Forming A Caisson - Concrete & Paving - Contractor Talk
Forming A Caisson
Old Today, 02:16 PM   #1
Mike-B's Avatar
Rewards Points: 930
Forming A Caisson
We often pour pad and pier foundations. An open excavation with a big concrete pad on the bottom with a caisson on top of the pad. Monolithic pour.
I use concrete form tubes for piers 5' diameter and less.
I use custom made, steel culvert pipe for large diameter piers.
I'd like try and build a 5'-6" diameter x 4' tall pier form in our shop. I would plan to build a box out of 2X material but I need some type of sheet goods to line the form. I was considering using 3/16" hardboard sheeting.
Will it bend that radius without special tooling?
Mike-B is online now
