Pulling Forms On 8" Wall - Concrete & Paving - Contractor Talk
Old 06-08-2018, 09:38 AM   #1
jb9's Avatar
Trade: Plumbing
Rewards Points: 204
Hello,
I just poured an 8" thick wall, 4 feet high (mostly ICFs but with some plywood formed bumpouts/pilasters). I want to pull the plywood sections but don't want to pull them too early or wait too long and have them stuck.
The pour happened 48 hours ago. Temps have been 50-70 degrees and weather has been bone dry (good conditions).
I'm not in a rush and have plenty of cleanup and prep to do for the plates... should I wait another 48 hours? I just want a good result. Ready-mix plant says their cylinder tests show 70% strength after 7 days and the pour was a 5-bag 3000 psi around a 5-6 slump.
Does waiting another couple days sound good?
Thanks in advance.
jb9 is offline
Old 06-08-2018, 10:01 AM   #2
Caleb1989's Avatar
Rewards Points: 356
Re: Pulling Forms On 8" Wall
Pull the forms, nothing to worry about. I usually pull forms the following morning, even in cooler weather.
If you find any rock pockets that will be exposed, it’s best to fill it sooner while the concrete is still green.
Caleb1989 is offline
The Following 3 Users Say Thank You to Caleb1989 For This Useful Post:
concretemasonry (06-08-2018), rustyjames (06-08-2018), tgeb (06-08-2018)
Old 06-12-2018, 02:38 PM   #3
NYCB's Avatar
Trade: Concrete/Masonry
Rewards Points: 682
Get your forms up and clean and oil them.
Like said above, pulling them the next day is pretty standard during the warm parts of the year.
NYCB is offline
Old 06-12-2018, 02:59 PM   #4
Fire up the BBQ
griz's Avatar
Rewards Points: 436
in the calif school world forms stay on for 7 days...
griz is online now
Old 06-12-2018, 03:05 PM   #5
Caleb1989's Avatar
Rewards Points: 356
That sounds like union talk And those plywood forms- trash em!
I grew up in NW Washington and everything was 1 1/8” fiberglass veneer form panels that you can use over and over. My dad sprays them with a diesel and oil mix and has used them constantly for 30 years.
Old 06-12-2018, 03:45 PM   #6
Fire up the BBQ
griz's Avatar
Rewards Points: 436
not union...dsa requirement
griz is online now
Removing stucco/cement from interior brick wall RookiePlumber Masonry 31 02-07-2018 11:33 PM
60' wide x 25' tall dividing wall - Steel Stud vs 8" Block Elastoboy Commercial Construction 11 07-19-2014 03:06 PM
Exterior wall covering options? bob_cntrctr Construction 8 02-25-2013 08:05 AM
Floor framing. Why put a joist under a non-loadbearing wall? Willin Architecture & Design 54 10-28-2012 08:21 PM
Wet basement, just making sure my thoughts are correct HandicappedHome Excavation & Site Work 7 10-12-2012 06:17 AM
