Single Sided Concrete Forms? - Concrete & Paving - Contractor Talk
Old 08-03-2014, 08:49 AM   #1
Nac's Avatar
Trade: Concrete, masonry & excavation
Rewards Points: 324
I have a 30' long x 6'4" high 12" wall I have to pour up against an existing hollow CMU wall. Normally would just use coil rod insert's and loop tie adaptors to a Symons panel if it was a solid wall. I proposed using a Hilti screen and epoxy coil rod and loop ties and the engineer does not want me to tie into the existing CMU wall. I know they make steel A frames for this application seems like overkill for a 6'4" wall. I was thinking a whaler at the top and bottom with a strong back every 4' and a 45 degree kicker at every strong back. Has anyone done a form like this or have any suggestions?
Facebook
Nac is offline
Old 08-03-2014, 08:54 AM   #2
JDavis21835's Avatar
Trade: Excavation
Rewards Points: 386
Re: Single Sided Concrete Forms?
Seems to me you are on the right path with the whaler, strong back and kicker plan. Maybe a whaler in the middle as well just for fun. Its easier to have more bracing than find out you need more in mid pour.
JDavis21835 is offline
Old 08-03-2014, 09:17 AM   #3
QCCI's Avatar
Trade: General Contractors/Specialty Contractors
Rewards Points: 952
We typically use the coil rod method also. I'd say add another whaler and you're on the right track, just throw some extra bracing in for a little security.
QCCI is offline
Old 08-03-2014, 08:52 PM   #4
CCC
CConcreteEx's Avatar
Trade: Concrete
Rewards Points: 537
Just remember, when you only form one side, think twice the pressure. Brace the h*** out of it!
CConcreteEx is offline
Old 08-21-2014, 07:32 PM   #5
Nac's Avatar
Rewards Points: 324
Ended up renting Ulma forms and mini A frames anchored to the footings.
Facebook
Nac is offline
The Following User Says Thank You to Nac For This Useful Post:
CConcreteEx (10-16-2014)
Old 10-15-2014, 06:29 PM   #6
Forming and Framing
FramingPro's Avatar
Trade: Shell builder
Rewards Points: 3,582
Thats pretty neat.. heavy duty forms for a light duty resi job
Im after fortune and frame
http://www.proicf.com
FramingPro is offline
Old 12-16-2014, 10:11 PM   #7
concrete2013's Avatar
Trade: Concrete
Rewards Points: 260
Did it hold?
concrete2013 is offline
Old 12-17-2014, 09:42 AM   #8
Nac's Avatar
Rewards Points: 324
Originally Posted by concrete2013 View Post
Did it hold?
Yes it held if you look at the bottom there is a waler on a 45 there are (2) 5/8 treaded rods epoxied 2' deep at every strong back holding the forms in place. Here is a pic of the wall striped before we rubbed it down.
Facebook
Nac is offline
Old 12-17-2014, 12:04 PM   #9
CCC
Trade: Concrete
Rewards Points: 537
Who spilled the coffee?
Old 12-17-2014, 03:03 PM   #10
Alldayrj's Avatar
Trade: Mason
Rewards Points: 284
Why did this have to be done? Bearing for a new extension or was the block unstable? Seems like the block had to be in good shape to hold the p wet concrete back...
Just wondering
Alldayrj is offline
Old 12-17-2014, 04:56 PM   #11
Trade: Concrete
Rewards Points: 260
Looks good. We did somthing similar on a ranch home, we were adding a basement addition and had to underpin under the footer for these 8' walls. Pretty much did the same thing only with gates.
If you're not on Facebook, you should be. Sir Mixalot Marketing & Sales 1862 02-15-2020 02:59 PM
Help Thinking outside the box here... CONCRETE HELL!! JeremyBCalnan Tools & Equipment 37 06-24-2014 10:33 PM
17-ton concrete slab overhang fell from a bank building in Stroud Township AmeliaP Masonry 27 09-05-2013 07:16 PM
Concrete Patio ECSOWNER Concrete & Paving 14 01-02-2013 09:00 PM
Board form concrete wall water stains DerekRC Concrete & Paving 0 12-06-2011 01:44 PM
