Unconsolidated Concrete - Concrete & Paving - Contractor Talk
Old 09-21-2016, 05:56 PM   #1
3 Jacks 2 Nines
bwiab's Avatar
Trade: Wannabe Homebuilder
Rewards Points: 2
Pulled the forms today and found this. Concrete guy told me that it didn't consolidate because the second truck was too dry. I'm thinking maybe he forgot to drop the vibrator here? Any cause for concern?
bwiab is online now
Old 09-21-2016, 06:42 PM   #2
General Contractor
greg24k's Avatar
Rewards Points: 8,906
Re: Unconsolidated Concrete
Slight omission could result in a portion of wall having insufficient cement bonding the aggregate together and this is the result ... If you see the same on the other side, you could have a structural issue, or depending how deep this is, the first hydrostatic movement or any lateral force could cause a structural crack.Also something like this tends to leave patches of porous concrete and you might have water seepage down the road.
Hard to tell from a picture but in some cases I would suggest talking to a structural engineer and have him evaluate the situation... If it was my call I would suggest using epoxy injection plugs and see if that crack can be filled and use carbon fiber staples 12" OC along entire crack to make a structural repair (needed/or not) just to make sure that portion of the foundation wall is reinforced.
Good luck
greg24k is online now
The Following 2 Users Say Thank You to greg24k For This Useful Post:
asevereid (09-21-2016), bwiab (09-21-2016)
Old 09-21-2016, 07:24 PM   #3
Frank Castle's Avatar
Rewards Points: 2
Hey greg, I'm not tryin' to be a wise-ars, I'm honestly asking.
Would it be cheaper to just replace it? And done right.?
Adapt, Improvise, Overcome.
Frank Castle is offline
Old 09-21-2016, 07:37 PM   #4
Fire up the BBQ
griz's Avatar
Rewards Points: 3,068
Looks more like a cold joint.
Liability wise may be best to have a SE evaluate it and make a recommendation.
griz is online now
The Following 4 Users Say Thank You to griz For This Useful Post:
bwiab (09-21-2016), CConcreteEx (09-24-2016), donerightwyo (09-21-2016), Railman (09-22-2016)
Old 09-21-2016, 07:39 PM   #5
GC/carpenter
Calidecks's Avatar
Rewards Points: 176
Looks like a cold joint to me as well. Was there a long wait between trucks? Did you vibrate it?
Calidecks is online now
The Following 2 Users Say Thank You to Calidecks For This Useful Post:
Old 09-21-2016, 08:05 PM   #6
General Contractor
greg24k's Avatar
It can be done many ways, depends who is willing to pay and what they wanna spend, also who is liable, is this structural or not, it could be nothing also for all we know, or it could be something.
They have to get a contractor, engineer, the owner, maybe concrete representative, and see who is at fault, and come up with a remedy.
bwiab (09-21-2016), Frank Castle (09-21-2016)
Old 09-21-2016, 09:21 PM   #7
3 Jacks 2 Nines
bwiab's Avatar
Rewards Points: 2
Well I freaked out and ran back down to the jobsite to inspect it closer myself. Definitely appears to be a cold joint. Don't know what happened. Guys were vibrating regularly far as I could tell. Trucks were always two deep. I filmed the first truck and the concrete was flowing great. I feel pretty confident that this is not a structural issue. There is continuous bearing across the joint. Two minor cavities at a form tie. Will probably get the SE to review anyway. That being said, what does this do for my waterproofing? We were planning on doing one coat of the black stuff. Should I grout this first?
bwiab is online now
Old 09-23-2016, 06:51 PM   #8
giannid's Avatar
Trade: concrete excavating sitework masonry
Rewards Points: 114
That is definitely a cold joint. In a flat work job you can usually make it look a little prettier by going out on the concrete and working the new into the old. In a wall that's not possible. Cold joints can be a defect if the first load of concrete was too cured to bond to the second/newer load. Hard to tell by looking at it though. The joys of concrete.
giannid is offline
The Following User Says Thank You to giannid For This Useful Post:
bwiab (09-24-2016)
Old 09-24-2016, 03:30 PM   #9
CCC
CConcreteEx's Avatar
Trade: Concrete
Rewards Points: 537
Cold joint, not going anywhere just looks a little ugly. Have him patch it, no need for concern IMO.
CConcreteEx is offline
The Following User Says Thank You to CConcreteEx For This Useful Post:
bwiab (09-24-2016)
If you're not on Facebook, you should be. Sir Mixalot Marketing & Sales 1864 08-25-2020 01:43 PM
Help Thinking outside the box here... CONCRETE HELL!! JeremyBCalnan Tools & Equipment 37 06-24-2014 10:33 PM
Concrete Floor, no vapor barrier ericomerico Specialty Coatings 6 06-17-2014 08:27 AM
need help on bidding for concrete jobs! Bconcretegirl Marketing & Sales 15 12-04-2013 12:25 PM
Concrete footing removal 18withtools Demolition 19 01-29-2013 07:34 PM
