Garage Slab Over Existing Concrete - Concrete & Paving - Contractor Talk
Old 08-01-2011, 12:09 PM   #1
pjswan's Avatar
Trade: general remodeling
I am going to be building a new garage after demoing an existing garage. The new garage will larger and the slab will be about 18 inches higher the the existing slab. Is it ok to put 12" of gravel/crushed rock or limestone as a base over the old slab and then pour a new engineered slab over it? The present slab has been in place for at least 60 years. The reason for doing this is cost and not disturbing the existing soil. thanks.
pjswan is offline
Old 08-01-2011, 02:20 PM   #2
I'm on a boat!
J L's Avatar
Trade: Yacht carpenter
Rewards Points: 3,442
Re: Garage Slab Over Existing Concrete
What does your local inspector say?
Also, why don't you go to the intro section and tell us about yourself, what you do, and where you're from. That will help us help you.
J L is offline
Garage slab 20' X 20' edge concerns HHC Concrete & Paving 35 08-10-2018 10:51 AM
400$ for a 14X7 concrete slab? Coastal Pros General Discussion 7 12-13-2009 02:00 AM
how much to charge. concrete curb demo. tie new curd to 6" slab Evan03 Construction 12 11-28-2009 01:54 PM
Existing addition on slab drainage problem dberkey1 Construction 4 08-21-2009 05:41 AM
New plywood subfloor over concrete slab jeffaah Construction 5 10-17-2008 11:33 AM
