 04-05-2016, 06:19 PM   #16
diplomat
Rewards Points: 698
I asked the engineer to confirm. A lot of weight is on it. It's the only footing other than the perimeter. A single footing and post holds about 1/4 of the first floor, second floor and roof loads.
We are allowed 1500 psf, so this is good for 24,000 ponds. I still feel like it could have been thinner than 12" with more or bigger rebar, but oh well.
Old 04-05-2016, 06:20 PM   #17
diplomat
Rewards Points: 698
Drilled to check, pretty clear that it is just a 4" slab everywhere. Used 3/16 12" long SDS plus bit for minimal disturbance and maximum speed. Each time after 4" I buried the rest.
Old 04-05-2016, 06:50 PM   #18
Particulate Filter
Metro M & L's Avatar
Trade: Flooring
Rewards Points: 1,484
That sucks.
Cha ching order?
Metro M & L is offline
Old 04-05-2016, 08:06 PM   #19
diplomat
Rewards Points: 698
Originally Posted by Metro M & L View Post
That sucks.
Cha ching order?
Only for the Sakrete. For me, I win or lose a little. I estimated 32 hours and $900 in materials for framing on this job, and factored it into my bid. I might still make it.
Old 04-05-2016, 10:34 PM   #20
Rewards Points: 40
Where's that "don't like!" button when you need one. Sorry to hear...
Golden view (04-05-2016)
Reading Plans Inner10 General Discussion 18 05-07-2014 09:58 PM
Deck Construction @ Winery: Review Our Plans? dutchswan General Discussion 14 05-23-2013 12:14 PM
Customer with no plans ArtisanRemod Remodeling 6 04-08-2013 10:51 AM
Mobile Family Plans angus242 Technology 13 06-03-2012 07:23 PM
Bad Home Plans Cost US! NC2X4 General Discussion 0 02-28-2009 01:34 AM
