How To Stop Water From Basement Walls And In Old Wine Cellar Under Front Porch. - Concrete & Paving - Contractor Talk
Old 03-13-2014, 07:07 AM   #1
Handros's Avatar
Trade: Home Remodeling
HELP! snow is melting, water seeps through from who knows where under front porch in old wine cellar in Detroit MI. Ive tuck pointed from outside, dug up and seal coated exterior walls. still water seems to come through where basement wall meets floor. Also i exposed some of the cinder block wall and it does seem moist but no sign of exactly where the water could be coming in and forming puddles in basement.
Anyobe with ideas or suggestions?
Handros is offline
Old 03-13-2014, 08:55 AM   #2
Itrimit's Avatar
Rewards Points: 149
Re: How To Stop Water From Basement Walls And In Old Wine Cellar Under Front Porch.
You've listed yourself as a " home remolded" and it sounds like that's exacally what's going to happen. So what's the problem?
Itrimit is offline
Old 03-16-2014, 09:49 PM   #3
HUI's Avatar
Trade: Utility, sitework, and erosion control contractor
Rewards Points: 178
I would use AV-202 multi-grout. Thy is what I use to seal up leaky manholes
HUI is offline
Old 04-07-2014, 03:10 AM   #4
atlanta
itsreallyconc's Avatar
Trade: dec conc & specialty conc repairs
bottom of bsmt OR top of bsmt ? either you missed the spot OR the mtl was incorrect/applied incorrectly,,, what material did you use - roofing cement ? we use either hlm5000 OR hydralastic on exterior walls
itsreallyconc is offline
Old 04-12-2014, 01:24 PM   #5
Mdj1281's Avatar
Trade: Waterproofing, mold remediation, concrete flat work, below grade egress, foundation repair
Rewards Points: 32
First you must find the source of the water infiltration, there are only three types of this. Either the water is rising up from under the structure (hydrostatic pressure), coming in through the wall itself or coming in through an architectural element (sill plate, siding, roofing, pipe penetration, etc).
To eliminate the first of hydrostatic pressure look at the rest of the basement. If there are not other areas of water infiltration at the same level (besides the one area) then you probably can rule that out.
Next I'd look at the sill area outside. Was the snow against the structure? Is landscape material or beds high against the building? Are there poorly caulked pipe chases or cable wires going into the structure? Rule out the easy stuff first. Take a garden hose and an hour of your time to start low and systematically eliminate these items one by one.
Block foundations are only trumped by stacked stone foundations by me. Hollow cavities allow water to enter in one area and cascade like that famous champaign glass scene until it finds a weak spot to exit. Depending on the construction the block may sit on the concrete slab instead of a footing letting the bottom-most block drain out onto the floor. If the wall itself leaks your best bet is an external repair using hydraulic cement and an elastomeric membrane meant for GREEN concrete. Better yet use a belt and suspenders system, I use a trowled membrane with a bentonite overlay on all retrofits with 100% success in the last 3 years since we began using it. HLM5000, TP60, and other products are good but fail in most retrofit applications because of the concretes moisture content.
Only other solution for the wall itself is water management by a French Drain type system... IF THERE IS A FOOTING! Install pipe along the footing, drill weep holes in the bottom course of block and run to a sump pump. I prefer fixing the problem to recycling water though...
Mdj1281 is offline
Old 04-12-2014, 02:25 PM   #6
General Contractor
greg24k's Avatar
Rewards Points: 8,310
If you understand drawings, you can start with this and that should solve your problem...
greg24k is online now
