Letís Talk Mud Jacking. - Concrete & Paving - Contractor Talk
Old 06-16-2018, 07:34 PM   #1
WBailey1041's Avatar
Trade: Gutters
Rewards Points: 1,625
Iíve got a long running dispute going with my father in law and brother in law about the fathers garage. Itís sinking on one corner and Iíve just learned Iím expected to help fix it tomorrow. Two problems here. First I donít know jack $&#* about concrete, second I donít know jack @#% about raising a structure.
Looking at the pictures would it be silly of me to suggest mud jacking? These two knuckle heads think they are going to jack this garage up and put blocks under it until they can break out and repour the concrete deeper.
-8530fe3a-2fb4-4a82-8d6f-3d20f77563de.jpeg   -d0f045db-3e2d-4600-b32b-2e383aeeeb23.jpeg
WBailey1041 is offline
Old 06-16-2018, 07:44 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 2
Re: Letís Talk Mud Jacking.
that looks like a full demo, install proper footings and pour new concrete.
mud jacking would make that worse.
it is intended to bring adjacent surfaces, one which has sunk, flush again.
griz is offline
The Following 2 Users Say Thank You to griz For This Useful Post:
Bull Trout (06-17-2018), hdavis (06-17-2018)
Old 06-16-2018, 08:04 PM   #3
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 520
Well, you probably won't convince them, but this from someone who has done a significant number of residential repair jobs, and you have multiple issues going on, just from what I can see in that picture.
"Band-Aid" type fixes in these situation never work out.
Old 06-16-2018, 08:06 PM   #4
Capra aegagrus
Tinstaafl's Avatar
Agreed, that's not a candidate for mud jacking. Jacking works for a tilted slab; does nothing to fix a fractured mess like that.
Tinstaafl is online now
Old 06-16-2018, 08:28 PM   #5
hdavis's Avatar
Rewards Points: 70
Sure, jack up the garage and put a real fiundatiin and slab in.
Thst looks like a gravel floor just had concrete poured inside after the garage was built.
Need a bunch of bracing inside that Before you do anything else.
Hijacking could level the slab pieces, but I'm betting the sills are gone on that.
hdavis is offline
Old 06-16-2018, 08:31 PM   #6
hdavis's Avatar
Rewards Points: 70
You can mudjack busted up slabs and get the pieces pretty level, but you still have a busted slab. Done all the time on Texas houses.
hdavis is offline
Old 06-16-2018, 09:55 PM   #7
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 1,682
Know a guy here that is really good at mud jacking. Have heard of them mud jacking a building backup level , foundations ,basement , the whole building. It not just for slabs.
Randy Bush is offline
The Following User Says Thank You to Randy Bush For This Useful Post:
hdavis (06-17-2018)
Old 06-17-2018, 12:50 AM   #8
Trade: Gutters
Thanks fellas. I found the attached through a google search. Anyone see anything wrong here? Seems fairly straightforward.
https://www.finehomebuilding.com/199...ng-up-a-garage
-78b4d0f7-75e4-4a1f-8113-77c517efb627.png   -41c9b9ad-8ff1-4236-8593-0a31ff180b70.png
The Following User Says Thank You to WBailey1041 For This Useful Post:
A&E Exteriors (06-17-2018)
Old 06-17-2018, 08:38 AM   #9
Fishindude's Avatar
Trade: Industrial
Rewards Points: 994
Look at the surface finish on that slab. It's a poor job at best, done by somebody that didn't know what they were doing. Remove and replace.
Fishindude is offline
Old 06-17-2018, 02:15 PM   #10
Randy Bush's Avatar
Bad thing is ,looks like the slab was poured over the bottom plate. If the rest of the building is in fair shape it needs to be lifted up all concrete removed , new footings stem wall and slab, or a new mono-slab. At which point will more then likely need a new bottom plate, treated, and possibly some wall, stud repair. All do able , like they say nothing money can't fix.
Old 06-18-2018, 01:04 PM   #11
VinylHanger's Avatar
Rewards Points: 11,098
Well? How did it go?
VinylHanger is offline
The Following User Says Thank You to VinylHanger For This Useful Post:
hdavis (06-18-2018)
Old 06-23-2018, 12:42 PM   #12
Trade: Gutters
Interesting to say the least. Polish engineering won the day.
They simply scabbed 4x4s to the studs and then poured concrete under it once it was in position. Next week we tear out the concrete.
-865567a1-7dd5-4461-b2de-cfd4ae3f20da.jpeg   -d88817d8-0694-4b01-b6fa-d919c5a20073.jpeg
Old 06-23-2018, 03:12 PM   #13
hdavis's Avatar
Rewards Points: 70
So, not much chance of this getting over built....
I couldn't figure out from your post where they poured the concrete, it looks like the existing would be up against it.
Good execution of the jacking setup.
hdavis is offline
Anyone here use straight talk? Sabagley Off Topic (Non Trade) 3 12-12-2014 07:38 PM
Haldey & Son Painting is a New Painting Company to Contractor talk hadleypainting New Member Introductions 3 05-11-2013 07:11 PM
Ever had a home owner ask to talk TLHWindows Carpentry 19 04-15-2013 07:42 AM
Talk "baby talk" Heritage Business 12 05-08-2010 06:36 AM
New to Contractor Talk myankevich New Member Introductions 4 04-18-2010 11:05 AM
