Powder Actuated Pins In 4500 Psi Concrete - Concrete & Paving - Contractor Talk
Old 09-26-2012, 09:24 PM   #1
GC/carpenter
Calidecks's Avatar
Rewards Points: 822
Does the yellow shot pins shoot through 4500 psi concrete, or is it going to be a problem? The concrete will be new.
anybody?
Calidecks is offline
Old 09-26-2012, 09:50 PM   #2
RobertCDF's Avatar
Trade: Custom deck builder
Rewards Points: 1,533
Re: Powder Actuated Pins In 4500 Psi Concrete
I've done some work on a commercial building that had much higher psi concrete than normal, it took 2 red loads to sink nails.
RobertCDF is offline
The Following 2 Users Say Thank You to RobertCDF For This Useful Post:
Calidecks (09-27-2012), greg24k (09-27-2012)
Old 09-26-2012, 09:54 PM   #3
GC/carpenter
Calidecks's Avatar
Rewards Points: 822
Yea, I'm building a room addition and the concrete is 4500 psi, I was just wondering if that was going to be an issue when I shoot down my plate on the interior walls. I'm used to 2500 psi.
Old 09-27-2012, 07:14 AM   #4
General Contractor
greg24k's Avatar
Rewards Points: 8,474
Like Robert said, depending how old the concrete is, and sometimes it takes two shots to get a nail in.
If you nailing down the plates, I always use nails with washers, they have better holding capacity... and if you have to shoot it twice the the washer will stop nail head at the surface VS. using regular nails, and if you shoot twice, the pin sometimes drives the nail past the surface busting the wood and cracking concrete surface.
greg24k is offline
Old 09-27-2012, 10:26 PM   #5
Ex-Framer
Needles's Avatar
Trade: Finish Carpenter
Rewards Points: 1,682
Why not just use 1/4" ral pins?
Needles is offline
Old 09-28-2012, 12:33 AM   #6
GC/carpenter
Calidecks's Avatar
Rewards Points: 822
Ok you got me what are 1/4 inch ral pins?
Old 09-28-2012, 05:05 AM   #7
General Contractor
greg24k's Avatar
I think what he meant to say is "Rawl", its a Spike anchor, which sometimes called Rawl pins. You have to pre-drill then drive them in. They come in "s" shape at the end to create an expansion mechanism... we mostly use them when tamper-proof installation is required, but they used for many other applications, because they come with different heads,i.e mushroom head,flat head,tie wire head,etc so you can use them for attaching sill plates, forms, drop ceiling track,etc.
greg24k is offline
Old 09-28-2012, 06:02 AM   #8
tgeb's Avatar
Rewards Points: 52
I have a 27 cal. gun but usually just hand drive the pins in, I have more control of the depth, fewer "blow outs" and they drive pretty easy.
www.gebcon.com
tgeb is offline
Old 09-28-2012, 11:33 AM   #9
GC/carpenter
Calidecks's Avatar
Rewards Points: 822
They sound a lot stronger, probably get them at White Cap?
Old 09-28-2012, 11:35 AM   #10
GC/carpenter
Calidecks's Avatar
Rewards Points: 822
If you can hit them in when the concrete is green that will work, but this 4500 psi chit might change that.
Old 10-03-2012, 05:55 PM   #11
NYCB's Avatar
Trade: Concrete/Masonry
Rewards Points: 478
I buy the red ones and just power it down with the little vent thing if they are sinking too deep.
NYCB is offline
Crown molding on concrete ceiling CadetC Finish Carpentry 13 09-15-2012 09:14 PM
Raised concrete deck Bearded Wonder Construction 10 12-07-2011 02:09 PM
Board form concrete wall water stains DerekRC Concrete & Paving 0 12-06-2011 01:44 PM
Recommendation on changing concrete color with breathable product? RDBD Specialty Coatings 0 06-07-2011 08:57 AM
