Too Early To Pour? - Concrete & Paving - Contractor Talk
Too Early To Pour?
Old 03-12-2013, 06:41 PM   #1
Dierte's Avatar
Trade: Commercial Electrician
Rewards Points: 83
Too Early To Pour?
I'm in Ohio. My concrete guy wants to form on thursday and pour on friday. This is for a patio, stairs, walkways. I'm just concerned that it may be too early in the year to pour. The weather looks like this:
Thurs hi 40, low 31 pm flurries
Fri 51,44
Sat 48,35
Sun 38,34
Mon 47,34 rain
Am I being overly concerned or ? Thanks guys
Originally Posted by rselectric1 View Post
EXACTLY! Being cheap can get pretty expensive.
Dierte is offline
Old 03-12-2013, 06:50 PM   #2
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 702
Re: Too Early To Pour?
As long as there is no frost in he ground, they will pay for hot water and calcium, and you have blankets, you are good! What type of finish? Broom?
overanalyze is offline
Jaws (03-12-2013)
Old 03-12-2013, 06:51 PM   #3
The Sheriff
Jaws's Avatar
Rewards Points: 4,940
I pour in 50+, but its Texas.
I know some additives can be added, possibly fly ash, but I imagine a cold weather guy will be more help.
"The sound of the saftey clicking off is the only warning your gonna get......., so cover your ears" Northeast Wyoming 2016
John
Jaws is online now
Old 03-12-2013, 07:00 PM   #4
mart4005's Avatar
Trade: concrete leveling
Rewards Points: 81
we've been pouring all winter. as long as it's 25 degrees and rising when we place it is our rule, and we've kept the frost out of the ground were good to go. The concrete has additives in it for that purpose hot water, water reducer, calcium, superplasticizers, and who knows what else. Just have to cover it with blankets when it's done.
mart4005 is offline
Old 03-12-2013, 07:07 PM   #5
Dierte's Avatar
Rewards Points: 83
Yes Broom finish. In the contract they say that they seal the concrete with something that is supposed to slow the curing time and help prevent cracks and shrinkage. Does this ring a bell to anyone?
Dierte is offline
Old 03-12-2013, 07:15 PM   #6
Always Learning
Rewards Points: 702
Cure and seal. Pretty common practice, not so important in cold weather though.
Old 03-12-2013, 07:16 PM   #7
mart4005's Avatar
Rewards Points: 81
yep, we use Kure-n-seal, it's a Sonneborn product.
mart4005 is offline
Old 03-12-2013, 07:30 PM   #8
Renaissance Man
superseal's Avatar
Rewards Points: 5,816
Who puts a broom finish on a patio anyway
With a high 51 and with sun shining, I'd skip the calcium, especially if there's steel reinforcement. As far as cure and seal, I'd skip that too. I would however spec up 4000 psi to facilitate a nice magged rosette finish on my nice new patio
supersealconstruction.com
superseal is offline
Old 03-12-2013, 07:39 PM   #9
I'm a Mac
Chris Johnson's Avatar
Trade: ICF Construction
Rewards Points: 4,254
Drive a bunch of stakes in the ground and if you have no frost, go for it. Looking at your temps, I would probably forgo putting the blankets on the first night, but get them on before end of the day following.
And I would be adding 2% calcium, just so you can get it set up and get it finished
Chris
Chris Johnson is offline
Old 03-12-2013, 07:45 PM   #10
Dierte's Avatar
Rewards Points: 83
I want a broom finish. Better than a smooth finish
Dierte is offline
Old 03-12-2013, 07:47 PM   #11
QCCI's Avatar
Trade: General Contractors/Specialty Contractors
Rewards Points: 952
Nothing wrong with a broom finish. I would trowel it and put a very light broom on it.
QCCI is offline
Old 03-12-2013, 07:50 PM   #12
Always Learning
Rewards Points: 702
Broom is fine, but Super is right, a nice mag swirl looks sweet on a patio!
Old 03-12-2013, 08:14 PM   #13
Dierte's Avatar
Rewards Points: 83
It will be a light broom finish
Dierte is offline
Old 03-12-2013, 11:00 PM   #14
Dierte's Avatar
Rewards Points: 83
And if it makes any diff. They are using 4500 psi
Dierte is offline
Old 03-12-2013, 11:12 PM   #15
Maker of fine kindling
Gus Dering's Avatar
Trade: cabinet maker
Rewards Points: 12,490
Why leave the blankets off the first night?
Does anyone use "high early" anymore? I used to order it by that name if I needed a quick set that needed to be driven on the next day. Not sure exactly what it was, for sure was not calcium.
Gus Dering is offline
Old 03-12-2013, 11:24 PM   #16
Fire up the BBQ
griz's Avatar
Rewards Points: 2,338
Stands for "High Early Strength Concrete".
Have not heard that term in many years....
griz is online now
Old 03-13-2013, 06:39 AM   #17
I'm a Mac
I'll leave the blankets off provided no rain is forecast. The concrete is giving off enough heat to maintain itself, good chance it's still soft enough if you cover it you cosmetically wreck the top, and hopefully the sun is shining the next morning which helps it as well. By the 2nd night the heats pretty much out of the slab and the negative temps can cause an adverse effect...hence get it covered
Chris
Old 03-13-2013, 07:52 AM   #18
Gus Dering's Avatar
Well at least I'm not crazy. Just living in the past, it seems
When I was in the Seattle- Tacoma area, I fancied myself as quite the visqueen tent artist. Mostly for protection from all the liquid sunshine but there were many times we set the salamander heaters up to keep the chill factor off for the day of an early morning pour. The tent was already there anyway.
Old 03-13-2013, 11:41 AM   #19
Renaissance Man
superseal's Avatar
Nothing smooth about a mag finish
Old 03-13-2013, 01:33 PM   #20
concretemasonry's Avatar
Trade: Masonry consultant
Rewards Points: 2,960
Just do not use flyash in the concrete - it is retarder and slows the setting and reduces the early strength that gives you the strength gain you need in cool weather.
For concrete, you must be concerned the the concrete temperature and not the air temperature since most of that will be in forms that provide some air temperature. With 4500 psi you will have enough cement and Type III cement (high early cement) will help to kick off the curing process. Around here, the better suppliers will not supply anything for slabs other than 4000 psi with air entrainment without the regard to when it is poured.
A poor contractor may dislike not using fly ash because that gives him a time lag if everything does not go right.
Dick
Dick
concretemasonry is offline
replace coping or pour coping Santa's Helpers Pool Construction & Enclosures 2 04-05-2013 11:02 AM
To pour or not to pour, that is the question mudpad Commercial Construction 30 06-15-2011 08:07 PM
how early is too early when it comes to xmas music woodworkbykirk Off Topic (Non Trade) 18 12-03-2010 08:27 AM
pour small slab in corner of basement denverboz Masonry 5 08-18-2009 09:47 PM
